Question about Hitachi C29-F300B 29 in. Television
My hitachi tv model no.C29-F300B ,in this tv set there is eht problem what can i do,EHT is not working,i was purchesd this tv set 8 years back,thiis problem is came just one month back.i live in delhi india.
  • Hitachi Master
  • 6,694 Answers
spares for Hitachi is rarely available in India. u should use the same number lot. any why try for manufacturer support
ok
Posted on Dec 31, 2010
How to change the language on my hitachi tv
Somewhere in the menu you should find the language setting if your set has it-----Typical in usa IS english, french, or spanish.
Mar 18, 2012 | Hitachi C29-F300B 29 in. Television
I have a Sony KV-35S26 manufactured Aug '97. The picture comes ON only occasionally. When it fails to come ON, the standby light blinks continuously. Sometimes, the picture comes ON initially then...
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - TV TUBE ) becomes weak - then few TVs ( not all TVs ) behaves exactly as you have described.............. .......so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching TV --- this adjustment is very important ) ----------iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com) ----- here EHT's price will be around Rs 250 ( US $ 6 ) & for my customers (in bangalore) i will take another Rs 500 (US $ 11) as service charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact TV service engineer ------- because they are highly experienced & can fix this component very easily. ------------ [[ sometimes along with EHT another component called transistor ( big in size - situated close to EHT - it will have 3pins - its size will be 1inch X 1/2 inch X 1/2 cm --approximately ---- black in colour ----- fixed to aluminium metal ) --- will also gets deffective --- so this component also should be checked ]] ---- in your case this transistor is good ... because when this component gets deffective then TV won't get '' ON '' .............so in your case only EHT should be replaced.........100% it works normally ----- though it is 14yrs old itseems TV TUBE is still in good condition because you have said that whenever display comes picture is clear......so if EHT ( same type) is replaced then your TV will work atleast for 2 more years.....GUARANTEE.......
May 22, 2011 | Sony KV-35S26 35" TV
I have a Mitsubishi CS-40509 TV. It is over 12 years old. Recently, there is at least a 30 second delay before the tv responds to the remote control/control panel commands. If i turn it on, the green light...
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - TV TUBE ) becomes weak - then few TVs ( not all TVs ) behaves exactly as you have described.............. .......so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching TV --- this adjustment is very important ) ----------iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com) ----- here EHT's price will be around Rs 250 ( US $ 6 ) & for my customers (in bangalore) i will take another Rs 500 (US $ 11) as service charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact TV service engineer ------- because they are highly experienced & can fix this component very easily. ------------ [[ sometimes along with EHT another component called transistor ( big in size - situated close to EHT - it will have 3pins - its size will be 1inch X 1/2 inch X 1/2 cm --approximately ---- black in colour ----- fixed to aluminium metal ) --- will also gets deffective --- so this component also should be checked ]] ---- in your case this transistor is good ... because when this component gets deffective then TV won't get '' ON '' .............so in your case only EHT should be replaced.........100% it works normally ----- though it is 12yrs old itseems TV TUBE is still in good condition because you have said that when display comes picture is clear......so if EHT ( same type) is replaced then your TV will work atleast for 2 more years.....GUARANTEE.......
May 22, 2011 | Mitsubishi Televison & Video
My Toshiba 32 inch TV has been working fine for 10 years. last week it started to make a loud crackling sound whenever it is on. it starts intermitantly at first and seems to get more regular if the set is...
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - TV TUBE ) becomes weak - then 1 of the indication is ....NOISY SOUND comes ... that is from EHT.....so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching TV --- this adjustment is very important ) ----------iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com) ----- here EHT's price will be around Rs 250 ( US $ 6 ) & for my customers (in bangalore) i will take another Rs 500 (US $ 11) as sevice charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact TV service engineer ------- because they are highly experienced & can fix this component very easily.....
Apr 25, 2011 | Toshiba Televison & Video
EHT + SUPPLY IS (55 OR 60 VOLTAGE) LOW VOLTAGE,MICRO POSER VOLTAGE IS NORMAL ON /OFF VOLTAGE NO ,RESET VOLTAGE NO , N O RASTER WHY
EHT should be 22 - 25KV
Power supply should supply 130Volts not 55!
Check power supply feedback loop and poor contact pre set.
Jan 06, 2011 | Hitachi C1478FN 14" TV
My hitachi cle-947 tv changed his language and i dont know how to change it to english
you can get to the setup menu by pressing the menu button 4 times. The first item in the menu should be language.
Sep 16, 2010 | Hitachi C29-F300B 29 in. Television
Hitachi model # C29-F300b 29 in
Just went through this. What you need is an adapter between your cable and the TV:  Male European Cable converted to Female American Cable
http://www.110220volts.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=Male&Category_Code=
Hope this helps.
Jan 10, 2008 | Hitachi C29-F300B 29 in. Television
Brought set back from Europe
you have to set it to 4.5MGh from 5.5 MGh
Sep 29, 2007 | Hitachi C29-F300B 29 in. Television
Hitachi C29-F300b television
found a sevice manual at manualsnguides.com but they asking 27 bucks, a buck something shipping. I dont have the manual or know a hatchi dealer closeby. good luck
Aug 17, 2007 | Hitachi C29-F300B 29 in. Television
Hitachi C29-F300B 29 in. Television Logo
126 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
