Question about Kenmore 500 6952 Dryer
Stops heating after aprox. 5 min. which thermostat should I replace?
  • 1,557 Answers
If its gas there is a flow problem if its electric then its the thermis it sits at the back on the barrel holder
Posted on Dec 31, 2010
LG model TS-K2430hl .Outside fan stops after a few min.
Should like your unit is working fine unless this is constantly happening. If this is a constant thing then condenser coil if dirty,check thermostat setting
Dec 16, 2017 | LG Heating & Cooling
Dryer stops tumbling, but heating element stays on
Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat
May 18, 2008 | GE DBXR463EBWW Electric Dryer
My indesit tumble dryer idv65 runs for 10 mins and then trips the electric and stops
if its an old dryer its probably the motor thermostat heating up and shutting the motor down ,replace that or even the motor
Jan 14, 2013 | Dryers
I cant get the ac ( cool ) to work , it read HOLD @ 82 degrees. I'm sweating over this
Hello my name is Heath it will be my pleasure to assist you. Your thermostat may be on the blink and need to be replaced. But first lets try a couple things first take the batteries out of the thermostat and let the display go completely blank ( aprox. 5 mins.). While that is going blank go to the indoor air handler and turn the power off to it either from the switch or the inside panel box. Then once the display has gone blank turn the power back on and put the batteries back in. Then set the switch to cool and turn the temperature down and press hold and try it like that to see if it goes back to heat if it does then the thermostat is changing the temperature on its own and going into heat mode and will need to be replaced.
Sep 11, 2011 | Heating & Cooling
Kud101 diswasher heater element
The dishwasher will heat the water to a temp of aprox 140deg if the heater is not working then the dishwasher will not shut off because it has to heat the water to a point where a thermostat will close during the heating time the dishwasher time stops advancing, also heater is used to heat the air for dry cycle
Sep 07, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Fan cutting on and off every 5 mins
The only thing that is going to but the fan off is the thermostat. When the fan stops, immediately check the thermostat on the wall. See is there is power between the B terminal and the GH terminal. If none, then replace the thermostat. If there is, then replace the control board in the AC. That means that the fan relay on the printed circuit board is weak.
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
RTH230B thermostat not working - nothing's happening
The 2nd combination is correct (w/ jumper). Wire nut or tape the blue wire. The snow flake shows it's going into cooling mode after a 5 min delay. If the AC is not coming on then the problem may not be the thermostat. If you don't have 24VAC between the red wire and the blue one the problem is at the furnace or it's supply. If you do, then check for 24VAC between the blue wire and Y on the thermostat(after the 5min delay) - if it's there the thermostat is calling for cooling. To check the heat, switch the thermostat to heat mode and use the W(instead of Y) on the thermostat(after the flame stops flashing).
Apr 02, 2009 | Honeywell Programmable Thermostat Heater
Kenmore 500 6952 Dryer Logo
172 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
