Question about Razor MX350 DIRT ROCKET - BLUE
Have a Razor MX 350 little older model 2008 sat for awhile. Charged battery went well lift rear end tire spins really fast but when my son sits on it it starts to move then cuts off like if theres an overload he weighs 85 pds so way below weight limit ??? any ideas i only see throttle , control mod and motor i think it might be the motor when load is place but dont know check all connects and looks good its been garaged so nothing damaged by weather .. HELP ??? THANKS
  • 53 Answers
I agree with bmb_az.
Batteries may seem OK simply by measuring the voltage or by the charger indicating they are charged BUT you need to put a load on the batteries and monitor the voltage to confirm if they are OK. If the voltage drops under load then it is most likely the batteries have very little capacity left and need replacing. You can take them into a battery shop and have them load tested, most places do this for free.
A drop in voltage under load can also be caused by a bad connection between the cells, fuse or switch.
Posted on Oct 24, 2013
    Problem Solver:
  • 7 Answers
I'm having the same issue.. I checked my battery..seems fine.. my daughter weighs 35lbs..lol.. when I twist the throttle down barely..I hear almost an air like sound coming from the motor its very odd to me.. all connections look new.. sat in my attic over the winter..ran fine before..the bike is pristine..no ideas why it won't go.
Posted on Sep 24, 2011
  • bmb_az Sep 25, 2011
    batteries where the issue even if they show charged
Did you ever find out what the problem was?
Posted on Feb 06, 2011
    batteries where bad even if they should fully charged
The chain of my son razormx350 is runing backwards, how can I fix it?
Try connecting the red wire to the + battery post and the black to the - post.
Sep 26, 2015 | Razor Dirt Rocket MX 350 Electric...
I bought a razor rocket motocycle when my 51 pound daughter sits on it it won't go the minute I lift back wheel off ground it spins untill I sit it down again? Battery charged for 5 hours
you may find that the motocycle isnt suited to the weight ratio of your daughter check the manual it usually tells you in the small print says not suited for ?
May 04, 2014 | Cars & Trucks
Razor mx350
Have you tried removing plastic chain guard and making sure chain is not off track i had this problem and that is all it was.
Apr 24, 2014 | Razor MX350 DIRT ROCKET - BLUE
We have charged the battery and even bought a new one, the gator still doesn't turn on at all. It's like it just died.
It sounds like you might have a bad motor, try it in all of the gears and if one tire spins in the rear but not the others, then you probably have a bad or disconnected motor, let me knwo what you find out, i can get you a new motor if you need one
Jun 25, 2012 | Toys
I was given a mx350 that has been sitting in a garage for a year I charged it for 8 hours but it does nothing the light comes on to show it has power but when i turn the throttle nothing no sound or...
If it was working before it sat, then it is almost certainly the battery (these kinds of batteries suffer if sitting and not fully charged). If you had one, or could borrow a voltmeter, you could check the batt. Also, lots of car part places like NAPA can test batteries for you.
Hope that helps
Jul 18, 2011 | Razor MX350 DIRT ROCKET - BLUE
Jumped the battery after car sat for awhile then
If you dont use the car it still use the battery so sounds like you need do slow trikle charge on the battrie. If that dosent work you might killed the battrie off. i dont this many time if not use it die fast.
Jul 29, 2009 | 1999 Buick Century
After sitting in driveway, back wheels have completely locked up.
Chock the front tires, loosen up the lug nutes on the rear tires, jack the rear end up, uncap the adjuster dust caps on the back of the rear drums, either use a brake spoon or straight blade screwdriver and turn the star adjuster while spinning the wheel until you have no resistance. If this does not work remove the rear tires and hit the sides of the drums with a small sledge hammer or hammer to loosen & break up the rust, When you get movement on the drum, hit it betweeen the studs. Be patient, this may take some time.
Jun 20, 2009 | 1998 Dodge Caravan
Razor MX350 DIRT ROCKET - BLUE Logo
631 people viewed this question
Top Razor Cycling Experts
Ted Maxwell
ray gallant
wayne-m
Are you a Razor Cycling Expert? Answer questions, earn points and help others
