Question about Philips DVP620VR DVD Player/VCR
Hi do you know the code please to make my phillips dvd DVP620VR region free The set up menu gives me three options - quick, custom and init set up
  • 10,421 Answers
Dvr620uk region code
Many units are really re-programmable to be region free, most notably the Phillips models. Protocol for re-setting varies by model. Some require use of the remote while the CD tray is open. Some have a hidden menu that can be revealed through use of the remote. One quick and cost-effective fix is to buy an inexpensive region free unit which are readily available, some for as little as $30 at Amazon.com I will research this particular model and add to the post.
Jan 10, 2014 | Toshiba DVR620 DVD Recorder/VCR
I bought some DVDs at amazon.com, but I live outside the region code area witch the DVDs are supposed to work. I live in code area 4. I need someone to find a code to region 1. I have a Phillips home...
This player is relatively easy to change to region free. Please complete all of the steps below to unlock your DVD player.
Please note: Unlocking any DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
Unlock sequence for the Philips DVP 3020:
1. Switch on your TV and DVD player;
2. Make sure the TV is set to the correct input for the DVD player;
3. Remove any disc from the DVD player and close the disc tray;
4. Press the "SETUP" button on the DVD player remote control;
5. Use the LEFT/RIGHT arrow keys to highlight "PREFERENCE";
6. Enter 1 3 8 9 3 1 using the numerical keys on the Philips DVD remote control;
A pop-up menu will appear on the TV screen.
7. Use the UP/DOWN arrow key and choose "0" for all regions;
That's it. You should now be able to watch DVDs from all regions on your player. It is also a good idea to switch the player to standby and then switch it back on before trying any discs.
This is a verified unlock sequence for the Philips DVP 3020. If it doesn't work the first time, switch the power off and start again at step 1. If it still doesn't work, it is likely that you have updated your Firmware to a new version and this unlock sequence does not work with your firmware version
If you need further assistance, please reply to me from within this page and let me know which firmware version you have installed in your DVD player.
Regards,
BElectric.
Jan 28, 2011 | Philips Televison & Video
I would like to make my Panasonic DVD-RV26 region
Hi
Thanks for using FixYa. There are the following two methods to make it region free---
Method 1:
No disc in tray; Press STOP; Press SET-UP: KEY IN 3, 8, 8, 8, 3 then 0 for zone free
Method 2:
1. Remove DVD/CD from your drive.
2. Press the following keys on your remote: [Setup] [1] [>=10] [6] [4] [3] [8]
3. A new menu option will appear – named other followed by four stars. Use Codes: 3192 -> Multi-Region Enable
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
May 01, 2010 | Panasonic DVD-RV26 DVD Player
Lg dvdcombo region codes
I have just hacked an LG 32LG4000 combo tv/dvd. To open up the dvd to multi region, turn on the tv & press the menu/set up button. Next, navigate to the lock symbol but do not open the sub menu. Press 0 seven times. Exit out of the menu, and your 'on board' dvd player will play dvd's from any region!
Nov 28, 2008 | LG 32LG40 32 in. LCD HDTV
Make my dvd multi region
1. Press the 'Set-up' button on the remote control
2. Select the 'System Info' mode from the on-screen menu
3. Using the remote control 10-key type in '1101'
4. 'Region code' should appear as an option on the 'System Info' menu. Initially the region code will be set to 4 (depending on your country). Press '0' on your remote control to set to multi-region.
5. Press 'OK/Enter' on the remote control.
6. Finish by pressing the 'Set-up' button once more.
Sep 14, 2008 | Sanyo Televison & Video
Unlock sony DVP-FX720
The problem may be you are trying to play DVDs from a specific region (Europe) and the player is set for another region. Region code errors will show up as "no Play" or 'region" Check the manual to see how to set the player to Region 0. A region machine will play any DVD. Sometimes the setting is on the menu - usually in the set-up screen under "region." I have re-set all my Phillips players to become Region Free through the menu.
Aug 22, 2008 | Yamaha DV-S5450 DVD Player
Phillips dvp1013
Hello Canada416,
Check the following link to the regional code data base for codes you can enter through the handset to unlock region codes. Let me know if this helps you or you need further assistance.
Jun 30, 2008 | Philips DCP855/37 Portable DVD Player
Phillips 14PT6107S/05
I found this on the net:
Try this, there are 2 versions of this set, one of these will work.
14PT6107
ENTER 062596 ON REMOTE
WITHIN 5 SECS PRESS MENU
SERVICE MENU SHOULD APPEAR
SELECT DVD
PRESS ENTER
OPTION 1 USE RIGHT BUTTON TO SELECT REGION "ALL"
NOW PRESS MENU 3 TIMES TO EXIT
OPTION 2 TYPE 00 PRESS OK
THEN MENU THREE TIMES
GO IN TO STANDBY AND POWER BACK UP
Option 2 worked for me. The thing I was failing to do was going in and out of 'standby'.
Also there is no 'all' instead 00 = 'all'
Jun 12, 2008 | Philips 26MD255V 26 in. LCD TV/DVD Combo
Dvd stuck on zone 1 when i am a zone 4
MMM impossible to unlock Yes it is inside your own time and mind set thats true for you !Anyway Region zoning does not protect copyright.!Newzealand is A Region Free regional code Free
country.
so ridiculous restrictive practices that are coming to be regarded as
"normal".Thats what I would like to have you gies with this site to do to help !
stop this .
I know how to hack .to change the zones Any way.I have never recorded NEW
RELEASE ONES!
1. Empty the Disc Drawer
2. Press "Setup" on the remote
3. Press 1, 3, 6, 9, Left, Left, Left, Right (keypad)
4. "Version" will appear on the Menu, scroll down to this.
5. Once in "Version" go to "Region" and go across to the number and change
to "0" to Multi Region. Use the keypad to change the zones.
6. Then exit Version
7. Then exit Setup
THATS HOW I DID THE IMPOSIBLE I DONT KNOW WHAT THAT IS. I HAVE AN IQ OF 184 AND Having Aspergers Helps . I know about blue book 2012 and want to hack the Air force bace .Please reply.
Feb 12, 2008 | Computers & Internet
7" LG Portable DVD Player DP271
Hi
I have tried to unlock the DVD DP271 player using following methods, But it is not unlocking. If any body knows any other code. Please help me to un lock my DVD DP271 player.
Thanks
Sekahr
1. Power up and press setup
2 Scroll down to LOCK
3 Press '0' (zero) seven times
4. A message may now appear with saying that the player is region free.
5. Power down then power up.
or
1. Remove any discs and power up the DVD
2. Press PAUSE
3. Enter 314159
4. The hidden region code menu may now appear.
5. Set code you want- 0 for multiregion, 1 for region 1 and so on
6. Press PAUSE
7. Power down then power up
Nov 02, 2007 | Insignia NS-PDVD8 Portable DVD Player
Philips DVP620VR DVD Player/VCR Logo
145 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
