Question about Xerox DocuColor 12 Printer
System fault turn off and on
Just will not print any more what do i need to print some work
What is the deal on this DC12 wich fiery and or splash are you using? Can you ping the ip address on the Fiery? Give us more info
Posted on Jul 10, 2008
My Emerson TV is a 2014 model number lf32em5f the TV works fine but every time I turn the TV on the volume will go to 0 and I turn it up and it will turn back down to 0 by itself any help please.
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/
Nov 25, 2016 | Emerson Televison & Video
Air bag light is on
The srs system has a possible fault or failure
No different than any other dash light that stays
on after the motor is running
Check for codes & diagnose the system with the fault
Same routine since 1981 some 33 year now-- nothing new there
Air Bag is most likely turned off-- until the system is repaired
Do you not own or read an owners manual, or study vehicle systems
on the internet?
All the answers are in thousands of places, for decades, on the
internet ,already in print & video
Jul 16, 2014 | 2006 Kia Optima
The picture turns green for a few seconds then goes back to normal
Hi. If it's not a picturetube (internal) fault, you may look for bad soldering joints on the printed circuit board, located at the tube.
This contains mostly the RGB amplifiers. A bad soldering on the one driving the "green" cathode, may cause such problems. It can easily be detected by gently knocking on the latter. Also look at the actual CRT socket solderings.
It is most unlikely that the fault is located in the colour decoder. Faults there mostly influence red and blue. In a PAL system, only red and blue are transmitted. Green is produced by a matrix.
Finally, in the worst case there is an internal fault in the picture tube itself. Usually, the discolouring is very bright, shows retrace lines across, and even makes the system shut down due to excessive beam-current. good luck.
Apr 13, 2014 | ESA ET427E 27" TV
I dont know how to print from my computor it is working as if it is printing but the page is blank and there are 4 buttons on th e printer with symbols
if the page is being received it will print. if the content on the page is missing that would mean a fault with the toner/ink supply has occured. try new cartridges. the drum may have failed if you have a toner system. the laser that generates the image may be at fault. a number of things can go wrong. try always include make and model.
Apr 05, 2010 | Office Equipment & Supplies
Job automatically stops
It might be easiest to reset the printing system and then add your printer(s) again. It may be that you have something stuck in the printer queue that is causing the problem.
To reset the printing system in OS X 10.5.x, open the Print & Fax System Preference. Control-click (right-click) in the list of printers on the left side. Choose the option to reset the printing system. You will need to add your printer again after you reset the printing system.
Another possibility is that you may need to reset something from the printer's control panel. The printer may be rejecting your jobs until fault from the previous job is cleared.
Aug 07, 2009 | HP C3180 All-In-One InkJet Printer
My photosmart c5180 gives me the error code 0xc19a0021 and says ink system has failed. if i unplug it and restart it it will print for a few minutes until the error comes up again
The kind of error you are getting is due to fault in the ink and print section so you can clean the print head with soft tissue and install the cartridge properly and check the vent of it and now reset the printer by turning on and disconnecting by pressing power button for 20 seconds
and hopefully everything will work out it the problem persists then you might have to replace the print head
Thanks And Regards
May 12, 2009 | HP Photosmart C5180 All-In-One InkJet...
System fault 3-380
Remove and reinstall the print cartridge. If the error is still there you should replace the print cartridge.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=21,E=0000000001181489224,K=5792,Sxi=0,Case=obj(18087)
Jan 17, 2009 | Xerox DocuColor 12 Printer
System fault
Refer to the link i posted and put in you question in the box and that should give you a correct information as its the manufacturer.
May 13, 2008 | Xerox DocuColor 12 Printer
System Fault
9-357.
Black toner problem.Probably You have low toner sensor defect.
But try first to vacuum and clean black toner dispenser.You must vacuum whole path wich is used to transport black toner to developer unit.Then if printing B/W print only, you must print 10 full color sheets every 100 copies.
Jan 29, 2007 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Printer Logo
95 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
