Have 22 inch, when I connect a dvd player via av jack I can only get black and white picture
    Brigadier General:
  • 8,909 Answers
Look at the menu in the DVD player and set the video output to composite video, colour will return.
Hope that helps.
Posted on Dec 31, 2010
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
I set up my 42 inch Insignia plasma, turned it on for the first time (connected to a DVD player in AV mode) and can only get a black and white picture, no matter what I connect as an external source.
Make sure your dvd player is not in progressive scan mode if your using a/v mode. The best way is RGB component input, provided you have the cables.
Nov 27, 2010 | Insignia NS-P42Q10A Plasma TV
I have picture but no sound LG flatron TV and Pioneer DVD player.
connect audio output (RCA Jack white n red color) from the video, to the audio input of your TV. Make sure you use same AV channel for the video and audio.
i.e AV1 or AV2 or AV3
Apr 10, 2010 | LG Flatron MW-30LZ10 30" LCD Monitor
DVD connections have progressively grown darker and now have gone to totaly black and white. Television color and picture are completely normal.
If you are using the red,green and blue component inputs, check to make sure the red and blue ones are connected good and none of the jacks are loose. If not there is a problem with either the DVD player or the TV. Hard to say. Thanks
Oct 28, 2009 | JVC AV-27D203 27" TV
My sony portable dvd player stopped working. The
If the DVD is connected to the TV properly using the yellow, white & red AV cable and the TV is switched to AV and there is still no picture, plug the yellow lead from the back of the DVD player into the green socket. If you see a black and white picture now the DVD output is on Progressive Scan mode. See user manual to turn off Progressive Scan mode.
Aug 31, 2009 | Sony DVP-FX810 Portable DVD Player
Cant get color picture when playing DVD's
I too had the same problem. On the Vzio there are AV plug ins on the left side (not the back, but the left side). Use these jacks when connecting to the DVD player and choose the AV button on the TV remote. Viola!
May 27, 2009 | Sony Televison & Video
My componet/av only shows black and white on my vizio vp422
The 37" Vizio I just bought has a very confusing feature where the same input can be used as either the Y channel of the component or the full video channel for composite. If you plug a component source into the TV and then select the composite input ("AV" on the remote), you will see a black and white version of the full component signal (makes sense as the Y channel is just the luminance component). As sad as it is, I was stumped by this for a while until I happened to hit "COMP" and got full color. FWIW, the manual warns about this, but it really doesn't emphasize the point. I wonder how many returns they get because of this.
Mar 16, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
42 inch proscan lcd
If you use the connections for DVD you must use all of them.If you are using the standard yellow,white,and red connectors connect them to the connections listed as video and not the DVD titled connectors. But my advise is get an up converting DVD player and use a HDMI cable to get the best picture with out having to brake the bank buying a Blue Ray. I once connected a DVD player to my TV in the same fashion before finding out it only gives you a purplish black and white picture. Up converting DVD players can be bought around 30 dollars and up. A 6 ft HDMI cable will cost around 15 dollars. This way you will be getting the full effect and great picture your TV can produce.
Jan 31, 2009 | Proscan 42LA30H 42 in. LCD Television
Hi! name's wesley. anyways, here's the problem. i just bought a new samsung 32' lcd tv and everything is great except for one thing: when i connect my ps2 to the "av 2" input, the sound comes out...
There is a problem with the AV2 input. Since this is a new set, return it for repair or exchange. DO NOT open it up as that would void the warranty.
Dan
Jun 05, 2008 | Samsung Televison & Video
Sony dvp ns50p dvd player
If you are using the s-video jack to connect the DVD to the TV, the jack could be loose or the wire could be bad. The s-video cable has 2 signals, the black-and-white (luminance) and the color (chroma). If the chroma signal is not getting through, the picture will be in black and white.
Sep 01, 2007 | Sony DVP-NS50P DVD Player
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
