I need to check and see if my new webcam is working?
Webcam of new Medion Akoya P7618 does't work. Doesn't appear in devicemanager.
I'm not sure, but maybe the launch manager controls the webcam and needs to be activated/installed
did you check for hidden devices in device manager?
Mar 07, 2012 | Computers & Internet
I have a new zoostorm vme50 and cant get the webcam to work. I've looked on device settings and it isnt listed, i tried Fn & Esc but nothing happened
you need to scan for new hardware and see if recognizes it if not try this
Check if driver for webcam is properly installed. You can check that by going to control panel then click on system then click device manager. The webcam should be listed in the device list if properly installed. Try to press Fn key + Esc key at the same time to enable/disable webcam.
but what i just described there kinda seemed like you did it already. if its a usb webcam. unplug it and plug it back in. also check there website for the drivers. if you did fn and esc and u turned it off then it wont show up in the device manager.
Mar 16, 2011 | Computers & Internet
Iam bought a new ENTER USB 2.0 Webcam. I installed the software as they given in the user manual. Now i connected my cam to my system USB. but my system is not recognizing the webcam. i checked with my old...
You need to find out what support software you need to download in addition to the Enter software
I run a Logitech and need Microsoft DirectX 10 to support it
Download this diagnostic software, plug in your webcam and see what it finds - Ignore the first Alert - I always get that
http://www.download32.com/webcam-diagnostics-d35065.html
Jul 29, 2010 | PC Concepts 300K Webcam
My web cam does not working properly, i can´t
Thank you for informing the world of your dysfunctional webcam, but why would you want to view nothing?
There are many, many problems that can plague a webcam. Try plugging the webcam in to a different computer. If the webcam still doesn't work, you will most likely need to find a new one. If it does work, try checking the manufacturer's webpage for updated drivers for your operating system.
May 13, 2010 | Gear Head WC535I Webcam
My Veo Webcam works correctly except on Skype. When I try to use it on Skype my picture is all red and yellow. Not a clear picture. I tried adjusting the resolution settings through Skype and that did...
check out Skype webcam help
https://support.skype.com/en/faq/FA1267/I-set-up-video-but-it-doesn-t-work-What-s-wrong;jsessionid=451F10CB24F4C887E359486876B1C9DC?frompage=category
Jan 14, 2010 | Veo Connect Webcam
My WebCam that worked with XP Pro no longer works now that I changed to Windows 7
You can check Logitech's support site to see if you see a webcam that looks like yours. If you're lucky the Vista drivers will work. Since yours is older you'll probably have to check where it says "Still Can't find your camera"
If that doesn't work for you then it's time for a new webcam...thank goodness they're cheap :)
Logitech Webcam Support Page
--RescueTechLA
Nov 29, 2009 | Logitech Webcam
My webcam is not working with yahoo messenger.it was working but just quit with messenger.
does it work with othe rprograms?
Reload and install the driver for the webcam, using the disc, or at the manufacturers page.
and if that does not work.
Check if Yahoo has new upgrades that has affected your w/cam.
Nov 05, 2009 | Logitech 961462-0403 Webcam
Webcam
if ur webcam is not working what u can do is first of all u can uninstall and reinstall the drivers for the webcam and then try ur webcam and still if it doesnt work restart ur computer once and then connect the webcam and try it out and still if it doesnt work then replace the webcam and get a new webcam which is compatible with ur computer.
Jan 20, 2009 | Acer Aspire 3680 Laptop
Driver for Micro Innovations IC200C
http://www.microinv.com you can check this site or send them email regarding your driver problem
Oct 16, 2008 | Micro Innovations IC200C Plus Webcam
Need to download driver for my new webcam spc900nc/27
well i think u check the Device Manager. Then press webcam spc900nc/27 applications. Then right click/ update the driver. If that not work, try to reinstall that again!!!!!!!!!!!!!!!!!!!!!!!
Apr 22, 2008 | Philips J44414
Computers & Internet Logo
David Payne
David Payne
