The fridge isn't cooling though the freezer half is working fine. It was recently transported quite a distance in its side (well braced and padded), and left to stand 20 hours before being plugged in. We have unplugged it and will let it stand 24 hours before trying again, but don't think that coolant and oil mixing is the problem since the freezer works fine. What else could it be?
  • 2,133 Answers
There are 2 reasons. While transporting if they lifted with won wards to discharge side, chances are there to oil entering. And while switch on it starts pumping the oil.Secondly, chance for gas leak.
It's advisable to remove gas and check for leak. If no leak, flush out the system and replace drier.
Vacuum and do gas charging. Please write if it's helpful.
Posted on Dec 31, 2010
I have a side by side ref/frez Amana ars266zbw the freezer works fine but the refridgerator isn't coolig
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 12, 2011 | Amana ARS266ZBS Side by Side Refrigerator
My refrigerator isn't cooling. The freezer is working fine though. Any suggestions?
heatman101
Jul 07, 2011 | Refrigerators
Freezer works, but has some ice forming and refrigerator not cooling.
The refrigerator half of a refrigerator/freezer does not produce any cold! The refrigerator is cooled by transferring air from the freezer to the fridge. The fridge temperature setting controls a flapper between the freezer and the fridge. There should be a fan which blows air from the freezer into the fridge (through the damper).
If the ice forming in the freezer is concealing the cooling coil and air can not move through the coils, then the overall result will be a warm freezer (even though there may be ice in one location) and a warmer yet fridge. This can be tested by unplugging the fridge and allowing a complete thaw. If the ice is the cause of the problem, then it should work for a short while until it freezes up improperly again
:o).
Jun 04, 2011 | Whirlpool GB2FHDXWS (63 cu ft) Top Freezer...
After relocating refrigerator, no cooling, middle panel very hot
Hwne you had moved the fridge it is quite possible that there could have been a damge to the compressor or the piping resulting in the gas leaking off. This must be confirmed , if so refill gas properly with the help of a technician. Next solution also could be if the fridge had been been transported upside down or side ways. If so the oil inthe compressor would have gone into the system and choked it. For a trial put off the fridge for about 24 hours so that all the oil drains back to base. then test it to check if the cooling comes back. Since I presume prior to your moving the fridge was working fine, the areas of fault could be these two factors. I hope you can check this up and decide . If not ask for a quote on the fault and we can review. I Hope I could help. Good day
Jul 21, 2010 | Amana 22.6 cu. ft. Side-By-Side...
My freezer side isn't freezing. fridge side seems to be working
If it worked fine to them, look at the heating and cooling C. in the back of the frig. Depending on how you transported it and how many bumbs you hit could of damanged them
Apr 03, 2010 | Amana SXD524VW Side by Side Refrigerator
Fridge/Freezer - fine bottom half, warm top half
Sounds like the fan in the freezer is not working ( pt# WR60X190 ) .
Jul 30, 2009 | Refrigerators
Freezer and fridge not cooling (halfway)
SxS Amana upper half of feezer and Refrigerator not working
Jun 22, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Red alarm light is on on Westinghouse upright freezer
Most probably during transportation either the coolant(previously freon gas) may have leaked out so the pressure on the cooling pipeline causing the red alarm because the compressor will overheat if the fridge is kept running at very cold thermostat readings and no effect of cooling the fridge will ultimately result in the compressor getting burnt. However fist have look at thermostat setting knob which could have loosened during transportation and just pushed into the spindle without knowing the correct angle, thus even though it looks as if on high cool but could also be the lowest setting..........sodeep
May 19, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
