Question about Ridgid 10"Wet Tile Saw with Laser and Stand
Was cutting tile and it just shut off. Blade seemed dull. Does blade stop running when it needs to be replaced?
  • 1,557 Answers
No it does not there is a fault with the cutter arm in most cases its a broken switch or its brusges are too worn
let me know if you need more advice
Posted on Dec 31, 2010
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 144 Answers
You either fried the motor and or the belt came off. Or ya got something wet and it shorted out. Try plugging it in after it dries and see if it works now.
Posted on Sep 29, 2015
I have a 10" ROK tile saw which shakes violently
MAKE SURE THE BLADE IS RUNNING TRUE, UNPLUG SAW ! BRING THE BLADE DOWN TO THE CUTTING DECK, WITH YOUR HAND TURN THE BLADE, AND WATCH WHAT THE BLADE DOES. THERE SHOULD BE NO SID TO SIDE OR UP AND DOWN MOVEMENT IN THE BLADE ! THERE IS LITTLE WASHER KITS THAT MAKE CENTER THE BLADE TO THE DRIVE. OR IF THE BLADE WIGGLES WHEN ALL IS CENTERED, IT MAY BE A BAD BEARING IN THE BLADE HEAD.... IF I WAS OF HELP HIT THE YES BUTTON.. THANKS JAY.. THE MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jun 20, 2011 | Diamond Products Mk - 101 10" Tile Saw
My felker tile master xl is cutting out of square
A dull blade or lack of water will cause this issue. Instead if cutting cleanly,excess friction will cause the blade to ride up the sides of the cutting channel. This action pulls on the tile causing an un-square cut.
Feb 02, 2011 | Saws
Target wetsaw starts and runs fine. Half way through the tile the blade binds and the motor bogs down which trips the breaker. It does it every cut now. Never had an issue before. Tightened the belt, still...
First thing I would check is that the table is square to the blade. If the back edge of the table that pushes the tile through the blade isn't perpendicular to the blade the cut will start fine but as you go through the tile the table will be pushing the tile into the side of the blade and cause a huge amount of friction, making the motor work harder and eventually pop the circuit breaker.
Jan 21, 2011 | Husqvarna Saws
I purchased the new Ridgid tile saw named " The Beast". Initially it looked like a great saw buy after cutting a few ceramic tiles I began to notice that it cuts with a slight curve. I could not find any...
Its either the speed of the blade ( mine came with its speed at half rate), or its the crappy blade they give you with the saw. If a cut is bowing your blade is having a tough time with material. This often happens with tough porcelain tiles and not using a porcelain blade.
Oct 01, 2010 | Ridgid 10"Wet Tile Saw with Laser and...
Saw is not cutting true / will not cut a straight line ?
Check blade is on properly. Remove blade and clean area where mounts to shaft. Make sure proper washers are in place. If blade is bent or wobbles replace. If blade is dull replace. Be sure you're getting enough water to saw. Don't force the tile through, let the saw do the work. Nothing helps any kind of saw more than a nice new blade.
Jul 01, 2010 | Diamond Products Mk - 101 10" Tile Saw
Tile saw not cutting straight
Sometimes a blade that is set deep enough will walk in this manner, especially if it is a thin kerf blade like the MK Hotdog blade.
Also, a blade which has worn unevenly will do this too.
Jul 11, 2009 | Mk Diamond MK - 101 Pro 24, 2hp Tile
Crooked cuts
The bearings in your saw need to be replaced. I would contact a DeWalt store to obtain the parts or have them do the repair. You have an excellent saw there, well worth repairing. good luck.
Jan 04, 2009 | Dewalt Heavy - Duty 10" Wet Tile Saw -...
Tile Saw Troubleshooting
options, change the blade, buy a more expensive blade, make sure the blade turns true when running, if not the armeture might bent inside the saw.
Aug 27, 2008 | Mk Diamond 5.3 amp Tile Saw
Tile Saws question
Since tiles are so thick, brittle, and made of ceramic, a special saw must be used. An ordinary circular saw for wood or metal would either break the tile or get so hot that it would seize up and stop cutting. However, ceramic tile is not cut well with sharp blades. The wet tile saw was invented to address all these unique properties of ceramic. It doesn't overheat, uses a relatively dull blade with no serrations, and can be transported to a job site and set up on top of an existing table or sawhorses.
Aug 27, 2008 | Dewalt DW8306 36-Grit. 4-1/2" Blue...
Ridgid 10"Wet Tile Saw with Laser and Stand Logo
666 people viewed this question
Top Ridgid Saws Experts
ken skalski
John Trevino
Are you a Ridgid Saw Expert? Answer questions, earn points and help others
