Question about Fujitsu Plasmavision PDS-5002 50 in. Television
Not always but most of the time , after working propely i can ear the fan(s) going stronger for few seconds, a message "ERROR MESSAGE CONDITION2" appear , the TV(monitor) shut down, and the power indicator go from green to fashing red twice, stop,twice, stop.....(sorry for my english) I could read in the manual somthing about component getting rapidly hot, but i don't feel any heat in the back and also sometimes the TV can work all night perfectly... Any solution? or knowledge of what is the part responsible?... Thanks
  • Fujitsu Master
  • 6,694 Answers
check the fans first. i may have some problem. i think the fan may be not attaining its regular speed. it can happens because of the wear and tear of the bearing of the fan. thats why the temperature is going up and shut the tv off. replace the fan and then try again.
ok
Posted on Dec 31, 2010
Testimonial: "Im going to try that, thanks. To be continued..."
Sony VAIO laptop stopped working properly
Good Day!
Can I know what operating system are you using?
Mar 05, 2013 | Computers & Internet
Evolis dualys 3 out of papper
a) Clean the printer
b) Print
Persistence: Probably sensor of the feeder has a problem.
Always good to restart everything, in case Windows plays tricks on you. ;)
Jan 31, 2013 | Evolis DUALYS 3 ID CARD PRINTER
Air flow error message again and again....
A few of these sets did have a issue, the lamp cartridge had some fine metal mesh around a few places where the airflow from the cooling fan contacts it, that mesh if there gets blocked with dust and will give this error as it is really the set detecting the lamp temp is too high.
If you find that, clean the mesh free of dust, careful not to drive the dust inside onto the lamp face itself.
Other than that dust on the fan that cools the lamp can slow the fan just a little and the set will detect this also.
Dec 21, 2012 | Mitsubishi WD-Y57 57" Projection HDTV
Hi , I am using hp pavillion dv4 1131tx laptop. My screen always randomly turns black and then shuts down after a few seconds. when i start it back up, i get this message: "The system bios has...
well your CPU centeral processing unit is overheating ..check the fan if its still working.. if its then try to clean the fan take it part and get it clean .
May 06, 2011 | Computers & Internet
Blinking power on switch 4 times what is the error message related to. took the lamp out of this machine and put in another worked fine...any ideas...thanks
PROBLEM: The fan is broken
If any fan in the projector not move, broken, jam, the power light blinking 4 times after few second of power ON
SOLUTION: Remove the filter and then remove the upper cover
check fans and fan connector
if all fans are OK then remove the fan connector and reinstall
fix the cover and power ON projector
Feb 02, 2011 | Sony VPL-EX4 Projector
Received apparent error message "E3" for upper
E3 is a fan error. This is usually caused by poor connection to the fan. Remove all connectors and reinstall assuring tight connection. This should remedy it unless the fan is bad, which is very rare!
Jan 12, 2011 | Magic Chef MCWC44DZ Wine Cooler
The original battery stopped working. Whenever we picked up the phone it just made a very loud noise in our ears. Now I ordered replacements batteries from ebatts. The red light is always on, slightly...
place the phone in the BASE for several seconds then try it. make sure it is the base and not a stand alone charger. if this does not correct it ensure you have the correct replacement battery for the phone. be aware the first time you charge it ... it has to be charged for at least 12 hours
Dec 08, 2010 | Dual Maxus 5.8GHz Handset Cordless Phone
When I try to fax a document to another fax Machine ( either via feeder or through software), I am always getting an error message " A communication error occured..." (Error 387)
Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Dec 01, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Microsoft word 2007 wont load without configuring first every time, how do I fix it? Each time I go to open microsoft word 2007 it takes several minutes to open. It always says configuring office 2007....
re-install word 2007 and activate it over internet after entering the product key. or else the you wont be able to create or edit any document after the first 30 accesses to the word. be sure to use the genuine software since pirated versions won't work propely....
Aug 29, 2009 | Microsoft Office Word 2007 Upgrade:...
Cmos problem
If you didn't get to the CMOS setup page then it will always show the same error. You have to press it many times (not just press it once) Or maybe it is not the DEL key. If I were you I will keep pressing DEL, F2, F10 or F12 a few time (using both hands). The timing here is crucial because the system only allow a few seconds to go to the CMOS setup menu.
Mar 26, 2008 | ASUS P4S800D-X Motherboard
Fujitsu Plasmavision PDS-5002 50 in. Television Logo
87 people viewed this question
Top Fujitsu Televison & Video Experts
Electro Med Services...
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
