Question about HP ScanJet 2400 Flatbed Scanner
Scanner problem The scanner boarb is not moving hence scanner can't scan.
  • 813 Answers
Hi firend
u have to take it your nerest serivce center if try to open at your home its may be broke or has been damged so u can take good repair of scanner
thnx using fixya
Posted on Jul 08, 2008
WHAT IS LASER WHAT IS SCANNER INSIDE HP LASERJET 5035
The scanner is a small mirror that rotates at high speed, allowing the laser beam to scan, hence the laser whining.
Feb 12, 2015 | HP Office Equipment & Supplies
Scanner not working
The scanning driver is for old OS, hence its not compatible with win 7.
Please click here to know and fix the scanning feature with Window 7 operating system.
Regards,
Riztech
Mar 26, 2010 | HP PSC 1315 All-In-One InkJet Printer
The scanner is not scanning in photo scan mode and
that's hardware related problem, you need to open the machine and lubricate all moving parts specially in bulb image receiver side.
Feb 08, 2010 | HP ScanJet 2400 Flatbed Scanner
My Visioneer 8650 flatbed scanner with auto document feed gives a message when I try to scan a document, telling me to move the switch on the bottom from the "locked" to "unlocked" position. The lock is...
Actually a very common problem. Try the following:
1. Power down then re-power up the scanner.
2. Try slightly moving scanner. Sometimes a small change works to fix.
3. Change one of your scan setting to flatbed scan (not adf). Do a test scan under this setting. This will usually kick start scanner unit to unlock.
4. Last resort, by does also work...give it a medium slap on the side, sometimes unjams the scanner light.
5. Super last resort, power down over night, it almost always works the next day. (could be that lock up is heat related to scan lamp, dont know but just a guess).
Excellent scanner, so worth the effort to try these fixes.
May 22, 2009 | Office Equipment & Supplies
I have a new DR-5010C scanner. I used to use the
I havent used Canon 2580C and hence cant comment on Scan Panel. But you can download SU5000 or Captureperfect 2.0 from Canon website (http://software.canon-europe.com/). This is easy to use and probably offers more features as compared to ScanPanel. Canon 5010C is a higher model as compared to 2589C and Captureperfect may offer better user interface.
S. Mohan. Chennai, India
Mar 19, 2009 | Canon DR-5010C Scanner
Fujitsu fi-4120C2 scanner
There are two generally components for a scanner to work, One the Hardware Driver, which connects to the Comp and Two, a program to scan using the hardware connected. Sometimes, both may be available in the same program. For example, after installing the Device Driver, you can use any scanning program, to scan. Hence please check if you have loaded the Device Driver. You may be just using the scanning software, whcih is not able to detect the device!
S. Mohan, Chennai, India
Jan 20, 2009 | Fujitsu ScanPartner fi-4120C2 Path-Through...
Scanner not working
if you go to this site http://driverscollection.com/?H=3300U&By=ACER then click on the blue link that says download acer 3300u flatbed scanners driver. it will bring up another page where you will be asked to enter a code from the image shown, then you will be able to download the driver
I hope this helps
Jan 07, 2009 | Acer Scan to Web 3300U Flatbed Scanner
Fujitsu fi-4530C
Hi
F at power on is a ROM Error. sounds like a main board issue. check for dry joints, but may need the whole board replacing.
Sep 04, 2008 | Fujitsu fi-4530C Pass-Through Scanner
Blank Pages
The scanner's paper sensor may be jammed. IT is sensint there is paper and hence scanning!. Try and fix it. Sensor may be optical or mechanical. If optical remove shreds of paper or dust. If mechanical ensure it moves forward and backward.
S. Mohan. Chennai
May 09, 2008 | Fujitsu fi-5750C Flatbed Scanner
HP ScanJet 2400 Flatbed Scanner Logo
126 people viewed this question
Seeker5211
Seeker5211
