I have remote controller manual but the conditioner lcd says - E1 what do I do ?
  • 2,133 Answers
E-1 Indoor unit return air sensor fault. Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace sensor. Helpful?
Posted on Dec 31, 2010
Haier air conditioner won't run displaying code e1? Do not have remote.
This is the error code.
E1 = Room temperature sensor fault Indoor unit
Even if u had the remote you still have a bad sensor.
AC Repair Delray Beach
Sep 03, 2014 | Haier Heating & Cooling
Ac unit
If the panel remains inoperable to control the buttons, you can just use the air conditioner remote to operate the air conditioner. The unit will still read the remote settings and allow you to operate it without a new panel or temperature sensor. The error code will still appear, but the air conditioner will function normally. 6_15_2013_8_05_15_pm.png
Jun 13, 2013 | Heating & Cooling
What to do to fix the E1 error on a haier her08xc7
Push buttons about five times each beforjust to make sure they are not stuck....then......Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset. Clean the filter. See the Care and Cleaning section in your use and care manual. After cleaning, replace the filter and plug the air conditioner back in.
Other forums say the E1 code is because the AC thinks a button is stuck or because it's dirty, but almost all of them say to use the remote and it'll work ok.
Jul 23, 2012 | Haier HWR08XC7 Air Conditioner
Dometic model 3313192 thermostat error code E1 what does this mean?
Hi By E1 error it means
Loss of communication between the Single Zone LCD thermostat and the module board. LCD will cycle between E1 error.
Check the link for regular maintenance Of the LCD thermostat.
If it doesn't help then you have to replace the LCD thermostat.
Ajin
http://www.google.com/url?sa=t&rct=j&q=dometic%20model%203313192%20&source=web&cd=1&ved=0CCwQFjAA&url=http%3A%2F%2Fmanuals.heartlandowners.org%2FHeating-Cooling%2FA-C_Units%2FDometic%2FDometic_Single_Zone_LCD_Thermostat_Operating_Instructions.pdf&ei=hOg0T7OUNIjkrAer4Ny6Dw&usg=AFQjCNEn2y9-ItUcF2KRJZ0dm0Ftrq8Jhw
Feb 09, 2012 | Dometic Rooftop RV Air Conditioner
My power went out after the power came back on my air conditioner reads e1
E1 might be a stuck key on the keypad... they are sometimes flakey .. maybe water getting into the keypad ... at any rate the remote control usually still works .. eventually sometimes the key pad starts to work again (maybe when it dries out)
So, based on solutions from those other sites, I pulled off the front panel, turned it over and removed the 4 screws from the back of the control pad (not the six screws on the outer perimeter). I looked for a stuck button but did not find one. I just pushed all the buttons a few times in case one was stuck (as suggested on other sites) and that did it!
Hope helps.
Jun 11, 2011 | Haier ESA3109 WallWindow Air Conditioner
My new gree air conditioner split system has an E1 error
My greewall mounted has a e1 prblem.how van ifixor what is the problem
Feb 09, 2010 | Heating & Cooling
The error code E1 is lit on the front panel of room air conditioner. The instuction book is lost and I can't locate the model number. It says energy star and comfort touch and come with an remote...
E1 is refering to the air filter. If turning the unit off and unplugging doesn't reset it then you probably have a PC board or sensor failure. None of these units can actually detect a dirty air filter. All it does is set a timer that turns the E1 on after what the manufacture determines is average.
Hope that helps.........
Jul 28, 2008 | Sharp Heating & Cooling
E1 code
Use a universal remote (like the one for a TV) to turn on and to adjust settings. I was some what doubtful, but after trying my universal remote, my air conditioner started working.
Jun 18, 2008 | Sharp AF-S120MX Air Conditioner
Haier E!
E1 means one of the buttons on the touchpad is pressed in. The remote will still operate the unit. You might have to pull the panel of, and check all the buttons. If all seems fine replace the control board. might not be worth it thou..
Aug 08, 2007 | Haier HWC08XC1 Wall/Window Air Conditioner
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
