Question about Little Tikes My Real Digital Camera
When I push the button to take a picture, the camera shuts off. Any thoughts on how to fix this?
Powershot A640 Could Not Be Powered On, Burnt Smell My Powershot A640 died during a picture shot, lens remaining open. I thought it may be due to the dead batteries. But after putting new batteries and...
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Sep 02, 2010 | Canon PowerShot A640 Digital Camera
Camera turns off when taking picture
Try changing the battery brand and see if this helps..I seem to have the same issue with my camera with certain battery brands..Solved my problem by switching brands..
Jun 21, 2008 | Fuji FinePix A345 Digital Camera
I have a Kodak dx4530. Recently, when I push the
The camera is not recommending the picture, It could be overexposed, shaky or taken in the wrong SCN.
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 01, 2009 | Kodak EasyShare DX4530 Digital Camera
Panasonic Lumix DMC-FX8 camera and the viewing screen is black
You have a button on your camera for the view finder on top of the camera so you can look through and take a picture : or you can see the picture your going to take on the screen.Push that button and it will change it back . I learned this the hard way . I also thought I broke my camera.
Jun 04, 2009 | Cameras
Not turning on and has strange smell
My Powershot A640 died during a picture shot, lens remaining open. I thought it may be due to the dead batteries. But after putting new batteries and pushing the on/off button, the on/off indicator blinked once then shut off by itself. After a while, a strange smell came from camera batteries area, and I could feel warm there too. Immediately I took out all the batteries from camera.
When checking the posts here the other day, I tried one solution and got the lens back to close: first took out the memory card from camera, then put the new batteries in; push the on/off button with no memory card. I found the lens retracted a little before camera shut off by itself. I pushed on/off button three times to get the lens fully close. However, the burnt smell came out again. I immediately took out the batteries.
Did I get a short circuit inside? Is there any ways to fix it?
Oct 31, 2008 | Cameras
My pre focus doesn't work do you know why
shoot mine is doing that too, i thought i was just losing my mind
Jan 07, 2008 | Sony Cyber-shot DSC-H2 Digital Camera
Camera only half operates: preview mode OK, picture-taking mode not working
Mine shuts off when I press the shutter button. I put in new batteries and I can get the lens in then. But it shuts off when I try to take a picture. These cameras are notorious for having a zoom problem. They say the Zoom error appears and the camera dies. There is a fix of gently pulling the lens out all the way till the cover open then twisting it gently clock wise till it clicks. They say this fixes this problem but I don't think that is what is wrong with mine. Do a search on Fuji E550 zoom problem fix. It should show up.
Feb 16, 2007 | Fuji FinePix E550 Digital Camera
Beep
The Polaroid Fun! Digital 320 camera is programmed to shut off automatically after a few minutes if it is not being used. This helps to conserve battery power. When the camera shuts itself off, it will make a continual beeping sound. To use the camera after it has shut off, simply push the shutter button or self-timer button to take a picture. If you are not going to use your camera, turn the power switch to OFF. The camera will also beep in rapid sequence after you press the self-timer button. The camera will continue to beep in faster sequence until a picture is taken (approximately 10 seconds). A final long beep signals that a picture has been taken. NOTE: It is normal for the camera to beep while downloading photos to a computer.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Little Tikes My Real Digital Camera Logo
23 people viewed this question
Top Little Tikes Toys Experts
Jim Goldsmith
Jim Goldsmith
Adam Fjeld
Adam Fjeld
Are you a Little Tikes Toy Expert? Answer questions, earn points and help others
