Question about Maytag Atlantis MAV6000 Top Load Washer
Washer tub will not spin - Maytag Atlantis MAV6000 Top Load Washer
  • Maytag Master
  • 17,130 Answers
First of all make sure that there is voltage to the (spin) main motor , if not the program controller is faulty and must be checked for failure of the driver/relay.
If voltage is present and the motor does not work check the motor capacitor. If not the motor can be faulty. check for any mechanical jamming as you must manually turn the motor for a spin. If not reset the spindle shaft and drive.
Posted on Dec 31, 2010
Kenmore 22622 washer tub will not spin during spin cycle, burnt smell
Sounds like the belt between the motor and the tub is slipping or the tensioner spring may have failed.
Dec 14, 2013 | Kenmore 22422 Top Load Washer
Empty tub wobbles when on fast spin, more than any other washer i have ever owned
Might be a defective tub. Or it could be item between tub maybe?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 13, 2013 | GE 3.9 cu. ft. Stainless Steel Capacity...
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
My 7 year old he3 has a terible thumping noise when in the very fast spin cycle it is like the tub is coming out. The spin cycle before last is not as bad. the shock absorber are ok I can take the front of...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 11, 2011 | Kenmore HE2 Plus Front Load Washer
During spin cycle washer drum knock and seems as if it is out of balance, even when empty
"spider" broken. Cast aluminum bracket that attaches shaft to inner tub is coroded. Spin tub and shaft assembly cost approx $300 to replace. Heard that parts may have lifetime warranty.
Sep 03, 2010 | Frigidaire ATF6000ES Front Load Washer
Spin cycle
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
May 04, 2009 | Kenmore 24422 Top Load Washer
Washer motor spins but the TUB does not (intermittent)
If the motor is running and the tub is not spinning you must remove the motor and inspect the drive coupling.
One of the 2 plastic pieces could be stripped or cracked.
If the drive coupling is intact, proceed to the clutch on top of the transmission.
Replace the clutch linings.
Mar 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Tumble Action Washer won't go to spin cycle
im a repairman,lets reason this out.if washer wont spin because the tub is so warped that when it spins its so out of balance then ok new tub.or the tub welds are broken and some part is dragging and not letting it spin then ok new tub.or spin bearing has failed and ruined tub support shaft,ok new tub.but why else would you need a new tub for a no spin problem,not sure,and to answer your other question , can you fix the tub if any of the above problem exist.no you would have to replace tub.i hope that helps,God bless ,tom....ps if i have been helpful please remember to help me with my ratings,tom
Jan 06, 2009 | Kenmore 43142 Front Load Washer
Roper(whirlpool) washer will not spin
check the tub casting under the agitator or it the gearcase
Mar 17, 2008 | Roper RAX4233PQ Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
42 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
