Question about Bose Companion 3 Computer Speakers
Have my system attached to my Samsung tv, but when volume is low can hear a ticking sound form both small speakers ?
    President:
  • 2,246 Answers
Ithink there is no problem,that's normal
Posted on Dec 31, 2010
Makes large thumping/chirping noise when turned on. Its not even connected to the receiver
Since you have said the speakers make this sound when "turned on", I'm going to assume there's some form of power amplifier attached (internal, external or otherwise). Based on the minimal information provided here, this simply sounds like the normal reaction of a speaker when the amplifier is turned on. In short, an audio speaker is a type of "transducer" and when power is applied (thru some form of amplifier), the cone reacts to the power surge and causes a thump, pop or other noise. Turn on your TV for example and you'll usually hear a small pop from the speakers...and a larger/more powerful amplifier is likely to make a louder noise. Without further information, in most cases this is quite normal.
Assuming there is an external power amplifier, my advice would be to turn the volume on the amp (regardless of whether there's a receiver connected) to 0 before turning the power on. If it still makes such a noise, it's possible the volume control of the amp may require cleaning.
Good Luck!
Apr 01, 2016 | Audio Players & Recorders
Poor quality sound - low volume on Netflix. Everything fine on regular TV programmes.
You have to go to the sound mixer on your PC and increase the volume on Internet Explorer, Microsoft Silverlight also.
To find the mixer try clicking on the speaker on the taskbar.
Mar 05, 2014 | Samsung LA32A450 32 in. HD-Ready LCD TV
Internal speaker does not work
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
if its a desktop swap the speakers around if one still does not work its either a faulty speaker or the speaker connection
hope this helps
Sep 06, 2012 | HP Compaq dc7600 Small Form Factor PC...
Hae i cannot hear sound from my pc after installing and replacing sp3 for sp 2 kindly assist me
reinstall drivers
hope this helps
Aug 02, 2012 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Why cvan't I hear sound
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
hope this helps
Jun 19, 2012 | Computers & Internet
My sound card problem i am not hearing any voice
is this your earphones or speakers
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Aug 31, 2011 | Computers & Internet
I am using a compaq 621 laptop, i'm not able to hear the sound when i play any song or any movie, but when i talk to someone on skype i can hear them properly
also
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 22, 2011 | Compaq Audio card Sound Card
The volume is very low & I can't find any way of increasing it; I don't want to add separate speakers as I have my phone linked to a headset via "internetcalls.com",in which the...
if you are referring to a computer with your microphone & headset attached
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
hope this helps
Jul 04, 2011 | Computers & Internet
The speaker system is making a loud rhythmic clicking sound, underneath you can hear the audio at very low volume. The clicking sound does respond to volume control. My drivers are up to date. Don't...
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
don
Mar 03, 2011 | Bose Companion 3 Computer Speakers
Difficulty hearing Samsung LCD tv even with volume up to 100%
Some models are just that way. I would invest in a small surround sound system for them.
Jun 18, 2009 | LG 37LG30 37 in. LCD HDTV
Bose Companion 3 Computer Speakers Logo
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
