Question about Cameras
I put in a memory card in but it don't work it says "write protect".
  • 10,865 Answers
Hello. Your card is locked. Remove it from the camera and look carefully around the edges of that card for a wee sliding lock device. Unlock it and reinsert it into the camera and then format it. J.
Posted on Dec 31, 2010
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
"Memory Card is write protected" so I can't take pictures.
remove memory card ... left or right side of memory you will see one little button slide the button down or up... this button is protected your memory..
May 28, 2013 | Nikon COOLPIX S6000 Digital Camera
Unwrite protect Micro SD card?
You have to be the computers administrator to change any values on any hard drive on your computer
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
click start click to open on my computer you should see your sd card drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your sd drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
Jun 22, 2012 | SanDisk 4GB microSD High Capacity Memory...
SD Card Problems with Vivitar Vivicam 5118!
What size is the memory card. If it's larger than 4GB then it won't work in the 5118.
Try using another card. Don't format it in your computer but do format it in the camera before trying to take pictures.
May 05, 2012 | Vivitar ViviCam Cameras
When i insert the memory card in my Kodak c143 east share then i displayed that " memory card is protected (reset switch on memory card)".
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 24, 2011 | Kodak EasyShare C143 Digital Camera
Camper says internal memory is full and i have only taken 12 pics. i think there might be "protected" pics. but i don't even know how to protect pics or to un protect them.
Digital cameras that come with internal memory usually have a very small amount of storage capacity (usually 32 or 64MB). I'm not sure why the manufacturers even bother with internal storage when you can get memory cards that have much more capacity. You need to either download the photos you've taken to your PC and then delete the photos so you can take more shots, or you need to insert a memory card. Depending on your model of camera you need a microSD or SD card. Let me know the model number of the camera and I will tell you what you need to get.
Hope this helps!
Tom
Jul 21, 2011 | Kodak Cameras
On my DMC-TZ8 the screen says "this memory card is write -protected " how do I solve this problem , only had camera two months I have took memory card out all seems alright THANKYOU
Your memory card is either write protected or corrupted.
  • If it's write protected, it can be very easily fixed.
  1. Turn off cam.
  2. Take out the mem. card. (it's probably located near the battery. press down on it and release it. Then it will pop out.)
  3. Slide the small switch on the side of the card to the position marked with an unlocked padlock.
  4. Put card back in and turn on cam.
  • If that doesn't seem to be the problem, then it's likely that the memory card is corrupted. This is common with Flash memory that has been used extensively for a long time and this problem is likely not caused by any fault in the camera. You might not be able to access any pictures that were stored on your cam, but you can try using a data recovery software like Recuva if you want to recover pictures ( click name to download ). If you want to use the card again, You can try formatting it (differs from cam to cam, check instructions manual for specific instructions) If this doesn't work, You will have to buy a new card. Make sure you buy a good brand like Lexar or SanDisk.
That's it. hope that helped.
May 02, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
"card protected " appears whenever i attempt a
Take the memory card out of your camera. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again. Then put the card back into the camera.
If that doesn't work, try another card.
Mar 14, 2011 | Sanyo Vpc-s1070w Digital Camera
How do I remove the "write Protect " from my Olympus camera? I must have pushed some buttons incorrectly and suddenly it shows that "write Protect " sign. I already tried removing...
Find the flash memory card that plugs into your camera and stores the pictures. It's usually behind a door or flap on the side or bottom. Remove the card, usually accomplished by pushing it in and then it should spring outward slightly -- at least enough for you to pull it out the rest of the way. Check the card for a tiny sliding tab on the side and move it to the opposite end of its travel. See this wikipedia article for pictures and more info about write-protection.
Dec 17, 2010 | Olympus Cameras
What does "memory card is write protected mean?" I can't take any pictures
when i turn on my nikon coolpix the screen says memory card is write protected what does that mean
Dec 07, 2008 | Nikon Cameras
The Camera is saying "protected Card" and wont let me take any pictures and wont let me un protect it how do i fix it?
Just solved by looking at the memory card itself......there's a switch on the actually memory card......click it & then put it back in the camera!!!!
Aug 22, 2008 | Cameras
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
