Machine is leaking when fully loaded. What is tube in front of machine near filter for?
  • 784 Answers
That little tube is most likely the water height pressure switch,, if this is plugged up or if the switch is bad then the water will not stop filling because no pressure is sensed.
c...
Posted on Dec 31, 2010
My LG front loading washing machine leaks from the bottom when in use. I have check the filter and it is clear. The tube beside it seems to be clogged and when I unscrew it no water out
Take top off, take control panel off, take wire clamp off front of door boot, take front panel off, check all hoses for holes/leaks. Repairclinic.com or appliancepartspros.com have how to videos.
May 08, 2017 | LG Washing Machines
My LG WM2455 has water leaking from lower front near the front access door. I have checked the catch basin and drained the tube but still get leakage after the next load. What could the problem be?
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Check the condition of the drain hose that connects the tub to the pump.
Aug 25, 2014 | LG WM2455 Front Load Washer
I have a Matag model A482 that is leaking water when filling for wash or rinse and I want to know how to remove the top (no manual...); it seems that there is a release mechanism in the front of the...
you will have to first remove the front of the machine two screws at the bottom of the front pannel tip away from the machine to release the front tabs. you will then find screws run up into the top remove these and the top will tilt back locate the filler tube from the valve and follow to the inlet to the washer about half way there should be a vacum cylender inside a rubber tube that has probably become loaded with hard water deposits or just stiff from age replace the tube and leaking should stop
Mar 01, 2011 | Washing Machines
Water leaking from the bottom of my front load washer
Common causes
door gasket damaged(torn)
Dispenser fault
Lint filter door not fully closed
It sounds like you might have a damaged outer bowl, broken by a foreign object(coin, wire,screw). Costly repair.
May 04, 2010 | LG WM-2277HW Front Load Washer
"OE" message
OE is actually DE - Drain Error. Pop open the little door on the bottom left of your washer, and unscrew the cap on the little tube on the left. ***Water will drain out!***
Once the water is out, unscrew the bigger tube on the right. This holds your drain filter. It is likely clogged, so clean it out and reinstall the filter and cap from the small hose.
Hopefully this fixes it!
May 02, 2010 | LG WM-2277HW Front Load Washer
My washer is leaking water near the water tube located right in front of the washer. Do I need to replace something or can I seal it?
most likely u will need to replace part.u should remove the cabinet to get a better look at where the leak is . the cabinet comes off from the front.
Oct 27, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Bosch washing machine leaks at right bottom
The part that you removed, was the pump filter, the pump is located behind the filter, possibly, the pump itself is leaking, or the filter cover is not fastened in tight enough, pr the filter seal is defective, if after tightening, it still leaks, suggest you replace the pump.
Please rate my solution.
Thanks.
May 26, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
LG WM2487 Leak Front Left
Not sure if this machine is similar to the WM2277, but here is the procedure for that - my leak was in the "baffels" hose that connects the drum to the drain pump:
1. Drain the machine - pry the panel at the front left lower corner to get access to a stoppered tube. drain as much water from here as possible.
2. Remove screw visible inside this area and remove the white molded plastic - also remove the screw behind that plastic.
3. Open the washer door and remove the spring loaded wire around the door gasket. Carefully pull the door gasket away from the panel push inside and then reclose the door.
4. Remove the detergent drawer and the two screws visible behind it.
5. Pull the top of the electronics panel away from the machine and lift up - place on top of machine or hook it out of the way
6 Remove the 4 screws that are visible holding the front panel to the machine. Left the entire front panel up about 2 inches and swing to the right (there is a wire connecting the door to the machine on the right)
Jan 16, 2009 | LG WM-2277HW Front Load Washer
Leak from tap at front of machine
the filter may not be sitting right in its slot - an obstacle may be keeping the filter from being seated all the way - once the filter is fully seated, it blocks the water to the front tap
Oct 27, 2008 | Miele Novotronic Premier 500 Front Load...
Machine fault code "f13"
Plug off the wall. There is a thin rubber tube going from the switch area to the exit near the outlet tube. Probably this is blocked. This tube should be free from any blockage; take out the top clip from this tube and blow into it - it should be free, clear the blockage if any and refit. This is the water level tube which tells the machine when to switch off water, etc.....
Sep 02, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
