Question about Canon Office Equipment & Supplies
Help formatting HDD and installing SST on Canon iR3300i
  • 71 Answers
Hi
Formatting and installing sst must be done on a computer with Canon support tool
Posted on Jan 01, 2011
Hard disk is ok then occur code E602-0001
Canon? Naughty Canon.
There is no hdd compatibility list / HDFormat files are encrypted > not viewable
Originally these HDD Dewcriptor Files were regular text files which could be edited to add new HDD formats when
necessary. More recently Canon has started encrypting the files to prevent them being edited.
Modifying the HDD Descriptor is out of the question on this series
Canon ImageRUNNER's will require that authentic Canon HDD's be installed should they require replacement. Generic drives may not be on
the list of supported drives for the SST and Canon will not release a list of supported drives.
http://www.copytechnet.com/forums/canon/100500-e602-0001-a.html
Oct 26, 2015 | Computers & Internet
When the Canon IR 3300 switchs on it displays the Error code E000602-0003 please help me what to do
This error belongs to the Hard disk of the copier. Please re-install the system software in HDD or replace the HDD with new one.
Oct 08, 2015 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
00602-003 error
Your hard disk needs to be replaced!! E602-003 is a bad sector read on the hdd, if you restart the machine it may work for a while but it WILL come back.
You need canon part number WM2-5230-000 (not sure how you would get it) it needs to be installed in the back of the machine at the top of the main body after the back cover has been removed.. Once this is done you dilemma begins, Canon uses a program called "service support tool (SST)" which is only a canon issued program, this program is the tool used to update all the software and firmware in iR devices. This can only be connected to a 2200 machine via usb to centronics cable with a "nethawk driver" driving the cable. Then SST need to have the firmware for the 2200 series registered (it does not come together) within SST, then connect cable and turn the machine on at the switch on the right hand side WHILE holding keys 2 & 8 together, this will give you a black screen which only shows "DOWNLOAD MODE" in the lower part of the screen. Then the machine is ready to accept the data. SST is extremely touchy, so if anything is not right you will get a lovely pink screen in SST saying an error code. To correctly set up the hard drive you must first format the HDD from within SST, then install the BOOT and SYSTEM versions (boot must be "N" at the end of it's version eg. 37.44N to be a printer or a stand alone copier will have a "C" at the end. You must pick the right one or you will not be able to print (if it has a PCL kit installed in the machine).
After all Boot, system, language, fax versions are installed restart the machine, wait for a couple of minutes intil all that data is written to the HDD and it will pup up ready to go.
Apr 22, 2014 | Canon iR5000-6000-L1 PS Ver 1.0
Won't print;
The problem means that your hard disk needs to be replaced. E602-003 is a bad sector read on the hdd, if you restart the machine it may work for a while but it WILL come back.
You need canon part number WM2-5230-000 (not sure how you would get it) it needs to be installed in the back of the machine at the top of the main body after the back cover has been removed. Canon uses a program called "service support tool (SST)" which is only a canon issued program, this program is the tool used to update all the software and firmware in iR devices. This can only be connected to a 2200 machine via usb to centronics cable with a "nethawk driver" driving the cable. Then SST need to have the firmware for the 2200 series registered (it does not come together) within SST, then connect cable and turn the machine on at the switch on the right hand side WHILE holding keys 2 & 8 together, this will give you a black screen which only shows "DOWNLOAD MODE" in the lower part of the screen. Then the machine is ready to accept the data. SST is extremely touchy, so if anything is not right you will get a lovely pink screen in SST saying an error code. To correctly set up the hard drive you must first format the hdd from within SST, then install the BOOT and SYSTEM versions (boot must be "N" at the end of it's version eg. 37.44N to be a printer or a stand alone copier will have a "C" at the end. You must pick the right one or you will not be able to print (if it has a PCL kit installed in the machine).
Thank you !!
After all Boot, system, language, fax versions are installed restart the machine, wait for a couple of minutes intil all that data is written to the hdd and it will pup up ready to go.
Hope this helps.....
May 21, 2010 | Canon imageRUNNER 2800 Black and White...
Canon ir3300 error602-003
how to install data in the hardisk of ir 3300 machine. plz say me the full process what is sst and everything
Dec 09, 2009 | Canon Office Equipment & Supplies
Ir5000i error 602
Ask Canon. If you're authorized they should be able to help you get what you need.
If you're not a tech get a tech to do it.
Jun 10, 2009 | Canon imageRUNNER 5000 Copier
Ir 2200 hard drive crash
That's probably because you're not a tech. The hard drive is not a user replaceable part. Get a tech to replace the hdd, format and install system software using sst.
May 03, 2009 | Canon (6981A002AA) for imagerunner 2200,...
HDD
Get a technician to replace hdd, format and reload system software using sst.
Apr 27, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
How to replace HDD IR5000??
how to clear hard disk IR 5000 and where i can find hard disk software
Dec 20, 2008 | Canon imageRUNNER 8500 Copier
E602
Turn on holding down 1 and 9 keys. will go through a long complete format. If blocks do not fall down through screen left to right, HDD is completely gone.
Nov 23, 2006 | Canon imageRUNNER 8500 Copier
152 people viewed this question
old marine
old marine
