Question about Hunter (25417) Ceiling Fan
Hunter fanlight blinks when turned on. - Hunter (25417) Ceiling Fan
    Guru:
  • 462 Answers
Loose connection some place start by removing lamp and resetting it.check switch for intermittent operation, finally check the wire connections behind the lamp. if this helps please rate me accordingly
Posted on Dec 31, 2010
We purchased the Hunter Ceiling fan over a year ago and it has worked fine up until a couple of weeks ago. When we turn on the light it just continuously blinks on and off.
there is a watt governor, or black box for the lights to cut down on wattage or energy use. you can remove the black box for the lighting, and wire it directly to the main wires. white wire to white wire, and black wire to red wire. black and red are always a hot wire and white is a neutral wire. the part number on black box should be 98480-02. this should stop the lights from blinking. have a good day !
May 28, 2011 | Hunter 21871 56'' Ergonomic Brushed Nickel...
When you turn on the light, it blinks for an hour at least until it finally stops blinking.
remove little black box its a watt governor. inside for the lights, and wire direct for lights. the problem should be solved.
Jan 19, 2011 | Hunter (25417) Ceiling Fan
Light blinks when turned on. I have changed light bulb with the proper wattage bulbs.
hi,
check is there is any loose contact in the bulb holder. its the only reason for blinking.
ok
Dec 31, 2010 | Hunter (25417) Ceiling Fan
I have a fairly new hunter ceiling fan/light. Often when we turn the light on it continuously blinks on and off. To remedy this problem we need to cycle the switch (sometimes many times). I am assuming...
on most of the hunter fans there is a watt governor in it. if problems with lights blinking, remove watt govrnor, then wire it direct without governor. governor part # 98480-02, have a good day !!
Dec 12, 2010 | Hunter (25417) Ceiling Fan
The light portion of my hunter ceiling fan is blinking. At first it started blinking, then it didn't work at all, now it is blinking again. What is wrong?
the blinking is caused by the watt governor to lights( its a small black box with slots in it ). just remove this box and wire direct. this should fix problem.
Dec 10, 2010 | Hunter (25417) Ceiling Fan
I have 2 of the same Hunter Douglass ceiling fans with double light kits in my living room. Yesterday one of them started blinking the lights constantly when I tried to turn on just the lower bowl light....
if problems with blinking lights, remove watt governor on inside of fan for the lights.its a black box,white to white wire and black to red wire. and wire it direct without watt governor or black box. this should fix the problem. the part # 98480-02 for watt governor. they installed watt governors on ceiling fans to reduce light wattage.
Sep 19, 2010 | Hunter Fan/Light Wall Mount Control 27186
Light s blinking on and off
Receiver for remote control of light goes bad over time. If you are competent with electrical wiring you can bypass this defective component. Take the light kit off (3 screws) and unplug the modular plug. Trace wires from lights back to a small box in the light kit containing electronic components (you can see circuit board, capacitors etc - in my case this was part # 98480-02). This is what you will be bypassing or replacing. In my case the fan did not come with a remote, so I removed & bypassed this box. (white wire to white, red wire to black. Light now works fine, no blinking.
Feb 10, 2010 | Hunter Dryers
Wiring p fan speed cotrol switch
most common fanlight control is 2 dimmer switches in parallel to control fan spped and light, direction is still usually controlled on the fan body
requires 3 wire in the light box, and a compund dimmer, this one has left and right and fits a single switch box
where a fanlight is used to replace a regular household fitting there is often only 2 wire in the switch box, either a sparky can fishtape an extra cable along the lamp cable, or replace the wire,
the 3 wires from the fanlight are light fan and neutral
some new retrofit fanlights have remote controls to negate rewiring
Apr 26, 2008 | Hampton Bay 52 In. Brushed Nickel Romano...
Hunter (25417) Ceiling Fan Logo
280 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
