Question about Intel D845GVSR Motherboard
ON MOTHERBOARD PROCESSOR
I AM not getting boot no fans are working although power supply is checked
1.replace a new fan.
2.check the power supply.
Posted on Jul 18, 2008
Asus P5NT motherboard - will not boot to bios
The voltage output onto the three main rails as you put it is 12 volts and 5 volts. As you say that there is no beeping, you must be getting power lights and fan spin up. This would indicate a failed graphics card. I may am only going on the information you have supplied. Although if there is no lights or fans it may be a failed psu. You also don't identify your PSU. if you have the one that came with the tower, it isn't surprising.
Sep 05, 2012 | ASUS P5NT Deluxe Motherboard and Intel...
Cant get computer to
Disconnect everything from the motherboard except the power supply, CPU and power switch.
Turn on the computer. You should hear 3 beeps because you removed the memory.
If you don't hear any beeps, check the power supply. Check all the connections. Did you connect the 4 pin power? Did you skimp on it? A common mistake is to get a cheap, high-power supply. Just because the box says it's 1000 WATTs doesn't mean that will carry a steady load.
Still nothing...
It's either a bad motherboard or processor. If you have another processor that is supported on that board and you know it works, try it. If it boots return your CPU for a good one.
Unfortunatly, if it doesn't boot with a known-good processor that just proves the board is bad; it doesn't prove your CPU is good. You may have more issues.
Mar 08, 2010 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
I have a problem with Intel D845GVSR Motherboard with 2.0 GHz processor. When I power the M/B, only the Motherboard LED is on, but no boot, no cpu fan running. No beep code also. I check the SMPS, RAM,...
Think this should be an issue with the power button, Remove the wires running from the power button to MB and try starting the system with shorting the 2 lead of the power button..
Mostly, it can be due to bad power supply or Ram
Rate this solution
RNJ VINODKUMAR
Sep 26, 2009 | Intel D845GVSR Motherboard
I have a pc w/ asus k8v-mx mobo, the problem is it
scan for virus, if it is not a virus change the power supply unit.
Aug 14, 2009 | ASUS K8V-MX Motherboard
Power pack fan not booting but there is power on motherboard
Do you mean the power supply fan or the processor fan? Of the assemblies in a desktop, the power supply is the least reliable and the internal fan the most unreliable part. Since a failed fan can allow other parts of the supply to degrade, I recommend replacing the supply, not just the fan.
In eMachines, these are standard form factor (ATX) supplies so you would only need to order the same or higher power rating to have it compatible with your case.
Jul 23, 2009 | E-Machines eMachines Desktop PC
POWER LED ON BOARD SHOWS THAT IT IS ON BUT SYSTEM DOES NOT BOOTS
Hi...
If that problem is happen check the monitor cable if it is correctly plug to the motherboard, if your motherboard have video card attach try to remove the video card, if the same things happen thee problem is the processor, you need to check the processor, remove it and clean then put a thermal paste so that the heat from processor will absorb by the heatsink, and be sure that the heatsink fan it working to prevent the heat.
Good luck !!!
Regards
PCmania
Jul 10, 2009 | Intel Desktop Board D815EEA2 Universal...
Not booting up
try changing your memory or your processor. you might get a result
Jun 11, 2009 | EliteGroup ECS L4VXA2 (CDL4VXA2)...
Not booting but RAM,processor,SMPS ,HD are fine.
Check without Video Card, Processor , Memory and beeps are coming
If no then this is motherboar issue, I had the similar problem. So went to the local repair shop and got the power capacitors replaced,
Jan 29, 2009 | Asrock P4i65GV Motherboard
Power to the mobo
Without having the specs on the motherboard or knowing how old it is, it's difficult to say if it is beyond repair. Although my experience with computers shutting down that quickly while attempting to boot have been a problem related to processor overheating. Processors get very hot within seconds of powering on. If the processor cooling fan or the thermal paste is not working as intended the system will shut down quickly. You may want to check those two possibilities before purchasing a new motherboard.
Nov 19, 2008 | FIC AM 37 Motherboard
Power supply
fan o. k
get the eq wit a bootable win. disc and run into the bios for a new set in xp
Oct 15, 2007 | Gateway (4000484) Motherboard
Intel D845GVSR Motherboard Logo
23 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
