Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
Hello. I just purchased my Kitchen Aid Professional 550 HD last Sunday from Costco. I've used it four times and tonight we noticed that the two thin rings (one black) just above the beater shaft are out of their place. The black one looks like it will fit into a groove on the shaft, but it is tightly lower than the groove.....a very thin washer sits loosly above it. We can't budge the black piece.
What I think you are describing is the snap ring (black) which you cannot move and the washer controlling the up thrust of the mixer. The black snap ring is usually a tight fit into the groove on the shaft and shouldn't move. The washer right above it is required to be there enabling the mixer to used with a spiral dough hook. The spiral dough hooks cause upwards pressure on the gear train that does not exist using a c-type dough hook. I think you mixer is fine............leave it alone, that's the way it was designed.
Posted on Jan 14, 2011
How do I fix a kitchen aid mixer that possibly shorted out?
Buy a new one quick. Or hide. Spent . electrical engineering. And supply of new diodes resistors and capacitors are needed.
Apr 17, 2016 | KitchenAid New Professional 5.5 QT...
I need a new worm gear for my Kitchen Aid kp2671xcv but I think that model is discontinued. Can I use a worm gear from a similar model?
This is the Professional 6 quart model and parts are available for it.
I can send you a PDF file of the service manual if you will contact me at srbell@myfairpoint.net.
Oct 11, 2014 | KitchenAid KP2671 Mixer Transmission...
Model 4ksm900b
Google Kitchen Aid in your home country.
Jul 30, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
My kitchen aid professional hd is bottoming out?
If by bottoming out you mean that the beater is nitting the bottom of the bowl, check your owner's manual. There is a screw adjustment that will correct this.
Jul 16, 2014 | KitchenAid Food Mixers
Kitchen aid hd professional mixer problems with speed controls
you need a new speed control board, easy fix about $35.00 for the part and an hour of your time, not even messy to do a total of six screws and four wire connections that clip on, several youtube step by step instruction videos available. parts available on ebay. let us know if this helps you
Jan 28, 2013 | KitchenAid Food Mixers
We just purchased the custom kitchen aid stand mixer on a boxing day special. We used it tonight to make cookies and then could not remove the bowl from the base. We are going to try the icecubes. If this...
The bowl screws into the base and can get quite tight if the mixer has been turning thick dough or other mixes. We usually tap the handle on the bowl with the palm of our hand a few times and that generally frees it. The other posibility is that the bowl was put into the base slightly askew. This could be more of a problem as this can cause the base plate to get damaged. Usually though if this happens you would have noticed some bad noises almost instantly you turned the mixer on.
Dec 29, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Kitchen Aid Mixer
good day,
hope this link below will solve your problem.
kitchen appliances
Apr 08, 2009 | KitchenAid KP2671 Professional 6 Series...
Kitchen aid mixer, voltage issue
i want to buy a kitchen aid
and i was wondering about the voltage since i'm in Qatar
and i found this answer , Hope its useful
http://www.110220volts.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=750-WATT&Category_Code=DownVoltageTransformer
Nov 10, 2008 | KitchenAid KITCHEN AID 5 Quart Artisan...
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
978 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
