Question about GPS
I own Hyundai Terracan. Which has a run time error code named as P1300.As my car is running with missfire i think that it should be the problem of P1300 Injector Specific Data Fault accordin to the error code list by hyundai. My VIN no. is KMHNM81XR4U40934 And the list of my injjector no. are listred below : IN which injector no.1 & no. 3 are missing 1: ACBDE41 2: A8C664E5C64E73F3 3: E8D98 4: 6CBA245EB9DDAE6D
  • 147 Answers
SOURCE: error code 51 (injector circuit) on 1994 nissan se v6 pickup
I would start by checking the resistance of all of the injectors. I saw this happen last week, I had a new injector that was reading low ohms and it was making two cylinders misfire. Replace the new one with a another new one and both cylinder ran good. I dont know what the ohm value of your injectors should be but I would want at least 10 ohms, All of them will be about the same except the bad one..I did a web search on your problem and it was covered at several places.
Posted on Oct 02, 2008
SOURCE: 05 Hyundai Terracan transmission temp ecu code
gentle men
I'm having a problem with a hyundai santa fe that will not start.
new crankshaft and cam shaft sensor
tried a tucson ecu and still won't start
HELP
Posted on Nov 21, 2008
  • 225 Answers
SOURCE: My 96 honda accord is giving me three different
I would start with a full tune up. If it has never been done then that is the best way to start. Make sure that you gap your plugs. NGK plugs are the best for any and all Honda's. Let us know how it goes.
Posted on Aug 30, 2009
SOURCE: side light bulb change on hyundai terracan
hi there
the solution is simple,
you only need to undo the screw on top of the side light/indicator. then facing the head light place a flat headed screw driver under the bottom lip of side light. the bottom of the lihgt is on a small push fit stud, use a sponge or cloth to protect your bumper paint work then just apply pressure gently to lever side light out towards you, It will come dont worry, you may then change your bulbs if you wish remove the whole light unit you will see the bottom bolt as soon as you release the side light. to replace just push back into place then replace screw. whole job takes about five minutes
hope this helps kevan hildred
Posted on Jan 28, 2010
  • 37 Answers
SOURCE: number one injector bank on 2006 dodge cummins
you'll notice on your valve cover gasket there is two connectors.. the one up front is your 1-3 the one in the rear is your 4-6... you can remove your valve cover and check the connections from the injector connectors to the
connectors on the valve cover.. check for an open.. however you could also have a fault internally in 1 of your injectors in that bank as well.. hope this info helped..
Posted on Feb 03, 2010
05 Hyundai terracan 2.5 d it sounds like it's running on 3 cylinders rather than 4
Have you run a fault code test? Is the check engine light on in dash?
May 24, 2016 | Hyundai Cars & Trucks
HYUNDAI TERRACAN LOSING POWER... Hi, I have a 2002 Hyundai terracan that has been losing power. along the highway and straight roads it was fine but on an incline it loses power and now has a job to do...
run the fault codes for an exact diagnosis but from your description of the problem I would be looking at a failing cat converter as it may be blocking up the exhaust system
Dec 14, 2014 | Cars & Trucks
My Terracan normally starts on the 2 nd turn of the engine. All of a sudden the engine just turned without starting at all. I waited till the next morning and tried again. It start immediately. I let it...
That code would have been "camshaft position sensor". They may have replaced the old one with a faulty new one, which might account for the blown fuses. Have them try unplugging it to see if it stops blowing fuses. If it does... have them replace that sensor again with another new one.
The replacement they used MIGHT not have even been NEW - it might have been salvaged from another vehicle... or they might have used the wrong one for your Terracan. How much do you trust that shop? You might have the Terracan towed to a different shop if you're not pretty confident about their competence.
Aug 04, 2014 | 2005 Hyundai Terracan 2.9
Why terracan spark timing p1300 fault
a Hyundai Terracan????????
what year, must we guess that too, and country? and engine size option too?
i think that is random misfire.
what is the question,
how to diagnose it?, read the FSM.
or who can fix it, answer any ASE mechanic on earth can.
open the FSM what does it say about 300s.
all say the same thing. MISFIRE GROSS and random cylinders.
and can be bad engine compression bad ,bad spark or bad fueling.
top causes. (not a guess, )
1: never ever doing the 60k mile service, not EVEN new spark plugs.
2: lean AFR. (1 example, low fuel presssure) for dirty MAF if it has one.
3:rich Air fuel ratios. (or flooding) causing misfire, high fuel pressure.
too high, (horrible clogged up air filter? extreme)
4: cam timing way off, cam belt slip or even a chain, if deaf.
#4 cause huge drop in compression.
That is the why, there are more.
why not get the car scanned and check out for if the engine
needs help or sensors read wrong using a SCAN TOOL.
does cooling system (engine) hit 180F or more. hold there.
if not it will rich misfire.
using a real scan tool shows all DTCs codes stored. other wrong or cheap tools will miss lots of factory code.s
good luck.
May 23, 2014 | Cars & Trucks
P1300
Error Code: P0301
Description:
Cylinder 1 - Misfire Detected
Possible Cause:
Wiring.
Ignition system.
Fuel injectors.
Fuel pressure.
Running out of fuel.
EVAP canister purge valve.
Evaporative emission system.
Low compression.
Base engine problems.
Engine control module (ECM).
Error Code: P0302
Description:
Cylinder 2 - Misfire Detected
Possible Cause:
Wiring.
Ignition system.
Fuel injectors.
Fuel pressure.
Low compression.
Error Code: P1300
Description: Random Misfire
Possible Cause:
As above.
Jan 22, 2014 | 1996 Honda Civic
My 96 honda accord is giving me three different code readings they are: P0303 cylinder 3 missfire, P0302 cylinder 2 missfire & P1300 multiple missfire detected, How do I fix this problem?
Aug 30, 2009 | 1996 Honda Accord
2005 hyundai terracan loss of power on faster journeys
check transmission sensor, I hope is not time for a new transmission
Jul 25, 2009 | 2005 Hyundai Santa Fe
I'm having a hard time to fine that code, but I'm still looking.
Cheer
Aug 30, 2008 | 2005 Hyundai Tiburon
GPS Logo
364 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
