Question about Epson PowerLite Home Cinema 1080 UB LCD Projector
I can't change the aspect ratio on my 1080 UB. It's locked in the "normal" view? How can I override this?
  • Epson Master
  • 6,694 Answers
first of all check the video setting of ur DVD player or satellite receiver which ur connected to the projector. in its video setting select output video format aspect ratio as 16:9. the projecter will output the format what it get in its input.
u can elect the aspect ratio in the projector remote just press the ASPECT button to select different format
ok
Posted on Dec 31, 2010
How can I change the screen size on my emerson 55 in tv with my remote contrl
Try:
1. Open the Main Menu (which is by the way the left arrow)
2. Choose settings
3. Press ok
4. Choose Television and press the right arrow 6 times
5. Choose view all and press ok
6. Choose Screen Aspect Ratio and High Definition and press OK
for this step you will need to know what type of display you have:
If you have a...
4:3 standard definition for an ordinary TV
Widescreen standard definition for a widescreen TV (16:9 aspect ratio) that doesn't display HD
720p on high-definition screens for an HDTV with 1280 x 720 resolution
1080i on high-definition screens for an HDTV with 1920 x 1080 resolution
1080p on high-definition screens for an HDTV with 1920 x 1080 resolution and progressive scan (also known as "Full HD")
I can't really help you with this, try looking in the maunal, but you can test it by...
7. Choose continue and press ok
8. On screen instructions will be shown on how to test your resolution
I hope this helps!!
Mar 30, 2017 | Emerson Televison & Video
Adjust the video height on MAG lt716s computer monitor
don't worry overly, the shapes of things will be altered as you change the resolution. The main preset resolution s have different
aspect ratios
1920 x 1080 is 1.77/1
1600 x 1200 is 1.33/1
you change aspect ration according to your selected resolution.
Your monitor will have a native resolution at which everything looks normal, .......If you vary from that resolution things will obviously change.
Jul 16, 2015 | Computers & Internet
I cant get picture to fit screen. like when news is on the words on the bottom dont fit
Sounds like the picture is Zoomed. Note it. Refer its user manual to get details to make it to Normal state. Electro help
Feb 18, 2015 | Televison & Video
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
Power and OPC blinks, TV will not change Input modes
Try removing set and or a box if used from power for several minutes.
Dec 23, 2012 | Sharp LC-46SB54U LCD TV 46 inch Class,...
Philips remote control not working
have the remote tested, any repair shop can do this and usually for free.
If remote is good the receiver in the set is likely bad.
Nov 27, 2012 | Philips 47PFL3603D/F7 LCD HDTV, 47...
Picture not to edge of screen
That is because you are watching the picture in the 4:3 aspect ratio. This is normal when you are watching a channel that is being broadcast in 480 or digital. But once you tune to a station that has 1080 or at least 720p which is true high def then the picture should expand to 16:9 aspect ratio. It will switch between the two automatically as it determines what type of signal it sees. You can force the resolution to change by pushing the format or aspect ratio button on the remote but you will lose picture quality.
Jan 11, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Aspect Ratio not responding/always in "Full" mode
Normally, when I see this problem in the customer's home, I find the main culprit to be the cable box. The remote for the cable box may have a button on it to change the format or picture size. You may have to go into the menu of the cable box to change the format setting. Hope this helps.
Apr 22, 2007 | Panasonic TH-42PWD8UK 42 in. EDTV-Ready...
Epson PowerLite Home Cinema 1080 UB LCD Projector Logo
408 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
