Vulcan freeloader hot water heater
After my heater got flooded from heavy rain my pilot light went out. I am able to relight the pilot light and the heater operates fine but after a while the pilot light goes out. I have to relight my heater every morning and evening as the pilot light has gone out.
  • 2 more comments
  • patrick2888 Aug 26, 2008
    Same problem but heater has not been flooded. This is more like the pilot is not keeping the flame detector capillary hot enough. Does the flame burner tip ever need cleaning ? htr is 8 yo and have already tried to cln the pilot hole but is v/v small. htr can run for two or three days before needing re-light. Hidden pilot flow adjusting screw is set at maximum and plenty of gas is coming from the gas regulator unit pilot outlet tube.
  • bennyjam Oct 13, 2008
    Yeah i'm having the same problem, it just keeps going out. Also the peizo ignitor wire seems to have been disconnected. Where should the wire be attached to? Is there somewhere online where i can see a diagram or instruction manual?
  • Anonymous Mar 18, 2014
    propane wall heater pilot light keeps going out, and then will not relight
  • Anonymous Mar 27, 2014
    Vulcan free standing heater
Pilot light is on but not igniting surrounding jets to heat water. What can be done?
HPD
Posted on Jul 11, 2010
Maby to much gas is going to the pilot causing flame lift-off get a gasfitter to check working pressure, flame position, blocked pilot injector, oversized pilot, windy location.
Martin Kelly Craftsman Gasfitter
Posted on Jan 31, 2010
Could be moisture in the gas supply line - get your gas fitter to purge the line at the meter.
Posted on Aug 03, 2008
Wher is pilot light
Why will my pilot light on the gas water heater not stay lit for ...
diy.stackexchange.com/questions/.../why-will-my-pilot-light-on-the-gas-...
Jul 28, 2011 - The pilot light went out on my gas water heater. I followed the ... This could be from a valve not being all the way open. It could also be from a ...
How To Relight Your Pilot Light On Your Water Heater ...
? 7:54
https://www.youtube.com/watch?v=gqM7kMkkFAI
Apr 15, 2013 - Uploaded by TipsNNTricks
How To Relight Your Pilot Light On Your Water Heater. TipsNNTricks .... I answer the following questions in this video. How can I relight my pilot ...
How to Light a Water Heater (with Pictures) - wikiHow
www.wikihow.com/Light-a-Water-Heater
wikiHowJump to Questions and Answers - If the pilot light doesn't relight or goes out immediately after ... if you are unable to light the water heater after several attempts.
Jan 13, 2016 | Water Heaters
Rheem NatGas hot water heater model 41V50, basement flooded pilot went our how do I relight?
At the controls there should be a knob that says " Pilot"... "ON" Turn the knob to pilot and hold it down while lighting the pilot lite. Keep holding it down until it gets warm enough that when you leave it up the pilot stays on. Once the pilot lite stays on on it's own turn it to on.
Mar 14, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
Hi there i recently had another gas appliance installed and the gas was turned off while this work was done, so my hot water service pilot light went out. the guys who did this work didn't relight the...
First turn the dial on the hot water heater to the off position and wait for 5 minutes. Then turn the dial on the water heater to the pilot position. Press in the dial and use a gas grill lighter, long wooden match, or similar device to light the pilot. Once the pilot is lit, continue to hold in the dial for about 1 minute then release and turn the dial to the temperature setting that's comfortable for you.
Dec 11, 2010 | Heating & Cooling
I have a vulcan freeloader 260 gas, how do i make sure it has water in the tank
The old freeloader is feed by cold at the bottom and the hot feed comes out the top. Basically if you are getting hot water out the hot tap (or any water out the hot tap) it has water in it. If you have any concerns post a new fault, I will keep a look out for it. These are great heaters, well worth looking after.
Sep 20, 2010 | Heating & Cooling
My Mum has a Vulcan freeloader 260 gas hot water system and it appears that the pilot light has gone out. The only problem is I can't find where it is to test how to turn it back on. Can someone please...
Remove the access panel lower right hand side and locate the pilot light re-igintion push button. The instructions are pritnted on the back of the access panel.
May 18, 2010 | Water Heaters
I have a vulcan freeloader 230 gas hot water system. the pilot will not stay lit. and some times when i do get the pilot lit, it will not ignite the main burner until i have lit the pilot a few times.
Clean the pilot assembly if has any orange at the tip. If its burning clean and blue, then its most likely the thermocouple. Safer to get a gasfitter to check it out.
Jul 18, 2009 | Heating & Cooling
Vulcan 300 Freeloader Gas Water Heater
I assume it has a pilot. Try blowing out the pilot area with compressed air or CO2. Then relight the pilot.
Dust can cover the pilot combustion air inlet and cause it to pull away from the safety generator or thermocouple. Its called an oxygen depletion arrangement on some space heaters. I assume your Domestic Water Heater has this setup as well. Even if not the thermocouple is not getting all then heat from the flame. If this doesn't work get back to me here. We'll try 1 more thing.
If this helps you please grade me accordingly. GOOD LUCK
Mar 04, 2009 | Emerson Fans 300 Heating & Cooling...
Water too hot on a Vulcon Freeloader Super 10
Remove the cover and there should be a temp setting
Jan 31, 2009 | Water Heaters
Heating & Cooling Logo
1,949 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
