Question about Toys
My cicciobello doll is 6 days old, and the injection site isnt working.....what do i do?
My daughter has had cicciobello doll for 2 weeks. The mouth button will not come out after removing the dummy.
Probably you can't fix it. Toys are mede to de disposable and parents blame kids for not caring. If you bought it just 2 weeks ago, you should return it for change to the shop where you bought it because it's obviously defective and I presume it should have some kind of warranty
Jul 26, 2015 | Toys
Doll pig knit doll blabla
http://www.shopwiki.com/l/Mini-rosalie-piggy-doll-from-Bla-Bla-kids
Jan 03, 2014 | Blabla Rosalie Pig Knit Doll
Water Isnt Getting Hot
Could be that the plumbing got clogged while the system was idle
May 13, 2013 | Sta Rite Pool & Spa
How do i check if my fuel pump is working on a 1998 flhtcui
Hi Anonymous, when you turn the ignition switch to the on position you should hear the fuel pump prime, if not check the system/fuel pump relay behind the right side panel for continuity. Good luck and have nice day.
Feb 29, 2012 | Harley Davidson Motorcycles
I have a audi a3 2000 w reg 1.9tdi the problem is its hard to start in the morning when i get it started it runs perfect then if i try to start it hot the problem is the same takes a few goes to fire up ....
i think the problem is the injector pump ,this isnt common rail as yet for this age vehicle and when its starting its not throwing the auto start mechanism into play which makes it over inject fuel ,remember the old transit with the inline injector pump,lift bonnet pull throttle and push button in ,then it would go first time .well its the smae thing buts done electricaly ,only solution is to put car into a bosch injection specialist and have the pump overhauled ,lots of cash though,or use a can of brake and clutch cleaner --- and thin pipe into teh air intake and spray some of the cleaner into the air intake ,brake and clutch isnt as harsh as easy start andf their is a nozzle on the can so the pipe pushes onto that ,just like the old perkins diesels in the transits in the 60s only it was a plunger on the dash in them days .
Dec 23, 2010 | Audi A3 Cars & Trucks
I have a '99 Ford Crown Vic Police Interceptor, and its not getting gas to the engine. I replaced the battery, fuel filter, the entire fuel injection assembly, made sure all pumps and wires were plugged...
you will need to change the fuel pump had that problem with one of the customers,if my info is of any help to you please leave me a comment,thankyou.
Sep 02, 2009 | 1988 Ford Crown Victoria
Have an 85 camaro 2.8, 5 sp and theirs no spark
theres ur problem. u have a 6 cylinder. drop a v8 in and you should have no troubles
Mar 15, 2009 | 1984 Chevrolet Camaro
My idog amp'd wont play music.
is it connected to a ipod or zune or any mp3?
Oct 20, 2008 | Hasbro I-DOG AMP'D
C330
Go to the Garmin site to see if you have to pay for this update. Enter the unit serial number to find latest update for your unit and if you haven't register your unit then register it to see if you are eligible for a free upgrade. If your registration is over 6 month old then most likely you will have to pay for the upgrade1e40710.png
Dec 26, 2007 | Garmin StreetPilot C330 GPS Receiver
Toys Logo
130 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
