Question about Solo 475 Backpack Sprayer Back Pack Sprayers
Trying to remove pressure tank from inside spray unit. trying to replace all seals.
    Problem Solver:
  • 17 Answers
Dont !!!!! just buy a new one bout 100 bucks but if u want it comes out thru top but u have to take lose underneath
way too labor intensive for the price of new one
Posted on Feb 09, 2011
How to replace seal on the fuel tank that filler tube goes into on 1997 Lincoln town car
You need to remove the filler neck, it has screws I think inside the gas fill door. Pull it out of the fuel tank, go under the car and remove the old rubber donut seal where tube enters the fuel tank, spray some car cleaner on the rubber and as quickly as possible insert the tank fill tube and put it all back together.
Jul 19, 2016 | Lincoln Cars & Trucks
Replaced fuel pump in tank on xj 96 now spray gas from above rear end?
Your seal must be leaking,remove fuel pressure and remove again and see if seal is bad or pjnched.
May 17, 2015 | 1996 Jaguar Xj Series
The tubing inside my water tank popped off. I am trying to find a replacement water tank, not having any luck though.
Call Lowes Hardware and ask for the website of the company that sells replacement parts for common household items such as pressure washers, cloth washers and dryers, ...
Dec 13, 2014 | Vacuums
Fuel pump replacement on a 2003 kia sorrento
Remove negative battery terminal, release tank pressure by opening gas cap, remove the rear seat, you will see a cover, remove the cover, you will now see the top of the gas tank and also the pump, the pump is located inside the tank and can be removed from the top, next remove the connector from pump, remove the lines, note : cover lines with a rag as you remove there may be a little pressure, this will help gas from spray all over, with connector removed and lines removed you will now remove the six bolts holding the pump in, lift and remove the pump, take note of the position, make a ref mark so you can reinstall pump in top of tank facing the right way. this is called a fuel pump module, here is a picture of the pump unit.10_6_2012_2_55_35_pm.jpg
Oct 06, 2012 | 2003 Kia Sorento
How do I replace a fuel pump on a 1993 Buick Rega?
Follow the steps given below:
  1. Disconnect battery.
  2. Relieve fuel pressure.
  3. Remove tank from car.
  4. Use compressed air to clean the tank, then spray with oil from an aerosol can to reduce the likelihood of combustion.
  5. Use a hammer and brass drift, turn the lock ring counterclockwise to unlock.
  6. Lift the tank unit upwards out of the tank. Tilt as needed to avoid bending the sender float. Fold the pickup screen if needed.
  7. Look inside the tank for and sediment or flotsam that may need to be removed.
  8. Unplug the tank unit to pump electrical connector.
  9. Unclamp the pump to tank unit hose and replace pump and hose.
  10. Install as reverse of above.
Mar 21, 2010 | 1993 Buick Regal
Have a Johnson 130 leaking gear oil on bottom of foot and bottom full of water
What year model? Tools you will need. (1)gear case pressure tester from any outboard dealer. why buy and not build. matching the threads on the drain plugs.(1) detergent and water in a spray bottle. troubleshooting step (1) Remove lower unit from engine as if you were changing the impeller.(2) secure lower unit in a holder so you can drain oil and do visual checks.(3)remove drain plug and vent plug, drain oil(4) reinstall lower drain plug and put pressure tester into vent plug hole(5) pressurize gear case(6)with spray bottle spray gear case at all seals and joints just like you would spray a tire looking for a leak. detergent will bubble at leak.(7) if you find leak at a seal were you will need to remove drive shaft or propeller shaft you will have to buy removal tools and a Clymer repair manuel from your local dealer.(8) hopefully the leak is at the shift shaft or the drain and vent plugs so you wont have to buy special tools to replace seals.(9)if you find a crack in the case have it welded at you local outboard dealer
Nov 03, 2009 | Boating
My gas pressure washer fell in the pool while running. Is it a goner?
Maybe, there is a slim chance it died before sucking water into the cylinder and cracking the head. To try and fix it drain out all motor oil buy a can of carburetor cleaner and spray the engine out remove the oil plug and the spark plug and spray some wd 40 into the spark plug hole, replace the air filter dry the spark plug and clean the fuel tank and replace the fuel filter inside the fuel tank replace oil with fresh oil and then give it a try. You’re out $20.00 but if it runs you are one lucky person.
Sep 23, 2009 | Honda Garden
Solo 425 and 475 spray packs.
I have a 425 that I have had to remove the pressure cylinder. I found this on the internet one time, but can't find it again. Anyhow, this is how to remove the pressure cylinder on a Solo 425. Do all the disassembly instructions in the owners manual. Then get a short 2x4 or 2x2 and place it on top on the pressure cylinder through the opening on top of the tank. Then give it a good whack with a hammer. Don't be shy, that ****** is in there. It may take more than one whack. Once you have the cylinder out there is a screen on the cylinder that must be cleaned. To re-assemble, turn the sprayer upside down, insert the pressure cylinder, lay the 2x4 across the bottom of the cylinder and use even force (and hammer) to force the cylinder back in. Stop when you get to the O ring seat and you can do the rest by hand, being careful not to pinch the O ring. I have had Solo sprayers for many years and think they are great. But when it seems that when I leave glyphosate (Roundup) in the sprayer it clogs the screen. My hard water may contribute to the problem.
Mar 27, 2009 | Solo Backpack Sprayer
Sprayer wont spray or hold pressure
We use the both the 425 and 475 solo sprayers most days at work and when they start to lose pressure ( after 6 months of daily professional use) we purchase a complete seal kit and put it through them. The only part I can't work out how to remove is the inside cylinder, other than that everything else is easily removed and replaced.
Jan 14, 2009 | Solo Backpack Sprayer
Immediate pressure loss
your dip tube inside the tank has come loose or has a leak near the top. instead of fluid being pushed up the dip tube into the wand hose the air in the tank is just escaping. You will have to remove the wand hose and figure out where the leak is and fix the dip tube.
Nov 18, 2008 | H.D. Hudson 2g Yard N Garden Sprayer
Solo 475 Backpack Sprayer Back Pack Sprayers Logo
471 people viewed this question
Top Solo Garden Experts
Jim Parker
Jim Parker
Colin Stickland
Colin Stickland
Are you a Solo Garden Expert? Answer questions, earn points and help others
