Question about Amana NAV2330AW Top Load Washer
My ignis washing machine stops in the middle of the washing cycle and makes a sound, kind of blowing.
  • Anonymous Mar 15, 2014
    noise
  • 3,267 Answers
There are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses.
The most common cause of a washing machine not taking any water in is either a kinked fill hose or the tap becoming faulty whereby you switch it on but the valve inside doesn't turn. Another common cause is the tap getting accidentally switched off and people not realising. Other causes can be wiring faults, water valve faults or programme control faults. This advice was originally written when most washing machines were hot and cold fill and didn't have error codes. It's now been updated to reflect the fact that these days the vast majority of washing machines are cold fill only and should give an error code if they can't take in water.
If your washing machine is stuck full of water the water needs to be drained out and this article gives tips on how to do this. If the entire washing machine has gone dead leaving the machine full of water it may be worth checking that it isn't something as simple as a blown fuse ( Washing machine is dead, wont start ) in which case if you get the washer going again it should pump the water out itself.
If the washing machine appears to be functioning normally but simply won't pump away the water then the possible causes (in the most likely order) are a blockage somewhere, a pump failure, or an electrical fault stopping the pump from running.
Blockages are the more likely explanation, but pumps can fail.
Posted on Dec 31, 2010
Ge washing machine/stopped in the middle of the drain cycle
sounds like your pump has got jammed with a coin or usually hair grip.
Sep 18, 2016 | GE Washing Machines
My ignis Bella 60 front load washing machine inner tub has developed sideways play . It rubs against sides during cycle with soft rubbing sound and stucks
at the back of the washing machine is an inspection plate not large
turn off the power and pull the plug from the wall and turn it from the rear and see what is happening
Mar 28, 2015 | Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
I have a bosch washing machine make is a exxcel 1200 express and it stops working in the middle of a cycle and the words f04 come up wot does that mean please
there may be a stuck in cycle of rotating knob kindly rotate the knob more than three times your problem will be sloved otherwise replce the mechanism
Dec 23, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Washer will stop in middle of cycle
The timer is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Washing Machines
Frigidaire washer machine stop in the middle of the cycle
Replace your lid switch.
The machine must have a goodd lid switch to continue timer functions after wash and rinse.
Feb 28, 2009 | Frigidaire FWS833A Top Load Washer
Amana NAV2330AW Top Load Washer Logo
249 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
