Hello, I have a Sanyo Steam Iron.Model No. A-L201,its light n indicaters r proper ,but its plate is not heating, please help me to solve this problem.
    Guru:
  • 462 Answers
This sounds like an element, burned wire, or safety fuse is out. may be cheaper to replace than fix. is this iron under $50 new?
since you say it light is on; its not power to the iron but inside the iron.
Posted on Dec 31, 2010
Why does water come out of the sole plate of my iron when ironing
The reason this is happening is because your iron is not heating to the proper temperature on the steam setting. Up the temperature setting if possible.
Sep 03, 2014 | Breville Technique Steam Iron, 2700 Watt
Why is there No steam from morphy Richards 42247 model steam generator?
It may be calcified or have lime scale. If the heater is "gummed up", it cannot heat properly. Try using either vinegar (takes longer) or an iron cleaner. You pour it in and it breaks up the scale. CLR works quite well too. Use pipe cleaners to clear out the holes in the sole plate.
Jun 02, 2014 | Morphy Richards Jet Stream 42271 Iron
Hi my swan steam gen iron is faulty , when I press the steam button it pours with water from the metal plate part of the iron , any ideas ??? Thanks
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle .
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
Feb 27, 2013 | Irons
How to repair aan electrical iron
If the iron doesn't heat, make sure power is on to the outlet, check the electrical chord, and check the thermostat and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical chord . Also test and, if needed, adjust calibration of the thermostat.
If the iron does not spray properly, inspect and clean the nozzle.
If the iron sticks to fabric, clean or repair the sole plate. If the iron stains fabric, clean the sole plate, clean the tank with a commercial cleaner, and use distilled or filtered water.
The tools you will need are
  • Screwdrivers
  • Toothpicks or pipe cleaners
  • Sewing needle
  • Commercial electric iron cleaning solution or vinegar and water
  • Commercial sole plate cleaner or baking soda and water
  • Steel wool
  • Emery cloth
Please rate my solution.
Jun 25, 2010 | Rowenta Professional Luxe DM880 Iron
It leaks water when I iron sometimes staining my clothes with black streaks or water stains.
Hello :
1:Clean your steam iron according to the manufacturer's instructions. Your iron is more likely to leak when it has not been cleaned properly. Plus, the water that leaks from a steam iron that hasn't been cleaned will likely be dirty and stain your fabric. Every steam iron brand is different, so be sure to check the manual that came with your iron or browse the manufacturer's website for instructions on keeping your steam iron in good working order.
2:Use your steam iron on a rigid surface like an ironing board. In a rush, you might be tempted to quickly iron a blouse or pants on the nearest available surface like a bed, carpet or even on a table with a towel draped over it. However, these surfaces may not provide the proper amount of level padding for successful steam ironing, and leaks are more likely to occur. Take the time to set up your ironing board for smooth steam ironing to reduce water leaks on a bumpy surface.
3:Allow your steam iron to heat fully in the upright position before ironing. Because your steam iron is designed to convert water into steam that will easily smooth out wrinkles on bulky fabrics, you can avoid leaks by ensuring your iron has time to get the water to the correct temperature. If you lay your steam iron in the horizontal position too quickly, water that is not hot enough to convert to steam will leak. Give the iron a chance to heat up, and then test your steam function on your ironing board cover or spare fabric swatch before tacking your favorite blouse.
4:Turn off the steam function on your iron when ironing at lower temperatures. Since your iron's steam function is designed to convert the water in your iron to steam at the right temperature, lower iron temperatures can cause water to leak if your steam setting is still activated. For ironing more delicate fabrics, turn off the steam to avoid water leaks.
PLEASE RATE !
Apr 18, 2010 | Euro-Pro Shark GI490 Iron
My iron is filled with water but won't steam - why?
No heat ! It's probably an electrical problem. If the electrical cord is connected to the iron properly, then it's probably one of the swithes to the iron.
Oct 07, 2009 | Oreck Cordless Speed JP8100CA Iron
Tefal steam iron not heating up properly
That is probably because the contacts to the element at the base of the iron are broken.
To disassemble you have to remove the casing, then remove the steam pump at front top of iron and then undo the safety screw mounted on the front of the base plate.
Apr 22, 2009 | Tefal UltraGlide plus 1656 Iron
Tefal Express 1750 has water dripping from it when using steam
That means that water is not heated properly and does not produce steam.
Try a complete descaling, often this happens because the water reservoir and heating element is covered with scale.
Feb 17, 2009 | Tefal Irons
Tefal Pro Express Steam Generator doesn't.
OK... so I have fixed my problem of NO STEAM, just lots of water coming out of the iron press plate itself... I had already cleaned the boiler, so I tried adding 1/4 tsp - 1/2 tsp bicarbonate soda to the water and flushing it through. From what came out of the iron press plate, I would say the problem was caused by a build up of goop (technical term) inside the iron. Once cleared, the iron is steaming away again. Please note, u will need to have an old towel handy if this is ur problem, 'cos until it starts getting better, there is a fair amount of water coming out of the iron press plate. Just add the bicarb to the water reserve and use the steam buttons to bring the bicarb through. Do not attempt to iron clothing with the bicarb in the water!!! Carolyn ;)
Nov 12, 2007 | Tefal Ultraglide 1549 Iron
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
