Question about HP LaserJet 1020 Printer
My hp laser jet 1015 printer folding paper from the left corner of the page when it out form the printer
    Genius:
  • 1,570 Answers
Try to check for some paper obstruction into the roller (black) and clear it. Try to clean also those roller with rubbing alcohol to remove some dirt on it and try printing again if it works.
Posted on Dec 31, 2010
My HP printer 1022 laser jet is making black stripes at left corner of the paper
This could happen due to
1. Worn wiper blade
2. Worn Drum
3. Worn PCR
above 3 are inside the toner, if you know how to replace them replace or install a new toner, if the problem still persists you have to check the fuser or contact a technician..
Jun 20, 2012 | HP LaserJet 1022 Printer
PAPER IS FOLDED AT THE CORNER. I STOPPED THE PRINTER THE PAPER WAS CREASED WHEN THE PAPER WAS UNDER THE TONE CARTRIDGE WHEN I TOOK IT OUT CAN YOU TELL ME HOW TO FIX THIS PROBLEM. THANKS
You probably have a small obstruction under the registration assembly or the actual rollers of the registration assembly are out of position. I have had this before. Lift the metal flap with the green lifter on the right hand side, up and check for paper and if it is in the right position. Also make sure that the paper guides in the paper tray are snug up against the paper.
May 11, 2011 | HP Laser Jet 1320 Printer
Left corner is folded down on page
Sounds like an issue with the feed rollers. The roller on the left side might be hung up and is causing the corner to fold over when the paper is pulled through. I would try checking the feed rollers in either the actual tray or the back of the printer. Another thing to check is the other tray (the manual one). Does the paper fold? this should help you narrow down where the problem lies.
Mar 02, 2011 | HP LaserJet 4350 Printer
Paper feed Ricoh Aficio 1015
Is the copier not feeding? There are many problems that could be causing this.
- The feed roller could be dirty or worn. The feed roller sits on the upper right side of the paper tray -- it's a thick gray roller. Clean this roller with a lint-free rag and some alcohol.
- The paper fences might not be tight. There are two paper fences (one toward you and one on the far side of the paper, away from you). Make sure these fences are tight enough so that the paper does not move around in the tray, but not too tight to keep the paper from being fed out of the tray. Also make sure the green guide on the left side of the paper is snug but not too tight.
- The paper could be damp, curly, or full of static. Damp paper is a big problem, especially in the summer. Try filling the tray with a fresh **** of paper and see if it feeds through better. Also make sure none of the pages in the tray are bent or folded under.
Did any of these suggestions help?
Aug 28, 2010 | Ricoh Aficio 1015 All-In-One Laser Printer
How to print legal paper in 1210 printer
canon lbp 1210 printers
has a probleam a legal page setting
plese answerer legal page setting
May 11, 2010 | Canon LASER SHOT LBP-3000 Printer
1320 Printer prints with corner fold
This tells me something is getting caught usually I would recheck the Paper Tray. If possible you could run the paper through the Bypass or Tray One as HP would call it. See if it is happening there if so then you can eliminate the Cassette Trayi
Also Did you run any lables through this Printer ??
Sep 12, 2009 | HP LaserJet 1320 Printer
Hp laserjet 1320tn folds the upper right-hand corner of the page
Check carefully for any small scraps of paper caught in the paper path. Do a 1/2 way test, do a print job, listen for the paper to get just under the toner then quickly open the front of the printer (may take a few tries) see if the paper is folded there or if it's happening later that way. If it is folded before entering the fuser, you probably have a small piece of paper in the paper chute somewhere. If it's not and folds later, the fuser is probably worn badly.
Feb 09, 2009 | HP Laser Jet 1320 Printer
HP LJ 4350 paper folding problem
It could be either the paper feed assembly, part # RM1-0012, or the registration assembly, part #RM1-1098. These parts can be bought at TSAworld, phone # 1-800-633-6626
Aug 08, 2008 | HP LaserJet 4350 Printer
HP Color Laserjet 3500 printer - no black on left side of page
The folded paper solution for for me. Thanks to all for sharing!!!!
I had the same problem. No black or cyan on the left side of the pages. From this advice... I folded a stack of 4 pieces of paper in half and then half again. I took out the transfer unit and put the folded paper in the upper left corner and then put the transfer unit back in. WORKS BEAUTIFULLY! Thanks you all sooooo... much!
Sep 25, 2007 | HP Color LaserJet 3500 Printer
HP LaserJet 1020 Printer Logo
146 people viewed this question
Seeker5211
Seeker5211
