Question about Hunter (25417) Ceiling Fan
Light blinks when turned on. I have changed light bulb with the proper wattage bulbs.
  • 6,694 Answers
check is there is any loose contact in the bulb holder. its the only reason for blinking.
ok
Posted on Dec 31, 2010
How do I change the bulb
1. First, make sure the power is turned off.
2. If the bulb is being used for some time, then let the bulb to cool as it will be really hot to handle.
3. If the bulb is too high for you to reach, use a step ladder to safely reach the bulb and remove the bulb. There are two types of bulb mountings:
a) Screw Fitting (common in Europe)
Keep turning the bulb anti-clockwise gently until the bulb comes loose from the socket.
b) Bayonet Mount (two prongs, standard)
Grasp the bulb lightly but firmly, push upwards gently and turn anticlockwise until it is released from the socket.
4. Insert the replacement bulb lightly but firmly into the socket. Depending on the type, turn it clockwise until it locks into place or keep gently twisting clockwise until it won't go any further.
5. Once the bulb is in, restore the power back on and switch on the light.
6. The old bulb needs to be disposed of safely as the glass is fragile and very sharp. Use the packaging from the new bulb to wrap the old one for safe disposal.
PRECAUTIONS
1.
Check the wattage on the used bulb and replace it with a bulb of the same wattage.
2. Dispose of the bulb well out of the reach of children
3. Don't put your fingers in the exposed light socket
Dec 23, 2015 | Dryers
Drivers side turn signal blinking fast other side normal, bulb change didn't help
Even after bulb change, do all lamps work? Bad ground can be shown by weak or dim bulb sometimes and this can cause fast flashing. All bulbs which flash must be working and of normal brightness which is sometimes hard to tell when they blink really fast.
Feb 27, 2015 | 2006 Lincoln Town Car
I have a Casablanca Fan & the lights are blinking?
make sure the wattage in the bulbs are correct
Oct 16, 2014 | Dryers
2004 buick lasabre, right side turn signal blinking fast.
Check the front turn signal bulbs. This will affect the resistance in the circuit and cause the working light to flash at a much faster rate.
Aug 15, 2012 | 2004 Buick LeSabre
Driverside turn signal does not blink on gets bright
see the wattage of the bulb have used are wrong.replace with right wattage bulbs.and also see that all the are blinking or not.
Feb 27, 2012 | 1991 Chevrolet S-10
Sometimes my turn signals dont blink, they just stay constant...?
Hi, the fact they do *** on is good, but as this is intermitant fault its a bit of a pain, first off i would check all the bulbs are all the same wattage, and that is the same as the wattage on the flasher relay, this is normaly written or embossed on the relay, and may say 2x 21 watt, if this is the case the bulbs must be 21watt, if it says 2x 5or 10 or 15 then the watage must corespond buld and relay, a higher wattage would cause the light not to flash, and a lower wattage would cause the light to flash to quickly
Feb 19, 2011 | 1992 Honda VT 1100 C Shadow
The right turn signal light is blinking faster than the left. How do I fix it?
Check to see if you have a bulb burnt out in either the front or back, that is usually the problem. If that is not it, it may be electrical and I would contact a mechanic to fix it. Good Luck!
Jan 16, 2011 | 1992 Honda Accord
B.garcia.1@hi there i tried to change my indicators on my yamaha xvs650 to led light but when i turned ignition on and put the indicators on they all flashed like hazzed light. can you please help me
Better clean up the base of the BULB, that fast blinking means ground line is not supplying. Check also the specs of the BULB, it might have different wattage w/ the original!
Nov 20, 2010 | Yamaha V Star Custom Motorcycles
Hunter (25417) Ceiling Fan Logo
886 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
