Question about RCA Televison & Video
Trying to program my remote but i can't manually turned tv on cuz the power button is broke. what options do i have?
    Brigadier General:
  • 8,909 Answers
You have answered your own question. Fix the power button and then you can set up your controller.
Posted on Dec 31, 2010
Trying to set DISH remote for an APEX LD4088. need the code please
Hello chiech22,
I noticed your post and see that your DISH remote needs to be programmed to your APEX TV. There are a couple of ways that your remote can be programmed to your TV. One option would be to use the remote code that is for your TV, these codes may vary depending on the model of your remote. The best option for you would be a Power Scan to get your remote programmed to your TV. Here are the steps.
1- While at the TV locations (TV1 or TV2 depending on which key is installed), point the remote at the TV. Press and hold the TV MODE button on the remote until all four MODE buttons at the top of the remote light up.
2- Press the RECEIVER POWER button on the remote.
3- Press the UP ARROW on the remote, about one press every two seconds. Stop as soon as the TV turns off. This process may take several minutes.
4- Press POUND (#) on the remote. The TV MODE button will flash three times.
5- Press TV POWER on the remote to turn on the TV. Press VOLUME on the remote to confirm the remote controls the TV. If this does not work, return to Step 1.
If you need any further assistance let us know. I hope this helps.
Jul 24, 2011 | DISH Network IR Remote Control
My remote will not turn the tv on or adjust the sound, it will change channels
First, try pressing TV on the remote, check if that solves the problem. Then press Sat and try the TV power button again. If the remote previously controlled the TV, you lost the code for the TV. If you have your Dish Network manual, check if you wrote down the code when it was originally programmed. Which specific remote/receiver do you have? The programming directions and code lists are available here: http://www.dishnetwork.com/supportsection/remote-setup . You can also scan all of the codes to find the correct one: see http://www.dishnetwork.com/SupportSection/power-scan-instructions . Additional remote/receiver manuals are here: http://www.dishnetwork.com/SupportSection/manuals .
The direct coding procedure for the Dish remote that I have is: while facing the TV to be controlled (after adjusting the key for TV1/TV2 in a multiple TV system), press and hold TV until all four indicators light up. Then enter the 3 digit code. Press and release the # key. Then see if the code TV powers off when you press Power. Then press Sat and check if the TV power button works. Try additional codes if the TV doesn't respond.
If you recently got a new TV and you tried to program the remote for your TV, your dish remote may not have the code you need. (Most universal remotes are limited to codes for devices released 6 months or more before the remote was programmed.) In that case, you should use the TV remote (and see if it has an option to control the satellite receiver). Alternatively, get a new universal remote that will control all of your devices. (The remotes that can be programmed by USB are the easiest to set up.)
I hope this helps.
Jul 09, 2011 | DISH Network IR Remote Control
I need step by step instructions to program the codes into my One For All universal remote URC-4220 to my JVC tv.
The code for a JVC TV is 0053 (non-combination TV). To program the remote, turn on the tv manually. Then press the TV button once. Then press and hold Set until the LED blinks twice. Then release Set. Aim the remote at the TV and enter the four digit code. The LED should blink twice again. Press the power button on the remote. The TV should turn off. Turn it back on and check if the remote does the other functions that it should for the TV.
There is a manual code search option. Press TV once, then press and hold Set until the LED blinks twice. Release Set and enter 9 - 9 - 1 . Then aim the remote at the TV and alternate between pressing Power and TV. When the TV turns off, press Set to save the code. Turn the TV back on and check if the remote performs other functions. If not, repeat the above steps until another code turns off the TV.
The manuals for All-for-One Remotes are available here: http://www.oneforall.com/support/manual . Choose universal remote control in the top drop down and then the URC-4220 in the second.
Please note that universal remotes only have codes for devices released 6 months of more before the remote was programmed. If your TV is newer than your TV, then you may need a newer remote.
I hope this helps.
Feb 12, 2011 | One For All URC4220 Remote Control
I need a code for one for all 8820 for tv toshiba
Try these codes: 1524, 0154, 0156, 1256, 1265, 0060, 0845, 1156, 0832, 0650, 1356, 1656, 1704, 1918, 1935, 1936, 1945 .
There is also a manual code search option. Turn on the TV and press the TV button on the remote. Then press and hold Set until the LED blinks twice. Then release Set and press 9 9 1 . Press the Power button then press CH+ repeatedly until the TV turns off. If you miss the TV turning off, press CH- to rewind the code. Then press Set.
One For All remote manuals are available here: http://www.oneforall.com/support/manual .
There is one issue to consider. The codes in the remote are limited to those for devices released 6 months or more before the remote was programmed. If your device is newer, then you may need a newer remote.
I hope this helps.
Jan 24, 2011 | One For All URC8820 Remote Control
We cannot get the remote to program with our sanyo tv
If you have tried all the codes and none of them work your last option is to try a PowerScan. Steps are below.
Step 1: Manually turn off the device you wish to program (TV, VCR, DVD)
Step 2: Press and hold the appropriate device key (TV, VCR, DVD) until the red LED illuminates. This indicates that the remote is in programming mode.
Step 3: Press and release the power button. The LED flashes once and stays ON. Indicating that the remote is in PowerScan mode.
Step 4: Press either CH+ or CH- button repeatedly until the device switches on. The CH+ button searches upward in the code list while the CH- button searches downward.
Step 5: When the device turns on, press and release the OK button to store the new code and exit.
NOTE: If you press the CH+ or CH- again after the device turns on, the device will not be programmed and you will need to repeat steps 1 - 5.
Step 6: Press any other operable button (VOL+ or VOL-). If the device responds, no further programming is required. If the device does not respond then repeat steps 1 - 5.
Dec 23, 2010 | Brookstone 538744 Remote Control
Cannot remember how to program remote
Turn the TV on, press and hold the CODE SEARCH or SETUP button until the light light comes on,then release, press TV button,the light will blink once and remain on, press and release the POWER button until the TV turns off, wait two seconds and keep press the POWER button until it turns off every two seconds,once it turns off press ENTER or SAVE...hope this was helpful...
Apr 21, 2010 | GE RM24970 Remote Control
Trying to program xbox360 universal remote. found
hey christy, to turn the tv on first push the desired device button like tv from the options tv,vcr,dvd etc. and then press the power button on..!!
it should work
Dec 14, 2009 | Microsoft Xbox 360 Universal Media Remote
Programing universal remote
Turn the TV ON. You can use the code search option by pressing Code until the LED flashes. Press the Power button until the TV turns off. Then press Enter.
Jan 20, 2008 | Televison & Video
Ilo tv.
my dog ate my remote and broke it and i just called an ordered a new remote from the # walmart extended service plan gave me the # is 800-216-5156 they need the model # and or serial # and the remote only cost me 14.99 plus shipping hope that helps!!!
May 01, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
22 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
