Question about Roundup "" Weed & Grass Killer
How much roundup do i put in 3 liters of water
    Scholar:
  • 127 Answers
Round up is currently offered in a few variations. If you have the "Spray and GO" or the "Spray and Go" refill product do not add water. The ratio is already correct. Likewise for the "Redy-to-Use Plus", do not add water.
If you have the "Weed and Grass Killer Concentrate Plus", the ratio is 3oz/gallon water. 3 liters of water=0.79 gallons so use 2.4 oz of this type of Round Up.
If you have the "Weed and Grass Killer Super Concentrate", the ratio is 1.5oz/gallon water so you would use 1.2 oz of product mixed into 3 liters of water.
If you have a different product and just need to work out the conversion from gallons to liters, 1 gallon=3.78 liters.
Hope this helps.
Posted on Dec 31, 2010
Mixing ratio roundup
Don't really catch your question, but 30 ml per liter is a good strong ratio. Some labels tell you to mix less, but not all weeds die if a weaker solution is mixed. Some more hardy weeds will not even turn brown. Also check the active ingredient grams per liter Ours are 480g/L. It differs from country to country as well as other suppliers selling it under another name.
Oct 07, 2014 | Roundup Garden
I just want to know how much of roundup to put in the tank, you use air to disperse the weed killer?
Yes I do use it, you can put about 1qt of round up for every gallon of water. This should kill your weeds, for most precise mixing instructions check the bottle label.
Thanks.
Jul 28, 2011 | Roundup 2 Gallon Pro Garden Poly Tank Pump...
I need to know How much roundup per gallon of water. Also, can I mix Krovar with it and if so how much per gallon?
I use 3 oz. of Roundup to every gallon of water and it kills even the local star thistle. They can be used together with the Krovar ratio at 2.4 oz. per gallon.
Mar 27, 2011 | Roundup "" Weed & Grass Killer
Mixing roundup
i have a 9 liter sprayer, how much roundup do i add?
Jun 22, 2010 | Roundup "" Weed & Grass Killer
How much roundup to 1 gal water forwatering can use
6 fluid ounces of Roundup (12 tablespoons) per gallon of water. Small weed seedlings can be killed with half this strength: 3 ounces per gallon. When using Roundup Super Concentrate, mix 2.5 ounces (5 tbsp.) with a gallon of water to control most weeds and a half-strength solution for small weeds. Roundup Pro Concentrate is the strongest solution available. Spray a mixture of 2 ounces (4 tbsp.) on weeds and half that amount of concentrate on emerging plants. Since Roundup doesn't discriminate between weeds and other plants, use the least amount of herbicide possible to protect desirable vegetation.
May 29, 2010 | Roundup ScottsRoundUp 0394560 PT...
Need to know how to mix round up and water
Annual and perennial weeds can be controlled with a mixture of 6 fluid ounces of Roundup (12 tablespoons) per gallon of water. Small weed seedlings can be killed with half this strength: 3 ounces per gallon. When using Roundup Super Concentrate, mix 2.5 ounces (5 tbsp.) with a gallon of water to control most weeds and a half-strength solution for small weeds. Roundup Pro Concentrate is the strongest solution available. Spray a mixture of 2 ounces (4 tbsp.) on weeds and half that amount of concentrate on emerging plants. Since Roundup doesn't discriminate between weeds and other plants, use the least amount of herbicide possible to protect desirable vegetation.
May 27, 2010 | Roundup "" Weed & Grass Killer
How do i mix roundup concentrate plus
Roundup Concentrate Plus is the least concentrated mixable product Monsanto offers. Annual and perennial weeds can be controlled with a mixture of 6 fluid ounces of Roundup (12 tablespoons) per gallon of water. Small weed seedlings can be killed with half this strength: 3 ounces per gallon. When using Roundup Super Concentrate, mix 2.5 ounces (5 tbsp.) with a gallon of water to control most weeds and a half-strength solution for small weeds. Roundup Pro Concentrate is the strongest solution available. Spray a mixture of 2 ounces (4 tbsp.) on weeds and half that amount of concentrate on emerging plants. Since Roundup doesn't discriminate between weeds and other plants, use the least amount of herbicide possible to protect desirable vegetation.
May 25, 2010 | Roundup ScottsRoundUp 0394560 PT...
Proper mixture ratio for roundup weather max commercial grade.
2 ounces per gallon. you can convert gallons to liters on the net.
Apr 19, 2010 | Roundup "" Weed & Grass Killer
HOW MUCH ROUNDUP TO GALLON OF WATER
regular concentrate 6 fl. oz per gallon
super concentrate 2.5 fl oz per gallon
May 22, 2009 | Roundup "" Weed & Grass Killer
Roundup "" Weed & Grass Killer Logo
763 people viewed this question
Top Roundup Garden Experts
Nick Olsen
Mike
Are you a Roundup Garden Expert? Answer questions, earn points and help others
