Question about Dell Inspiron 1525 Notebook
Black screen and and no.9 highlighted - looks like a locked
  • Dell Master
  • 27,725 Answers
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
Posted on Dec 31, 2010
Hi. I need to make default setting to print grayscale. Kindly give me the steps. Thanks
Color/black mix
This item allows you to configure printer settings to optimize printer and cartridge performance for the printing environment. If the printer is primarily used for black printing (over two-thirds of the pages are black only), change the printer settings to MOSTLY BLACK PAGES.
Setting the color/black mix
1. Press Menu to enter the MENUS.
2. Press to highlight CONFIGURE DEVICE.
3. Press to select CONFIGURE DEVICE.
4. Press to highlight SYSTEM SETUP.
5. Press to select SYSTEM SETUP.
6. Press to highlight COLOR/BLACK MIX.
7. Press to select COLOR/BLACK MIX.
8. Press or to select the desired option. (Select MOSTLY BLACK PAGES)
9. Press to select the option.
10. Press Menu.
Select MOSTLY BLACK PAGES if you print mostly monochrome print jobs, or a combination of color and monochrome print jobs.
Product User Manual (You may like to refer to Page 65)
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 16, 2011 | HP LaserJet 4700 Printer
I cant watch any dvds on my dvd player as their is a parental lock on there, i have tried unlocking it but i need a code which i dont have, the model is a sony RMT-D175P
OK - to switch off the parental control on the Sony DVP-NS15 and reset the password, please do the following:
1. Switch on the TV and the DVD player
2. Set the TV to the correct input for the DVD player so you can see the on-screen menu
3. Remove any disc from the player and close the disc drawer
4. Press the DISPLAY key on the Sony remote control to open the on-screen menu
5. Use the DOWN arrow to highlight the disc and padlock (parental control) then press ENTER
6. Use the DOWN arrow to highlight ON> then press ENTER
You will be asked to enter a password. Press 1 9 9 7 0 3 then press ENTER. Don't worry that it's only asking for four numbers, you need to enter all six. After you enter the master password, you will be asked to set a new password. Set this to something easy to remember, e.g. 0000 then press ENTER and confirm the password.
Finally, if you don't want to use the parental control feature you need to switch it off. If asked for the password again, enter the new password you set.
7. Use the arrow keys to highlight OFF> and press ENTER
8. Press the UP arrow to highlight PLAYER> and press ENTER
9. Highlight LEVEL and use the arrow keys to set this to OFF
10. Press the DISPLAY key again to close the menu
If you have any difficulty unlocking the player, please let me know.
Apr 05, 2011 | Televison & Video
How can i replace dell inspiron 1525 laptop monitor?
For removing the panel, things you need is just a small + 03 Number Screw Driver.
1. Remove the button highlighted above using a Sharp Object like Safety Pin.
2. Now you will find screws for the Outer Frame.
3. Remove the screws one by one.
4. You might find some locks for the outer panel.
5. Slightly Insert - sign Screw Driver on the frame and scroll it until the locks are released.
6. Now you can easily remove the panel.
7. Once the outer panel is removed, you will find some screws on the side of the frame, unscrew it.
8. At the bottom side of the Monitor there will be a Power and Signal Cable for the Panel, unplug it.
9. Thats it now the panel is removed.
Take Care.
Apr 03, 2010 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
I need to fix the calculator to float 5 decimals,apparently it's not floating.
If you want your calculator to display the results with 5 decimal digits:
  1. Open the [MODE] configuration screen.
  2. On first line highlight [NORMAL], if it is not already highlighted and press [ENTER] to validate.
  3. Use Down arrow key once to reach the line Float 0 1 2 3 4 5 6 7 8 9
  4. Use right or left arrow key to highlight the number 5 in the foregoing list (Float 0 1 2 3 4 5 6 7 8 9).
  5. Press ENTER to validate your choice
  6. Press [2nd][Quit] to exit the [MODE] configuration screen.
Mar 14, 2010 | Texas Instruments TI-84 Plus Calculator
How to watch dvd on a toshiba 20af43 without original remote control
To remove the video lock:
1. Press MENU, then press left or right to display the OPTION menu.
2. Press up or down to highlight LOCK.
3. Press left or right to display the LOCK menu.
4. Use the Channel Number buttons (0-9) to enter your PIN code,
then press ENTER. The LOCK menu appears.
5. Press up or down to highlight VIDEO LOCK.
6. Press left or right to select:
• OFF: Unlocks all video input sources.
Jan 05, 2010 | Toshiba 20AF43 20" TV
Have a toshiba 27df47 flat screen tv. how do you
First make sure the video inputs are not locked using these instructions:
To set up the video lock:
1. Press MENU, then press or to display the LOCKS menu.
2. Press  or to display the password entering mode.
3. Use the Channel Number buttons (0-9) to enter your password,
then press ENTER. The LOCKS menu appears.
4. Press  or to highlight VIDEO LOCK.
5. Press or to select:
Then it appears that choosing Video 2 using the TV/VIDEO button should enable the front input.
An entire manual is avialable here that should closely match your tv:
http://www.tacp.toshiba.com/tacpassets-images/models/27DF46/docs/27DF46_om_E.pdf
Aug 29, 2009 | Toshiba 27DF47 27" TV
Black and white dstv
look on the TV menu for (system) in south africa we use PAL, if you cant change it on the TV, with the decoder remote press menu then 7 then 4, it will ask for a pin code press 9-9-4-9 it will read "RF modulator" press OK, it will then read 1 MODULATION press ok again and it will highlight PAL I now press the right key and press OK, if this persists then the decoder it probably faulty... good luck
May 28, 2009 | Sony KP-EF61 61" Rear Projection...
After being turned on the screen goes black and the lock key with the number 9 is illuminated ablove the keyboard
It is better to run the dell diagnostics, when you see the dell logo keep on tapping f12, then choose utility partition and do an express on your system.
Nov 01, 2008 | Dell Latitude D400 Notebook
Unable to unlock screen
The A with a lock icon is the symbol for the capslock. maybe the reason why you cannot log back on is that it's not accepting your password because you have the caps lock on.
Oct 09, 2008 | Acer Aspire 5315 Notebook
Dell Inspiron 1525 Notebook Logo
60 people viewed this question
Alun Cox
