I need to know my ip adress and all that stuff?? help please
  • Jeffrey Groves
    Jeffrey Groves Dec 31, 2010
    Please provide the make and model number of the device that you want the IP adddress of.
    Novelist:
  • 125 Answers
Inorder to find the ipaddress of your computer follow these steps,
1. Click on start? Go to All programs? Accessories?Command Prompt
2. You will find a black screen which is the Command prompt
3. In the command prompt you will find a blinking cursor , there you type in "ipconfig/all" (without cotes)and hit enter.
4. You will find ipaddress, subnet mask, default gateway , mac address/physical address and all other information of your comp.
Thanks in Advance!
With Regards,
Prema
Posted on Dec 31, 2010
  • 6,487 Answers
If you want to know some network settings like the IP address of your computer and your router , you can do that by opening command prompt.
Follow these procedure , Click Start > Programs > Accessories > Command prompt once the black window is open type this command IPCONFIG/ALL and hit enter that will show all the details including the computer IP address and the router IP address which is also called Default gateway.
Remote connection
You cannot connect to 192.168.1.150 from work. Thats an private adress. You need to know your routers public ip adress to connect to it. The correct port in your firewall (ie 80) also needs to be opened
Jan 17, 2014 | Night Owl Optics 8 CHANNEL H264 DVR WITH 4...
That is not a valid IP address. Whois returns the error "malformed address"
Jan 17, 2014 | Computers & Internet
I'm using ricoh aficio 2045e, it's not printing! I think because I don't have the hostname or the ip address and I don't know from where to get it?
Enter in SP mode and print the ALL SMC report .In this report find the IP adress.Enter in your PC printer device the IP adress.
Feb 17, 2013 | Ricoh Aficio 2045e 2035e Copier...
HP 1312 printer running wirelessly from a laptop (Windows 7). Has always worked fine. Turned printer off when we were on vacation; now printer is "offline." Have reinstalled printer driver and...
Hi!
The problem you described can have multiple causes.
But one is more common:
Every device on your home network (wired or wireless) has its own IP adress. Usualy this IP adress is given automatically by the DHCP server contained in your wireless router. When a device is turned off for some time, it can receive when turned on again another IP adress than before.
So, if your printer has no static IP adress (entered by yourself during printer setup), it is very likely that it has now other IP than the address known by your computer. The computer sends the print jobs to the old adress and of course, nothing is printed.
Please check in your printers proprieties the adress of the TCPIP port assigned tom it, and also check on your router's management site what clients are connected to it.
The network communication between the computer and the printer can be checked by issuing a PING command from a command prompt.
e.g ping 192.168.1.***
the numbers are one example of an IP adress.
Please let me know if it helped, if you need more help ask again, I'll be glad to help you to get the problem solved.
Regards,
Bogdan
Aug 21, 2011 | Office Equipment & Supplies
Can't get windows xp home edition to recognize wireless printer, even after assigning printer TCP/IP address. Windows 7 computer prints to it, but the Windows XP computer can't even find the...
Hi!
You din't wrote what's the model of your printer, but I think we can find a solution:
1. Try to ping the IP adress you assigned to the printer. If that works, please download the latest drivers or installation software from the manufacturer of your printer (or second option use the installation disk that came with your printer). If it does not reply to ping, be sure the IP adress you assigned to the printer is in same range as the IP adresses on your network.
2. It is possible that the installation software itself manage to find the printer on the network, and that means the problem is solved
3. If not, install the printer as it is local attached (e.g USB or LPT port)
4. After installing as local printer, please go to printer proprieties, go to port, choose add a new port, choose standard tcp/ip port and write for the port the IP adress you assigned to the printer.
5. Apply changes and ...that's it.
Aug 10, 2011 | Microsoft Windows XP Home Edition
Can't get access limits to work
there is no internet connectivity
check your router ip adress
check the computer ip adress is same range of router ip
if not,, please assign same range of router ip manually
please letme know this helpful
Jan 07, 2011 | Linksys WRT54G-TM Wireless Router
Ip adress keeps failing...?
Are you sure nothing else on the network your using has the Same IP Adress. If anything does, This IP will not work.
Jan 04, 2009 | Microsoft Xbox 360 Console
Help on Port Forwardsing?
Goto your ip adress (Type it in adress bar) Your ip adress is located from www.ip-adress.com type it in, A pop up should come up "ACCOUNT" And "PASSWORD" the info should be
Account: admin
Password: admin
Or
Account: admin
Password: password
Or
Account: admin
Password: (leave blank)
then, goto "Applications and gaming" click Port Range Forwarding
Should pop up, goto Application space, name it anything (ex. echolink) From 5198 to 5199 Then select Both and for the last part you have to find it from
Start> Run> Type "Command" Then hit enter
Should pop up, just hit "Enter" and alot of stuff should come up.
Like this:
Where it says IP Address... 192.168.1.2 (Will be different for you)
That is where you put it on the last blank from your portforwarding!!
Hope I helped
Dec 01, 2007 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
