Question about Samsung Galaxy S GTI9000 Smartphone
Phone is locked it wont except my google account
    Sergeant:
  • 242 Answers
Sir please call to the related simcard customercare and say the last 6-digit number which is present before the simcard. then they will give the pukcode number to unlock the cellphone...........
Posted on Dec 31, 2010
5 Suggested Answers
SOURCE: i can't open up my g1 android phone. how could i
i put my password to much wrong my phone lock
Posted on Feb 04, 2011
  • 5 Answers
this happend to me too, except it happend when i put the wrong lock patter in too many times. the reason it wont access ur google account is probably becuase u either dont have internet or no wifi where u are at. so go to a place where they have wifi and try there. or call tmobile tell them u forgot ur password and dot have internet and see if they can help
Posted on Nov 14, 2009
  • 90 Answers
SOURCE: my daughter entered the wrong
For all android devices a google mail account is needed for purchasing apps etc. if he did not set this up and had set the pass code without the email specified the only way to get back into the phone would be to do a complete reset. Before you do this have you tried restarting the device and seeing if it gives you the ability to try to enter the code again, if not here is how to do a factory reset. As stated below this will delete everything on the sd card so i would advise you copy all the files from it onto your computer. the entire process should only take about 10 to 15 minutes depending on the phone sometimes less than this, good luck!
Performing a factory reset (hard reset) If you're passing your phone on to someone else or your phone has a persistent problem that cannot be solved, you can do a factory reset (also called a hard reset). This returns your phone to the state it was in before the first time you turned it on. Note: Factory reset will not remove the data and files that are in your phone's microSD card. Factory reset is not a step to be taken lightly. It will permanently delete all your data and customized settings, and will also remove any applications you've downloaded and installed. Be sure to back up any data and files you want to keep before you do a factory reset. Performing a factory reset using phone buttons If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the buttons on the phone.
  1. With the phone turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button. Note: If you are not sure whether your phone's power is turned off, remove and then reinsert the battery.
  2. Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button.
  3. Press VOLUME DOWN to select CLEAR STORAGE, and then press POWER.
  4. Press VOLUME UP to start the factory reset.
Posted on Mar 27, 2011
  • 93 Answers
SOURCE: phone is locked and it
pull the battery out and put it back in... While holding the green button also hold the volume down and press the red key too. (all 3) and this will bring you to a menu where you can erase and start all over. Rate me well and leave testimonial!
Posted on May 11, 2011
Samsung j3 emerge #sm-j327p unlock google verifacation frp
I'm assuming you mean its google locked. This is because you removed the previous owners google account from the phone without them removing the device from their google account, so it gets locked for privacy by google. This is a common problem now and a big reason i tell everyone to stay away from a used smart phone unless you buy it from a reputable shop that will stand behind it. There is nothing you or boost can do, it will require the previous owner to login to the phone with their google account and remove the device from their google account, then it can be set up with a new google account.
Jan 11, 2018 | Samsung Cell Phones
What to do when my phone has ben hard reset and I cant get in with any goole accounts at all
When you factory reset a device that has a PIN code or a SWIPE code of some sort, the Google security lock will trigger after a factory reset. This is because the phone is assuming you factory reset it because you could not get into the phone (ie. it is not your phone / it is stolen).
At this point, you need to log into the phone with the Google account it was ORIGINALLY set up with. There are a couple of scenarios you may fall into at this point, BUT there is no way to "bypass" this security lock.
  1. If you know the e-mail it was ORIGINALLY set to, but you do not know the password, you have to reset the password (via the computer, etc). WARNING: If you reset the password, you cannot log into the phone for 72 hours (again this is a layer of security for stolen devices).
  2. If you have absolutely no idea what the e-mail is, Google is assuming you stole it. At this point you either need to contact the manufacturer / the carrier to see if they can exchange it (assuming it is your device).
Feb 23, 2016 | Google Cell Phones
I pressed too many patterns now what i have to do now
If you forget your pattern
  1. you will after 3 faulty attempts be unable to use the pattern to unlock it.
  2. Instead you are asked for your Google account and password (that is setup with the phone of course). This is where the problem starts.
For many, many users providing the username and password won't change a thing. For some people changing the password via a computer has worked but that is uncommon. Most people ends up with a very expensive paperweight. Have no fear, there are solutions to almost everything
1. Completely power off and power on your phone.
2. Right after you pass and just before the Verizon Wireless logo video ends, immediately tap on the home button extremely fast and repeatedly (at least 4-5 times per second). If the Emergency Call button pops up, click that every now and then (3-5 times) but keep tapping on the home button. During this process your phone may flash the password screen or keypad screen just a few times and your phone will seem to be lagging due to the tapping.
3. Keep tapping until you see your Android home buttons stay steady at the bottom. Voila, you're in your phone! If the emergency keypad constantly shows up or if it shows the Google account screen constantly, you have failed. The success rate can be around 15-50% so keep trying until it works. (You may want to grab a young phone-savvy guy or girl to do it if your fingers are too slow)
4. Find and run the Settings App and go to Accounts & Sync.
5. Under Manage Accounts, remove all accounts except your Google account.
6. Press your power button off and on and enter your correct Google account information.
7. It will ask for a new security pattern. Enter it twice and you are done!
This solution worked for me. If it does for you, please leave a comment with your carrier and phone model to let others know that it worked!
[METHOD 2]
I recommend the tapping method first but if that doesn't work or you don't have a home button, here is a different method to try pretty much based on the same concept. (again, will depend on app compatibility and may not work for all phones)
This method uses a free app called Screen Lock Bypass. (thanks to Michele for introducing this, [UPDATE: free version has been pulled off, only paid full version available which may or may not work on your phone. Try METHOD 3 first!]) Please use this at your own risk as I cannot be responsible for any of the results caused from using this app. Basically, you'll be using this app to bypass the screen lock and delete the other accounts blocking your Google username/password to accept.
