Question about Ovens
Electrolux 30" electric double oven
    Problem Solver:
  • 13 Answers
Some oven elements are "plug-in" style, held in place with spring clips, It is possible that they have dislodged during cleaning. Good luck, Rob
Posted on Jan 01, 2011
Top part of oven not heating up
Thank you for your post, friend!
Based off what you have described your Electrolux double wall oven is not heating up inside the top portion. It could be a miscommunication within your oven and you can usually perform a reset to clear that out. In order to reset your oven you would need to flip the household circuit breaker off for roughly ten minutes. If you restore power and continue you having an issue with your oven I would suggest you could have a possible fault with the control panel, thermostat, element, or connectors. Typically, this is not a simple DIY job. You may need to look for assistance with replacing any electrical components and I would highly suggest having a professional technician help with that. Hope this is helpful. -Matt
Feb 23, 2015 | Electrolux 30" Built-In Double Electric...
WE HAVE AN ELECTROLUX DD060GA DOUBLE OVEN THE TOP OVEN IS WORKING BUT THE BOTTOM OVEN DOESN`T EVEN COME ON WHEN YOU TURN THE KNOB THERES NO GAS AND NO SPARK AND THE LIGHT WONT COME ON EITHER, CAN YOU...
Good Morning Friend,
I understand that your Electrolux double oven, model# DD060GA, is having trouble with the bottom oven coming on. I also see that your top oven works just fine. This appears to be a UK Electrolux double oven. I suggest contacting the manufacturer directly. They will be able to better assist you in getting your bottom oven functioning correctly.
-Best Regards-
WP
May 21, 2014 | Electrolux EOG7330WN Gas Double Oven
Tried to clean single Electrolux wall oven. The cycle began, the door locked and then the oven shut down with the door locked. I shut off the breaker for 10 minutes and then back on, no change. I checked...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jan 20, 2011 | Electrolux ICON 30 in. Double Wall Oven
After cleaning the top half oven with a self-clean cycle the oven will not pre heat past 100 degrees. The bottom oven will heat. What might be causing the top to malfunction? The serial number is...
usually it is the thermal cut off( TCO) ,a kind of themal fuse which goes out if the temp exceeds certain limit and cuts off the power to the elemnts.it is to protect the cavity from over heating.it needs to replaced or reset depending the model. u will need a tech to fix this.
Aug 21, 2009 | Electrolux Ovens
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
Ovens Logo
97 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
