Question about Yamaha RX-V663 Receiver
My brother gave me this Yamaha RX-V663 receiver because he'd bought a new one. He said it was starting to have sound issues. So, I have seven speakers (minus the subwoofer) all hooked up correctly (double checked it) but when I turned it on and tried to listen to the radio (FM antenna already attached) I can't hardly hear any sound. I switched to any devices like the dvd player or the ipod dock still with hardly any sound coming from the speakers. I have to turned the volume more than half-way just to hear any sound. And it sounded like when you're standing next to a person wearing his headphone listening to loud music. Did I configure it incorrectly or something is really wrong with this receiver? Any advice would be greatly appreciated. Thanks in advance.
  • 11,361 Answers
Here is the owner manual:
http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V663_U.pdf
It sounds like the TAPE monitor switch is on or MUTE function is activated.
You may have to read through the manual first.
Or it can be the audio switching processing circuits are bad.
Posted on Dec 31, 2010
  • Yamaha Master
  • 6,694 Answers
its not with any setting problem. its because ur receiver have some hardware problem. if there is any supply voltage missing, this problem can occur. especially the +15vand -15v. or if there is any loose contact or dry soldering in power supply or in the DAC ( Digital to analog converter) card. first of all check for any dry soldering in the main board. also check the soldering of DAC board socket and input selector board socket.
ok
Yamaha rx-v663 how to set and lock sound program
once you set the audio program for an input, it should stay set even if you power the unit down. As far as locking that program so that it cannot be changed - no there isn't a way to do that.
May 07, 2015 | Yamaha RX-V663 Receiver
Yamaha rx v663 video signal skipping
I'd leave it that way if it was me.
Jan 28, 2010 | Yamaha RX-V663 Receiver
Yamaha RX-V663 display is not working
If you have your receiver hooked up to a TV or Monitor, press "Menu" then toggle to section "5" "option menu" and check your "Dimmer" setting "0" is highest. Then check "FL Scroll" and the choice is "Cont". This info is on page 96 in your manual, if you don't still have a copy, here's the link
http://www.yamaha.com/yamahavgn/Documents/YEC/AV_Receivers/Manual/RX-V663_U-1.pdf
Hope this helps. If you still have a problem, post a comment and I will help you further.
Dec 26, 2009 | Yamaha RX-V663 Receiver
Switching from comcast to verizon fios my rx-v663
This usually means your receiver is not passing the HDCP copyright protection correctly. Try using component cables instead, if your receiver supports it.
Nov 25, 2009 | Yamaha RX-V663 Receiver
Decoder problems
OK, use the down mix function on your blue ray player. this will decode for your receiver. the down mix feature should be located in the audio options on the blue ray menu screen.
Mar 16, 2009 | Yamaha RX-V663 Receiver
Verizon Fios connection issue with RX-V663 Receiver
I had the same problem with RXV3900, was told by verizon and yamaha it's a software issue with the box. Verizon is suppose to be working on a new update, but no time frame for now. I'm using component to receiver, and hdmi to tv with no issues.
Mar 15, 2009 | Yamaha RX-V663 Receiver
Yamaha RX-V663 delays 10-30 seconds between commands using the remote control. New batteries, new receive. For example, try to raise volume. It goes up 1 dB then cannot give any other commands using the...
I have seen this type of thing with several remotes.  You have some light source in the room that is interfering with the reception of the ir.  Turn off all light sources in the room and then try.  You might be surprised!
Dec 20, 2008 | Yamaha RX-V663 Receiver
Yamaha RX-V663 - HDMI doesn't work.
Hi and welcome to FixYa,
Initially, a workaround:
  • as you posted, audio out of the DVD goes to the receiver;
  • HDMI out of the DVD goes to the Schaub Lorenz LCD.
Even if it were a compatibility issue or HDMI processor issue on the receiver, the above should get you going.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 19, 2008 | Yamaha RX-V663 Receiver
Yamaha RX-V663 Receiver Logo
168 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
