Question about Mastercool 67471 Evaporative Cooler Air Conditioner
When ballcock stops the water flow water escapes through the 6mm hose to the dump valve overflowing no to the roof
  • 40 Answers
The 6mm hose is a bleed off hose and is meant to leak water out. the tap is to adjust the quantity. if you dont want any leaking out remove the hose from the dump valve and have it drop back into the tank
Posted on Apr 04, 2011
We have fitted a new ballcock on the watertank (cold) since then we have little cold water
Are you sure the ballcock is correctly adjusted to fill the tank to the required level? The float should have a screw on it which changes the height at which the valve is closed. if set too low you may not get enough head of water to feed the system. If set too high the tank will overflow.
This video deals with a toilet (WC) cistern but the principal is the same for any ballcock valve system.
How to adjust the cistern ballcock in your WC cistern get better flush
Apr 15, 2015 | Home
Manitowok ID0452A-161 water not draining one water tray is filled causing water to over flow into ice bin melting ice. Need to know where the float switch is and dump valve solenoid. FOR TROUBLESHOOTING
Remove side panel on left. Dump valve and drain hose usually blocked with silt, but may be dump valve coil open circuit. No float switch, water level sensor above tray.
Mar 04, 2014 | Manitowoc ID0452A-161 Dice Cube Air Cooled...
What do I do if the toilet continues to draw water and the water level on the fluidmaster 400 is properly set?
First is the water overflowing the overflow tube? This would indicate that the ballcock or flow master needs a seal or that it is rubbing the side of the tank (if it is rubbing the side of the tank twist it slightly). If the water level is always below the top of the tube but the flow master keeps on filling in bursts then you need to replace the flapper. Flappers will decompose slowly and black residue will come off to the touch. Wear gloves because this black will be on your hands for days. The flapper gets a slight ripple or curve that allows water to get by.
Nov 29, 2013 | Fluidmaster INC #B1F09 9" Faucet Connector
Hot water will not stop flowing. Hot water
Sounds like a bad shutoff solenoid. It operates the valve to let water in and then shut it off. There should be a valve behind the machine where the hose connects to the wall so you don't have to isolate hot water to the entire house.
Sep 18, 2017 | Bosch Axxis WFL 2060 Front Load Washer
Water keeps running, toilet not shutting off totally, tank will fill then we have to pull up float and hold it a while to stop water, doesn't overflow, just keeps running, doesn't shut off...
Hi snowjobs847...
Try resetting your float level to a lower water level in the tank, the extra pressure put on the seal may make it reseal.
If the above did not work:
You need to replace your "ballcock"...the ballcock (inlet valve) is non-repairable, has to be replaced with a new one if you cannot get it to stop leaking.
Please take time to rate me
Sep 04, 2011 | Home
Float is adjusted to the proper height but water continues to slowly rise until it reaches the overflow
Hi lucy edwards...
Change the inlet valve (ballcock) it is leaking and non-repairable
Once you replace your ballcock with a new one and set the water level that will solve your problem.
Aug 30, 2011 | VitrA Aria Toilet with Round Bowl /...
I installed a new ballcock assy and float. the toilet fills and shuts off but i can still hear an intermittant water flow. there were no instructions with the new valve so i dont know how to adjust.this is...
Without knowing what type of ballcock assembly you used I can't tell you how to adjust it. However there is one easy thing that you can check. If you have a plastic line going from the ballcock to fill/overflow in tank make sure that the bottom of that line is not below the water in the tank or it can create a siphon and make the water to run a small amount nostop. Hope this helps you. Have a good day and thank you.
Apr 30, 2011 | Home
Water is shooting straight up after flush, then it...
From the sound of your description. It could be the fill tube has come loose from the overflow tube or the ballcock valve has a bad gasket and may need to be replaced. I hope this helps.
May 19, 2010 | Home
Valve to stop water from running
IF YOU HAVE A FLUIDMASTER BALLCOCK,AND IF THE WATER IS CONTINUING TO RUN ,YOU NEED TO ADJUST THE WATER LEVEL,MOST OS THE TIME ALL YOU HAVE TO DO IS OPEN THE TANK LID AND ON THE LEFT SIDE YOU'LL SEE THE BALLCOCK,AT THE TOP IT MIGHT HAVE A BLACK PIECE THAT YOU CAN SLIDE UP AND DOWN TO ADJUST THE WATER LEVEL,OR SOME HAVE A PIECE THAT LOOKS LIKE YOU CAN USE A PHILLIPS HEADS SCREWDRIVER,ALL YOU HAVE TO DO IS TURN IT A HALF OF TURN EACH TIME UNTIL THE WATER STOPS GOING INTO THE OVERFLOW TUBE ,WHICH IS USUALLY LOCATED IN THE CENTER OF THE TANK AND IT WILLBE 1INCH ROUND ,IT ALSO WILL HAVE YOUR FLAPPER OR BALL CONNECTER TO IT.
Apr 07, 2010 | Toto Toilet Onepiece Ultramax ...
Keeps on runing
Either the flush valve needs to be adjusted so that the float is below the overflow tube, or your flapper is not sealing or getting stuck. The fill valve either has a float or a ballcock. On a ballcock there is a screw at the top of the fill valve that will lower the arm of the ballcock. On a float, a small clip connects to a rod next to the float, pinch and pull down to lower the float. There is a plastic screw at the very top for fine tuning.
Jun 29, 2009 | Toto Home
Mastercool 67471 Evaporative Cooler Air Conditioner Logo
205 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
acrman404a
Level 1 Expert
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