1. Go to the Android Market download page on your desktop and install the app. (Yes, you are able to install apps using your desktop instead of your phone) Direct link:https://play.google.com/store/apps/details?id=net.thomascannon.screenlockbypass.fix (note: You need to login to the Android Market using your Google username and password that you used when you first set up your phone. This is the username and password that "should have" unlocked your phone in the first place.)
2. Select the phone you have (this is why you need to login with the right Google ID) and install the app. Wait about 5 minutes or restart your phone and wait a good amount of time for the app to fully install.
3. On the app instructions, it says to install any other app to trigger the Screen Lock Bypass app. I did not do this but for me, restarting the phone, waiting, soft off and on seemed to trigger it. (may have been triggered by a message though, this is the part where it unexpectedly blanked and disabled my screen for a good while.)
4. If it worked and bypassed the "too many pattern attempts" screen, go to phone Settings and then select Accounts & Sync.
5. Under Manage Accounts, remove all accounts except your Google account. (this should enable your Google username and password)
6. Go to Settings and select Applications, then Manage Applications.
7. Find Screen Lock Bypass and uninstall the app. (this will trigger the "too many pattern attempts" screen immediately)
8. Use your original Google username and password to finally unlock your phone properly.
9. Enter your new security pattern twice to finish!
If Method 2 worked for you, please leave your comments with your phone make and model to let us know!
[Method 3]
This was suggested by commenter Guru and has potential to work with all phones as it was claimed to work with the Galaxy S2.
Pre Condition: You remember the pattern and you remember your Google password and Android account is listed while using instructions below. Data services (Wi-Fi or mobile) should be enabled.
1. Using your computer, log into your Google account. You can verify your correct Google account using the Additional Tip at the bottom of this article.
2. Go to this link directly - https://accounts.google.com/IssuedAuthSubTokens OR click your Google e-mail on the top right corner, select Account settings, then hit "Visit the previous version of the Google accounts screen" towards the bottom, click "Authorizing applications & sites " under your Personal Settings > Security.
3. Under "Connected Sites, Apps & Services - "Revoke Access" of your Google Account with Android. You will see the screen showing "You have successfully revoked access to Full Account Access"
[Alternate for step 3 - If you have already signed up for 2-Step Authorization previously and are able to generate a new application-specific password at the bottom, go ahead and generate a new password and use that password to unlock your device]
4. Enter Gmail login and password on your phone. It will now accept your login details and will show a pattern screen. Enter the "correct" pattern and you can see the home screen.
Again, if this works for you, let us know!
Good Luck!
Feb 09, 2015 | Cell Phones
My Samsung 5 went dead I charged it it wants My Google Password it wont accept it.my email fimcord207gmail.com.I been using my sons ph but it wont let me except email could you call 5415153900 please
The Google passwords that it wants is the owners account, if you are the owner, then you should have no problem with it. To use the email on your son's phone, you must first deactivate your son's account and set up yours.
Now, if you have a Samsung S5, all you need to do is to hard reset your phone. You can do this:
Make sure your phone is off.
Press and hold home>volume up>power button at the same time until you see the Samsung logo come up.
You should be in the recovery section, with the volume down rocker, scroll down until you see "Wipe/Format Data". Press power to activate.
This will set your phone back to factory default, press power on Reboot Phone. And that's it, you have to start setting up your phone, so before hand make sure you have the Google password ready (google account). Good luck.
Oct 10, 2014 | Cell Phones
My phone is locked and ask for a google account, and i dont know my account
You can Google contact Google and a page will come up with links for contacting them. There is one link called "3 Ways to Contact Google" by WikiHow. Hope it works for you.
Apr 20, 2013 | Sprint LG Viper 4G LTE GSM Smartphone -...
Tablet wont access anything google
It seems that you have a firewall setting not allowing you to google.
Open your antivirus or firewall settings and ADD an exception for Google.
If you could give more details on the Tablet operating system and antivirus, I could help you more.
Nov 21, 2012 | Computers & Internet
Wont except my google account to unlock ZTE avail Z990 phone
i cant access with mu google acount after i have releasez so many times wrong pattern
Jul 27, 2012 | ZTE Avail-Z990 Avail At&t Unlocked Android...
How can i get in my google account from my android HUAWEI smartphone
Follow these steps:
Settings > Accounts & sync > Add account > Google > Create or Sign in
I Hope It will work
Mar 14, 2012 | Google Android
Brother try to geust my password and phone is locked and need an google acount have on with the phone but wont accept it help?
Try resetting your google account password by going to https://www.google.com/accounts/recovery
Then after you have reset your password on a computer, try the password on your phone.
If that doesn't work try this:
Have someone call your phone.  Answer.  Leave the call connected. Push the "back" key over and over (NOT the home key) while leaving the call connected.  Keep the keyboard retracted.
Go to the home screen, go to settings, google account, add another google account, sign in to that--- (must have wifi connected, as you're trying to communicate with the google servers while you're on a phone call-- it will prompt you to turn on wifi if you forget)--  then end the call, and go back to the lock screen.  This time, I use the google account that u just added.
Mar 02, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
I can't open up my g1 android phone. how could i access the lock. it says that i need to sign in to google account. i do have an google account but when i sign in my account it doesn't open.
Aug 31, 2009 | Cell Phones
Samsung Galaxy S GTI9000 Smartphone Logo
63 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
