Question about Compaq Presario M2000 Notebook
Cannot Power On
Hi All,
Here i want help from you all who are expert. I have problem with my laptop M2000 Compaq. The problem is, my laptop cannot power on. when i plug in power adapter, power light on my laptop is on but when push on button, it doesn't work. i already sent my laptop to technician, but they told me to change the motherboard. they also don't know actually what happen to my laptop. for me, change a motherboard need high cost. then i sent to other person for repair. but he told me to change CMOS battery.please help what should i do for my laptop?? i don't want to losing my laptop cause it has something value.
  • lwyergirl Jul 14, 2008
    I'm having the exact same problem with my Compaq Presario M2000. Help!!
    Problem Solver:
  • 7 Answers
There is deffinetly a problem with the board, though it should be diagnosed at an authorised service station, the problem is they will nearly always replace your board. Here are a few things you can try that i have come accross on the Compaq: Swap the Memory Around and try to power on, then try them individually and try to power on. Plug in an external Monitor and try.
(Strangely this worked a few times for me)
If you can get to the Bios Battery test this, it should be near 3 volts. For other Diagnostics visit my site at www.powerjackrepair.com
Posted on Jul 11, 2008
  • 813 Answers
Hi firend
u take your laptop compny othorised service station he will guide u proper
thnx using fixya
Posted on Jul 08, 2008
Compaq M2000 turns on using charged laptop battery but doesn't charge or turn on when using power adaptor, with or without the laptop battery
1) The AC adapter should ALWAYS be plugged into the laptop FIRST, then plugged into AC power. If not, this could create a voltage spike.
2) Let's look at the DC Power Jack, for the Compaq Presario M2000 series of Notebook PC's,
http://www.notebookparts.com/products/description.php?II=9741
The DC Power Jack is mounted to a removable circuit board.
Enlarging the view of the jack, shows us there is an Inductor.
The small 'can' standing up on the power board. This chipset could have gone south. (Bad)
How to know? Replace it, or dig out your dual trace oscilloscope. See if the Inductor works.
Could also just be cracked solder joints, of the DC Power Jack, TO that small circuit board. Solution would be to resolder it/them.
[ I WOULD however, search for a BETTER price, than listed in the link above, IF available ]
DC Power Jack is in good shape, soldered tight to the motherboard, and ruled out as the problem?
(Since you know the AC adapter is good)
Then the problem would be the Inductor on that power board, or power correcting chipset.
What one is it? Dunno.
DO KNOW is has J leads on the bottom.
CAN give examples, and perhaps you can identify using them.
1) https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
2) http://www.utsource.net/ic-datasheet/KB926QFB1-1829416.html
Service Manual, (Free), for Compaq Presario M2000 series of Notebook PC's,
(Remember, follow Anti-Static Precautions. USE an ESD wrist strap, and connect it's alligator clip to a good ground source),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
Drop down to the line that begins with - Compaq Presario 1100.
(1100 in blue)
Scroll over, click on M2000. (In blue)
(Ignore if you are aware of the following;
PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name { M2000 }, it may take up to 30 seconds, before the first page comes up )
Compaq Presario M2000 series of Notebook PC's, disassembly guide,
http://www.insidemylaptop.com/take-apart-compaq-presario-m2000-notebook/
Regards,
joecoolvette
May 12, 2012 | Compaq Presario M2000 Notebook
Hi.. I have a Compaq Presario M2000. How do I turn on the wireless. Or does it even have that. It has a wireless symbol but it's not lit up. Thanks..
Yes, it has wireless and blue tooth. Simply download the owner manual of their website. Here is a link
http://search-manual-online.com/compaq-presario-v5000-notebook-manual.html
Apr 26, 2010 | Compaq Presario M2000 Notebook
Laptop will not start (compaq presario m2000)
Try removing the battery (which may be bad) and only have ac power connected.
RDO
Nov 17, 2008 | Compaq Presario M2000 Notebook
Presario m2000 no power
the same EXACT this happend to me! i didnt know what to do so i just a new charger at dell.com
Sep 12, 2008 | Compaq Presario M2000 Notebook
Compaq presario m2000 sound card
logon to compaq website search for your model and download sound drivers
Jul 15, 2008 | Compaq Presario M2000 Notebook
Entering COmpaq M2000 BIOS
you can simply remove the cmos battery then press the power button for atleast 20seconds then thats it if the date resets then the passwords as well ^^
Jun 11, 2008 | Compaq Presario M2000 Notebook
My m2000 cannot power on
sounds like your sound card or power card in laptop is back feeding into your computer and make it short or cu off only way youu can fix it is to change the suggest card's and i am sure it will work better ( got time call me and i will walk you threw getting it fixed ok linda lala linda lonely2linda@yahoo.com send me a email and i will send you my tel no. ok
Jun 03, 2008 | Compaq Presario M2000 Notebook
Compaq m2000 boot problem
i suggest you go to bios setup and restor the default if it continues try replacing a diff hard drive or dvd drive drive thats not the one u r using rigght now and i think the problem will be resolved cos i had a similar problem with presario c500 what i did was change the dvd drive n it work well.
hope this helps
thank u for using fixya
May 27, 2008 | Compaq Presario M2000 Notebook
Compaq M2000 beeps twice
Try powering it on without the battery in (with the power plugged in). Are the results different?
Dec 06, 2007 | Compaq Presario M2000 Notebook
Compaq Presario M2000 Notebook Logo
57 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
