I have power to the wall unit but not to the external unit. I have a Kelvinator split system KSR 27G
  • 17,129 Answers
The power to the outdoor unit comes from the main unit inside where the main controller is in place. the relay drive to the compressor of the outside unit is switched ON from the wall unit. So the main board must be checked to see if the porcesor works and triggers the drive relay, if so the relay contacts or the relay can be faulty.
Wishing you a happy New year.
Posted on Dec 31, 2010
How to remove unit rfrom wall
The split system indoor unit is generally hooked on a bracket screwed to the wall. First you must cut power to the unit, Second you must evacuate the gas from the external unit using environmental approved tools. Then you remove the indoor unit by lifting about 5cm (2 inches in the old imperial system) and pull away as much as you can, about 10cm or so. At this point you can disconnect the 2 copper pipes from the external unit and the mains wiring. Richard.
Dec 19, 2015 | Heating & Cooling
I have a kelvinator ksr25f split system.The green light on the front panel flashes when the unit is turned on.The unit cools ok and when the temp is cool enough the outside unit stops as normal but doesnt...
Check and make sure the outside fan is running. The KSR series Kelvinators were rebadged LG units. It is possible the 6uf fan capacitor on the outside unit has failed.
Mar 04, 2014 | Heating & Cooling
Air con dead
Larger split system air con gets power from the external unit while smaller air con gets power from the internal unit. Can you find any power switch or power socket/plug around the external or internal units?
Nov 19, 2013 | Cell Phones
Hi, i have kelvinator split system in my house.but...
Sounds like a clogged drain pan. You will need to have the unit professionally cleaned.
Hope this helps I take the time to answer your question so please rate me
May 19, 2010 | GE Zoneline AZ38H12DAD Split System Air...
The air conditioner unit is not coming on. had message to change batteries in wall control changed batteries but unit will not come on Kelvinator DS3BC
Hi, Have you checked to see if there is power to this unit? I have not looked up the type of system you have, wall/window unit, central split system and so on. If the thermostat display said weak batteries and you installed them, it should start if it is programmed properly. If it is, the next step is to determine if it has power. If it does and will not start, we need to troubleshoot further into it. Get back to me on this. Let me know the type system you have. Thank you,
Shastalaker7
May 08, 2010 | Heating & Cooling
Hello im trying to trouble shoot two split systems the electrical wires were crossed for the two units I fixed it the compressors wont come on, wall unit says e7? This is on the Amcoraire ac split systems.
E7 indicates an "External Feedback Problem" which sounds like a communication problem. I believe there is a sensor cable that runs from the outdoor unit to the indoor unit also. Check that all cables are properly run to the appropriate unit and check all connections for tightness. Here is the link to a manual that includes installation and wiring instructions.
http://www.acwholesalers.com/EasyEditor/assets/amcor%20duo%20uchw-h12%20owners%20manual.pdf
Mar 16, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Remot control not working for this unit
change batterys if not working contact tech support from kelvinator
Feb 26, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Kelvinator split system a/cond
An air handler comes with a low, medium, and high speed wire taps and can only be set through these taps.
Oct 16, 2008 | Heating & Cooling
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
