Question about HP Mini 1000 Netbook
I just got an hp mini from japan so i was trying to reinstall new OS after turning it on so as to go change the boot order and restarting it the screen does not come again and i waited for a very long time to see if it will come but no and i took off the power supply and battery, pressed on the power supply for 30 - 60 seconds and putting the power cord back and putting it on it didnot work
    Sergeant:
  • 223 Answers
I think you still have select your booting device is CD drive , change your booting drive option to Hard disk , if you can remove cmos battery once and place it , so that old data will be erased on PC memory and proced to your new OS.
GOOD LUCK
Posted on Dec 31, 2010
  • 1 more comment
  • papi_larry23 Jan 02, 2011
    thanks for ur help but nothing comes on the screen (dark) so how do i change boot order
  • balaji n
    balaji n Jan 03, 2011
    just check this tutorial to change your booting order, copy and paste in your browserhttp://helpdeskgeek.com/how-to/change-bo... .
    Good luck
  • balaji n
    just check this tutorial to change your booting order, copy and paste in your browserhttp://helpdeskgeek.com/how-to/change-bo... . Good luck
Hp mini bootmgr missing
First goto BIOS and check if the order of boot devices is correct. It should be HDD as first option to boot. Change the same and save and exit BIOS. This should help you boot. If not, you You can create a bootage USB and set your system to boot from the same as an alternate option. Once booted repair your OS.
Jan 17, 2014 | Computers & Internet
Computer wont start or boot up cursor line on top blinks please help ?
Your computer can't find the OS on your hard drive. Most likely the boot sector has been damaged (or someone reformatted the drive). The entire hard disc may have failed.
Since this is a netbook, you will either need an external optical drive (USB) and a copy of the OS to boot from or a USB flash drive that has been prepared as a boot version of the OS. HP offers the Mini 5101 with WinXP Home, SUSE Linux or FreeDos. There may be newer versions with other OS options. Make sure to get the correct OS, even if you upgraded it.
You will need to boot to the optical drive or the flash drive. On other computers, this may involve accessing the BIOS to change the boot order. Look for a splash screen with the key information. Then turn off the computer and turn it back on while repeatedly pressing the key. (F1, Esc, Del, and F10 are common keys.) If you miss the timing, turn off the computer and try again.
If you are using XP, you will need to enter the Recovery Console. Then enter the command line mode. If your command prompt starts with any character other than C. Type C: then press Enter. Next type CD WINDOWS. Then try the BOOTCFG /REBUILD and see if a Windows OS is found. (type the command in and then press enter). Then type in the command FIXBOOT. This repairs the boot sector. You will need to confirm the commands. Type CD .. and CHKDSK /R /F to check for and fix damaged hard drive areas
If this worked, type EXIT. Try rebooting the computer. Otherwise use the command FIXMBR and then exit. Enter the HP recovery program (on the original hard disc or on Recovery discs, if you made them). Restore the computer to the original configuration with that program. If you ever did anything to repartition the hard drive, the recovery partition may not be accessible. You will lose any stored files and need to reinstall any programs you added to the netbook.
I hope this helps. Please note: losing this part of the hard drive may indicate that you have a failing hard disc. You will need to decide if you want to replace the drive or the netbook. If you decide to replace the hard drive, match the original drive size and data/power specifications (2.5" drive and SATA cable, probably). Use a USB/SATA/IDE hard drive adapter and a cloning software either added to the hard drive or from an optical disc to transfer the OS to the new drive and then set it as the boot drive before installing it in the netbook.
Sep 22, 2012 | HP Mini 5101 Netbook - HEWLETT PACKARD...
PC boot problem
Hi Jimmy,
Does the PC load windows fully before restarting?
If it does load and then restart,then it may be a problem on the part of your hard drive.
Run a full scan of the PC with an updated anti-virus to rid off any viral attacks.Make sure the anti-virus is always updated for better performance.
If it does not load windows,try this:-
  • Restart the PC.
  • Before it loads the first page,press Ctrl,Alt and Del.This is a soft boot sequence.
  • The booting leads you to the Bios setup page.
  • Under file save changes and exit[though no changes made].
  • If problem not solved repeat the procedure again.
If the problem persists,you may have to reinstall the operating system again.
Hope this helps.Thanks!
Nov 05, 2011 | HP 2133-1 Mini-Note PC
Hp mini 311 stuck in start up mode says "windows xp" over and over and then it goes to black and then starts up again with xp. I have turned off, taken battery out, tried to go into safe mode,...
boot it with the windows XP CD and reinstall windows. hit the 'r' key the second time it appears on the screen when it says that it has found an existing OS in 'c' drive, this will reinstall the OS without loosing any previous data.
Jul 01, 2011 | HP Mini 1000 Netbook
I have an Hp mini netbook with windows 7 starter os i am trying to get to the boot options to run a dif os off of my usb drive exactly how do i do that
when it is turning up before the boot loader starts there are going to be some directions how to get to the setup menu, usually is esc of F4 or F10 or something else, there you will have to get to boot options then you will have to set the boot order in order to boot from the usb
Jun 03, 2011 | HP Computers & Internet
Hp mini 110 started with a hp symble and f9=change boot device order f10 bios setup options. after a few minites screan said reboot and select proper boot device or insert boot mediain selected boot...
The hard drive is not being recognized as a bootable device- you will need to reinstall windows or replace the hard drive in order to resolve this issue
Oct 02, 2010 | HP Mini 110-1037NR Netbook
Hp mini 1116nr won't boot at all - tried booting from flash drive get disk i/o error - what to do
Repair the OS using external cd/dvd drive connect ted via USB, Change boot order to usb drive on the first boot priority.Follow the instruction
Good luck
Apr 09, 2010 | HP Mini 1000 Netbook
I want to reset the settings on my hp mini to its factory settings.
Hello try to download the files on another computer running a Windows operating system and restore your
device, follow these steps:
1. From your computer, go to http://www.hpmini.com and download the
HP MIE Restore Image Creator utility and the HP Mini MIE recovery image.
2. Insert a USB flash drive into a USB port on the computer.
3. Launch the HP MIE Restore Image Creator utility from the Start menu.
4. Click the Browse button and select the HP Mini MIE recovery image.
– or –
Select HP Netbook Recovery Image to download the latest HP Mini MIE recovery image from
http://www.hpmini.com.
5. Click Start.
6. When the process is complete, remove the USB flash drive.
7. Insert the USB flash drive into a USB port on your HP MINI.
8. Change the boot order by turning on or restarting the device, and then pressing f9 while the “F9 =
Change Boot Device Order” message is displayed in the lower-left corner of the screen.
9. Use the arrow keys to select the USB flash drive, and then press enter.
10. Press enter again to begin restoring the device.
11. Follow the on-screen instructions to install the operating system and programs.
12. After the operating system and programs are installed, remove the USB flash drive(the device will automatically restart)
13. Restore your personal files and you are done
Good luck
Jan 20, 2010 | HP Computers & Internet
Turn the computer on no matter which button i push
You may have a defective keyboard. A defective keyboard will stop the boot up process. Try another keyboard and see if that fixes your problem.
Oct 09, 2009 | Computers & Internet
HP Mini 1000 Netbook Logo
63 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
