Question about Gateway FPD2275W LCD Monitor
CRT Monitor Not displaying blue components
I have an old, general TV... crt monitor for my Intel Celeron[P-2] computer. It shows red and green components of any image perfectly but can't show blue components. I checked if the cable of monitor is not working properly, but there wasn't any disconnection.
If I push power button of monitor, it shows all three components perfectly for short period of time before closing. Please find some solution to repair this type of problem.
E-mail: Kiranshakya_id@yahoo.com
    Problem Solver:
  • 8 Answers
Your moniter's video circuit is faulty .
Posted on Jul 08, 2008
Vertical lines on lcd d520
Time to replace your LCD Screen. To verify that it is the lcd screen on the laptop, borrow a Monitor from a neighbor, friend, relative or co-worker and plug it into the laptop.
It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 14, 2012 | Dell Latitude D520 - Celeron Intel Celeron...
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
Lg crt monior display cable wire circuit diagram
Pin Signal 1 Red Video 2 Green Video 3 Blue Video 4 Monitor ID - Bit 2 5 Ground 6 Red Ground 7 Green Ground 8 Blue Ground 9 [KEY] 10 Sync Ground 11 Monitor ID - Bit 1 12 Monitor ID - Bit 0 13 Horizontal Sync 14 Vertical Sync 15 N/C (Reserved)
Feb 11, 2010 | Computers & Internet
ADI GD-166G SCREEN HAS GREEN COLOUR DISPLAY
hope u r a professional..as u r handling chip-level repairing of monitor, knowing itz hazardous n dangerous..
however, check thoroughly for dry soulderings..(esp. at the crt base)..[this chance is maximum]..
see if the base is loose or faulty..
yes, it can b the 'chroma ic'..but don't ignore the associated components..(esp around the base)..
check video amplifier n sub section..
the colour diodes, transistors n resistances at the base..
for better supervision contact ur system admin/vendor....
Nov 11, 2009 | ADI Corporation MicroScan 5P (White) 17"...
Green light flickering & Sunset red screen display.
You've got components that have gone bad, probably from age and the normal heat inside a CRT monitor case.
I hate to say it, but it's really not worth fixing. You can usually find a used but working 17" monitor for under 20 bucks.
Sep 27, 2009 | LG Studioworks 700S 17" CRT Monitor
Crt monitor video chroma processing
first you check the signal cable continuty by multimeter then correct it if faulty .if ok then give -ve click at red cathode on crt base in on condition if red raster comes on screen then red cathode is ok same thing for green and blue cathode if green cathode do not shows green raster after -ve click then crt is faulty then give -ve click at R point at color raster ic which has heat sink if red color comes then ic is ok same thing for green and blue if ic is faulty then replace it if not then check bipolar capacitor if faulty then replace it
Sep 15, 2008 | AOC CT720G 17" CRT Monitor
CRT-Monitor
my e70fsb monitor is self adjusting, brightness goes to maximum
Aug 05, 2008 | Computers & Internet
Monitor image is "posterized"...red,yello, blk and white only
you have defective RGB circuit, or re solder all CRT Board maybe you have lost contact at the RGB CRT Board. RGB means red, green, blue. CRT means Cathode Ray Tube.
Oct 08, 2007 | Apple Studio Display 17" CRT Monitor
Benq v772 CRT show only Blue and Green color
It has to be either a cable or an IC issue. Get your cable checked first (VGA cable)
Oct 01, 2007 | BenQ Value V772 17" CRT Monitor
Gateway FPD2275W LCD Monitor Logo
43 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
