Question about RCA HD61THW263 61" Rear Projection HDTV
Have an infocus sp61md10 same as rca hd61thw263 when plug in the menu channel and volume lights come on and little light to right come on the on off and bulb light do not light up . i have replaced both power boards and can't get tv to power up
  • 7 more comments
  • oketoindian Jan 02, 2011
    with plugged in menu light volume -,channel - and far right solid light stay on solid only way to grt lights off is unplug. bulb light and on off light stay dark. fan on front of big circuit boards run . nothing else comes on. have replaced both power and aux power boards
    when plugged in menu ,channel up down and volumn up and down and far right dot light stay on solid no blinking. bulb light and power on off light do not light. fanf in front of big circuit boards runs evrything else seems dead. have replaced power and aux power boards
    looks good but i know that don't necessarily mean it's good. with bad lamp will that make these tv act totally dead sound ect
    bulb looks good but i know that's don't mean it's good .will a bulb make a tv like this have no sound ect
    filiment looks good but the 2 white wires tha plug in to the bulb housing look like the got real warm and the covering on the plus is brittle
    just took another look at bulb. on side of bulb is two small holes. one has wire going to top center of bulb. the other doesn't have a wire to it. i'm thinking bulb must be burnt out looks like should have wire coming out othr hole. thanks dale..
  • oketoindian Jan 06, 2011
    just put in a new lamp and housing. no change in system same lights only other thing showing power is the small fan in front of circuit boards. am i correct that you can manueally turn on tv or do i need the correct remote, i have one ordered
    ok thanks for the prompt reply.. you don't happen to have the remote code do you .also visually looked at he board where the 2 wires that feed the lamp go. don't see any abnormal. thanks dale
    hopefully it will be in the paper work with new remote
  • 4,889 Answers
When it turns off, what is the status of the LED at the front? Does it blink or stay on? If it blinks then how many times does it blink in between each pause? Please provide this info so that we can continue with the diagnosis.
Posted on Jan 02, 2011
  • 6 more comments
  • eagle338
    eagle338 Jan 02, 2011
    This does not sound like a power supply issue at all, coz the fan is running. Have you checked the status of the lamp to see if its shattered or has a burnt filament?
    Sai.
  • eagle338
    Yes that is a possibility. If the bulb looks ok, then check the status of the filament inside. If even that looks ok then we will check the output voltage from the ballast. So let me know whats the status of the filament.
    Sai.
  • eagle338
    I have replied to that post . Please see my last response.
  • eagle338
    Just as I suspected. From what you describe, it sounds like the filament is burnt. Can you take a good, high res image of the filament and upload it on imageshack.us , and then get me the direct link?
  • eagle338
    Yes thats a confirmed case of blown bulb. You should replace it with an original lamp from the manufacturer because
    1)It comes with a 1yr warranty
    2) Cheap bulbs not only die sooner but can also damage the ballast, by putting excessive load on the same.
  • eagle338
    eagle338 Jan 06, 2011
    You obviousl;y are gonna need the remote. Try powering it p once you get it.
  • eagle338
    I am sorry. I would be lying if I say I know the code, so we are just gonna have to deal with it using the original remote
  • eagle338
    Yes good luck with the repair.
Ok I have an alpine mrv-m500 when I plug the RCA outputs from my head unit they only work if the inputs go across channels ex; left ch(1) right ch(2) or vice versa. When the RCA inputs are correctly...
what type of radio do you have? next in ur radios menu there mighht be a selection of using and amp or not u might to to adjust ur stereo selections for using amp/rca/wattage/loud.fader you get kinda where im going my kenwood and alpine both have this feature in the menu tab..goodluck
May 18, 2014 | Car Audio & Video
RCA TV picture bigger than screen
if the tv width is ok try entering to service menu (do not use remote control) as follow:
1) turn the set on.
2) press the menu button and hold it down while pressing the power button.
3) while holding down the menu button release the power button and press
the volume + button.
4) The screen will display a one line menu, on the left the parameter P00,
and on the right the value of the parameter V00
5) release buttons.
6) using the volume + button change the right parameter until 76
7) using the channel down button change the left parameter until 06 (vertical size)
8) whith the volume + or volume - adjust the screen size.
9) when your tv is OK back to parameter 00 using the channel up button.
10) press menu button.
and trouble solved.
Mar 05, 2010 | RCA F32650 32" TV
RCA Scenium 44" HD44LPW62
it does not sound good take it to tv shop intermitten shut down or dead sorry
Apr 03, 2009 | RCA Scenium D34W20 34" TV
TV will not start up with new lamp
Here's my question you replace just the bulb and not the balanced if so there are three wires that go to your fan check them and see if they're brittle if they are you can change the wires I went up to a bigger wire can't get too big the center wire I believe is the one that makes the TV come on the other two wires are what controls the fan I read if you take a nine vote battery across the terminal of the fan Connector battery will only set one way to make the fan come on so If it doesn't come one try it the other way this may or may not help good luck if they're brittle replace them you'll be surprised
Dec 26, 2008 | InFocus ScreenPlay 4805 Multimedia...
RCA HD61THW263
If the picture comes on a its blue the lamp is ok. If you dont't get a menu then you really have a problem. A technician can bring up test patterns on this set that can tell you what the problem is.
Sep 04, 2008 | RCA HD61THW263 61" Rear Projection HDTV
InFocus ScreenPlay SP61md10 (same as RCA HD61THW263)
I hope you are still under warranty. This is usually a problem with the main DLP chip seating properly on the board. I have rarely been able to correct this without getting a new engine board and DMD (digital mirror device).
Jul 15, 2008 | InFocus ScreenPlay 61" Rear Projection...
Lightning Problem
I HAVE A 61" RCA INFOCUS ALL THE LIGHTS IN FRONT OF THE TV IS BLUE YOU UN PLUG IT AND PLUG IT BACK IN IT STAYS BLUE. YOU CANT TURN IT OFFOR ON
Apr 14, 2008 | RCA HD61THW263 61" Rear Projection HDTV
RCA d52w20?
ok ...first question ... what happens when u push menu?...do you get any osd...on screen display...menues volume.. channel number. HOw bout any sounds... the light comes on and the stays on..?
Dec 03, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 20F420T
if you can bring up the menu try using the volume up / down and channel up/down on the remote to change your selection. that might work
Sep 01, 2007 | RCA 20F420T 20" TV
RCA HD61THW263 61" Rear Projection HDTV Logo
276 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
