It gets black as though it is working properly then it stops functioning saying E001
  • 27,725 Answers
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
once you have your computer running
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
if this fails
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your hard drive from the motherboard or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Dec 31, 2010
How to fix the Canon Image Class Printer 4750 error code e001-0000
Canon IR2270/IR2870/IR3570/IR4570/IR5070/IR5570/IR6070/IR6570
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
for more details : www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
Jan 04, 2015 | Canon Office Equipment & Supplies
My canon C3170i shows error E000001-0010
Product : imageRUNNER 5070 / 5570 / 6570 Title : Fuser noise and intermittent E001 code Error
The upper fuser roller section makes a noise and intermittently error code E001 occurs Workaround : In this case, the UFR Shutter inside the upper fuser roller was installed reversed (180 degrees out of postion). Installing the UFR Shutter in the proper orientation corrected the problem. Note: the UFR shutter installed in the reversed position will cause a noise and block the Main Thermistor when the shutter should block the Sub Thermistor. In turn, the shutter will block the Sub Thermistor when the shutter should block the Main thermistor. This will cause improper temperature for the Upper Fuser roller and cause the error code. suggested to go in service mode and reset the error, and see if it will solve the problem. If the problem presist, a code will appear and that will be the one we should work on. So we did clear the error, and the machine is functioning.
Entering service mode: press Additional Function > press 2 & 8 at the same time > press Additional Function again Clearing the Error: press Copier > press Functions > press clear > press Err > press Ok. Restarting the Machine:Power off then On.
Oct 12, 2011 | Canon Office Equipment & Supplies
Canom imagerunner 2520 error e000001
the e001 is error for the temperature rise detection in fixing unit. There are more sub codes that I need to know for precise troubleshooting. i.e. E001-000 or E001-001 or E001-002
But if there is no fault in components, you can try to reset it in service mode.
Procedure:
additional function, then press 2 and 8 then go in clear by pressing scrolling, then go in engine, then choose ERRCLR and then turn off and on the copier.
If these doesn't helps you need to replace fixing film unit.
Aug 29, 2011 | Canon 0000A011BA Copier
ERROAR E001 AND E808
u can clear E001 in the service mode Press * 28 * go to clear press OK then err press OK . and the E808 is the cooling fan malfunction .it can be because of the erratic power fluctuations or damaged fan.
and the if E001 happens during copying then u have to check the fusing unit as sometimes the pressure roller bush gets misplaced from original position causing jam and code
Aug 03, 2011 | Canon iR 2016i Black and White Copier
Fifa 11 starting time say e001 error
E001 error for FIFA 11 - Means your Graphic card is not supported in playing the game. You need to upgrade your Graphic card which support at least the "Shader Mode 3" function.
Most of the onboard graphic cards does not support this function and you get the E001 error when you play the game. Updating your DirectX or graphic card drivers is no help at all because is a hardware compatibility issue.
Hope it helps.
Mar 04, 2011 | Computers & Internet
How to clear code on ir 3235?
wich code?
E000, E001, E002 You can clear under service mode:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
TURN OFF AND ON
Hope that helped
pls.rate
Apr 17, 2010 | Canon ImageRUNNER 3235 Black and White...
New ink printer says its out of ink
Sometimes you can clear that error by holding the cancel or stop button as you power up. Make sure that all inks are installed properly first though.
Oct 09, 2009 | Brother MFC-425CN Multi-Function Center...
E001 switch off the machine and on again
E001 is a fixing assy fault you have to clear the error in service mode after correcting the fault of course. I would try clearing the error code in service mode 1st. press *28* function tab clear tab error ok then restart copier
Sep 09, 2009 | Canon imageRUNNER 400S Copier
Error codes
E000 and E001 is due to the laser unit, I can explain in more details.
E014 is due to the Dc motor failing
Hope this helps?
Oct 17, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
E001
That is a fuser realted issue. Not warming up properly.
Most likely a defective fuser. The over heat has opened, the heat element has gone bad.
Fuser more then likely needs replaced
Jan 15, 2008 | Canon NP 6545 Copier
Computers & Internet Logo
David Payne
David Payne
