Question about JVC Cameras
JVC Everio GZ-MG27U 20GB HDD Camcorder has a problem that it only will work with AC adapter plugged into the camcorder. I have two batteries, one has a full charge of 7.7vdc indicating a FULL charge, the other has almost no voltage indicating no charge. When I use the good battery, the unit starts up when powered on, then shortly shows a camera - - - - battery on display and then goes to "communication error" and shuts off. I found that the connection at rear of camcorder labeled as the " " voltage point has no voltage on it at all with the AC adapter attached to the camcorder. This indicates to me that it will NOT charge a battery anymore. The "C" contact has about 3.09vdc with the camcorder in OFF mode, and no voltage in the Review or camera mode of the power switch. The "T" contact has 2.91vdc in any of the mode settings for the power switch. If I have the AC adapter attached, and a battery (good one) attached, the camcorder works fine. However, when I disconnect the AC adapter, the battery will not operate the camcorder by itself, and you briefly see a battery display on the screen but it shows low battery, and has a RED outline just before it loses all power. I believe the " " connector but have a broken wire somewhere behind it inside the unit. Can you confirm, and tell how to resolve this problem?
  • Uncle Icabod Jul 08, 2008
    The first response didn't really answer my question. I see my message shows a bunch of " items where I was trying to show the various connection contacts as they are labeled. The + is the one I was saying should be the +7.6vdc, the C is the contact that I read a voltage of +3.09vdc with the power switch in the OFF mode, and the T is the contact that had +2.91vdc on it in all mode settings of the power switch. This is with the AC adapter attached to the unit. I basically don't want to have an outrageous repair for a 2-year old camcorder, but was trying to confirm whether or not my suspicions that there may be a broken wire on the inside area of the camcorder for the + contact so it will not even charge a battery anymore, or accept the battery's own voltage to thus run the camcorder. If I really need to send it in, then yes, I would need to know where a repair facility is nearby to Rialto, CA, and also an estimate of repair costs if I were to chose that route. I believe I may tools to fix it if I am careful, as I was a electronics technician in my working years.
    Thanks, Steve
    Guru:
  • 1,894 Answers
As far as i understood the problem
you need to replace the old battery which is not charging,
please dont use batteries of unequal charge in the camera operation. this will lead to problems from battery leakage to problematic accidents.
dont ever attempt to use batteries of unequal charge.
because i personally did it once and lot of oil like liquid got spilled from battery and spoiled the battery lid and the memory card slot.
Posted on Jul 08, 2008
  • dewan nafees ahmed Jul 08, 2008
    your idea also seems acceptable. there may be a disconnection between the units positive lead.
    Genius:
  • 1,665 Answers
Better you can use a separate charger to have battery fully charged.
  • JVC Master
  • 13,433 Answers
Is your camera still covered by warranty? You will have to send it in for service.
http://www.jvcservice.com/Service/
or contact your dealer directly.
Of you can get yourself a service manual from the site above ones it comes online again and attempt to fix it yourself.
  • 4,472 Answers
Well the first thing I would do is recommend you send your unit in for service as you may end up doing more harm then good. You can call and get free estimates on what this may cost. If you need any further assistance or help locating a service center let me know.
Thanks,
lee
  • Lee A.
    Lee A. Jul 09, 2008
    I hope you have found all my assistance helpful and will rate accordingly.
    Thanks,
    Lee
JVC Everio GZ-MG27U videos appear overexposed (very white, washed out, barely visible) both on the LCD (when recording) and on PC when played back... Is there a setting that needs reset or is it something...
It should no trouble with your JVC Everio GZ-MG27U exactly.You can find the Manual for it to look up the mode setting tips and operations .After correctly reset it,it will be OK .Good luck !
Nov 20, 2010 | JVC Everio GZ-MG27 Camcorder
Our JVC Everio GZ-MG27U Camcorder is stuck on zoom 32X. It will not go lower than 32X.
It seems that your lenses are stuck, take it to a certified technician and ask for them to repair it.
I'd appreciate if you rate this 4 thumbs if I had helped you. If I couldn't help you please rate accordingly.
Jun 15, 2010 | JVC Everio GZ-MG27 Camcorder
Communication error appears in harddrive camcorder JVC EVERIO GZ MG330A , battery doesnt work
Check your battery contacts and camera's battery terminals for some dirt. If not from there, your battery needs replacement. When buying new one, test it first before leaving the store, its because even new one(old stock) might have the same problem. Good luck
Mar 23, 2010 | JVC Everio 25x/20GB Hard Disk Drive...
Deleted Videos on JVC Everio GZ-MG27U
Sometimes the "my computer" could help. go into it after plugging in your camcorder choose the file and search through the folders.
Aug 24, 2009 | JVC Everio GZ-MG30 Camcorder
I need to download the driver
You should be able to find drivers here
http://www.jvc-victor.co.jp/english/download/camcorder/about_winxp.html
May 10, 2009 | JVC Everio GZ-MG360 HDD Camcorder
No power to camcorder
It is the internal circuitry that has to deal with powering the camera with the battery. You will want to follow this link and locate the nearest service center and have it repaired.
http://maps.jvc.com/cAscList/
If you still need assistance let me know. Please take a moment to accept and rate my solutions.
Thanks,
Lee
Oct 03, 2008 | JVC Everio GZ-MG27 Camcorder
Cameras Logo
191 people viewed this question
Top JVC Cameras Experts
Michael Galve
Michael Galve
Parshiv Luthra
Are you a JVC Camera Expert? Answer questions, earn points and help others
