Question about Minolta DiALTA Di350 Laser Printer
Machine trouble c0501 - Minolta DiALTA Di350 Laser Printer
  • Minolta Master
  • 6,696 Answers
First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Feb 22, 2015
HOW TO SOLVE ERROR CODE C0500 FOR KONICA MINOLTA 211
Error code C0500 and C0501 means Fixing unit's temperature abnormality.
How to reset these codes?
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
http://servicekonicaminolta.blogspot.com/2012/03/error-code-c0500-and-c0501.html
Jun 14, 2017 | Konica Minolta Office Equipment & Supplies
Reset c0500
Aug 08, 2016 | Office Equipment & Supplies
C0500
May 01, 2014 | Minolta Di3510f Bizhub Copier
Will not run
MAINTANANCE CALL (M2)
Jan 24, 2014 | Minolta Bizhub Di1811p Copier
C0501
The 501 code is not for bizhub 350 is for dialta 250/350/2510 and refer to fusing unit error.
Dec 16, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
ERORR C0500
Sep 26, 2013 | Konica Minolta Office Equipment & Supplies
C0501
turn off the machine, press the stop button, turn the machine ON, and keep the "STOP" button pressed, C0501 error code will reset in few moments...............
Aug 03, 2010 | Konica Minolta bizhub 180 All-In-One...
My bizhub has an error code of C0501
C0501 it is a trouble related with the Fusing Unit. Try to power it up with the STOP button pressed. If not, you may need to change your fusing unit.
Jul 23, 2009 | Konica Minolta bizhub 180 All-In-One...
Minolta DiALTA Di350 Laser Printer Logo
52 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
