Question about Microsoft Xbox 360 Console
My xbox 360 was working fine, the cable that goes into the back of the 360. then connects to the tv has broke, I bought a new 3 in 1 cable from Wal Mart. With this cable the 360 plays sound and the tv has a solid green bar on the bottom. I have a HDTV 52 inch insignia. What is the problem?
  • 1,557 Answers
Take the cable back i hate 3 in ones by gamma electronics they fail badley trust me ive seen 4 this month alone
Posted on Dec 31, 2010
I have just bought an xbox 360 conected it to my tv allcables connected picture great but no sound
Hi Douglas
I imagine you have bought the new slim Xbox 360? Did you use a HDMI cable to connect it to your TV or did you use the standard cable? If you used a standard AV cable ensure that you connected the red and white cables into the same AV input as the yellow video cable.
Mar 05, 2011 | Microsoft Xbox 360 Console
Xbox-360 wireless controller doesn't sync at all
my xbox e87a2ee.jpg joystick this spot of cable is broke and i dont know what is sequece of colours in cable?
Oct 23, 2009 | Microsoft Xbox 360 Controller
HDMI Problem
ok i think you need to reset the video settings here is a step by step procedure which you can follow
To reset the display settings of the Xbox 360 console to the default settings, follow these steps:
  1. Remove any discs from the disc tray.
  2. Turn off the console.
  3. Turn on the console.
    Note If you are using an Xbox 360 Wireless Controller, turn on the console by using the Xbox Guide button on the controller. Wait for the guide light to indicate that the controller has linked to the console.
    Note Make sure that you use the player 1 controller when you do this. The player 1 controller is indicated by the upper-left quadrant light on the console.
  4. As the console starts, press and hold the Y button as you pull the right trigger.
    Note This action causes the Xbox Dashboard to reset the display settings to the default settings. The console then automatically restarts.
Jul 10, 2009 | Microsoft Xbox 360 Console
New xbox 360 arcade no screen or sound
to start off,what type of cable are you using??
since you've already tried using 2diff TVs,basically its with the console
try using a different AV CABLES, if it still doesnt work,try calling xbox support hotline for possible replacement of your cable or for processing a repair for the xbox if necessary..
since you just bought your console,try going back to the store where you bought it and have it replaced, because for the repalcement of the cable if you call xbox support,it will take 8-12business days for toureceive it and 2-3weeks for the turn around time of the repair for the xbox.
May 17, 2009 | Microsoft Xbox 360 Console
TV screen is fuzzy
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. Try another television
3. If the steps dont work, call xbox customer support to have your xbox serviced. Good Luck! hope your console still has warranty
This issue means that your xbox 360 console is having a problem with its Video Card.
Mar 28, 2009 | Microsoft Xbox 360 Elite Console - Black
Picture will not show
You might want to try the following:
1. make sure that the AV cable is not loose or incorrectly seated in both the Xbox 360 console and the TV
2. make sure that you have the correct AV cable for your TV, to verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, disconnect the AV cable and then reconnect the AV cable to both devices
3. if you are using composite cables, do not try to set any HDTV settings because you may lose the picture
4. make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
Example:
- if your Xbox 360 console is an NTSC console, make sure that your TV supports NTSC
- if your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- if your TV has a type of picture compensation enabled, disable it
5. reset your Xbox 360 console
- Remove any discs from the disc tray
- Turn off the console
- Turn on the console
- As the console starts, press and hold the Y button, and then pull the right trigger at the same time
- The Xbox Dashboard resets the display settings to the default settings and then automatically restarts the console.
6. Do not take your Xbox 360 console or its accessories to your retailer for repair or for service unless an Xbox Customer Support representative asks you to do this
Mar 09, 2009 | Microsoft Xbox 360 Console
My 360 is it broke?
just check the av cable you are connecting the console with the tv and check tv settings for the same. i dont think you need to hold any buttons its just a cable problem what is sounds to me.. change the cable if tv is working fine or just check the connections at your friends place and make a note of that and to the same thing at your place with the same connections..
tell me if this works !!
Have a nuce day !!
Apr 18, 2008 | Microsoft Xbox 360 Console
Color problems with 360
It sounds to me like a problem within the 360s hardware itself. You could try sending it back to microsoft or like you said, going out and getting a new one.
Sep 03, 2007 | Microsoft Xbox 360 Console
No color on Sony TV, all other tvs are great
check the av cables in back of your tv and also check the wires connected up to the xbox 60 it's self
Sep 01, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
74 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
