Question about Sony Handycam DCR-TRV103 Digital Camcorder
Suddenly stopped working and displays error code C:31:23. If I turn the power off or unplug it, it will allow the tape to be ejected when I turn the power back on. But it will not play or record any longer. It just gives the same error code. Does anyone still repair these?
  • 536 Answers
From the user manual that I found on the Sony web site (click here), the C:31:nn (where n is any number) error code is a sign of a malfunction within the camera.
They suggest two solutions:
1) Remove the cassette and insert it again, then operate your camera 2) Disconnect the power cord of the AC power adapter and/or remove the battery pack. After reconnecting the power source, operate your camera.
From your description, it would seem that you need to try option 2)
Hopefully this resolves your issue. If you have any questions, please ask.
Thank you for using FixYa and Happy New Year!
Posted on Dec 31, 2010
I have an older (1996) Sony Handycam CCD-TRV211. I am using the player to transfer my old 8mm tapes to my computer. The player will play for about 4 seconds then stop. I get a blinking triangle with a...
How are you powering the camcorder ? Many will not transfer videos if battery powered, since the battery may fail. Try again with the camcorder mains powered, see if that helps. Have you cleaned the heads with a cotton bud and a little IPA ?
Mar 01, 2017 | Cameras
JVC mini GR-D23EK Unit in SAFEGUARD mode E03 how to correct it
Hello. What I've found is that in dealing with the error codes your choices are very limited. You can try removing the battery and power supply for a while. This might clear the code, however, failing at that you'll be forced to send in the unit for repair--you are absolutely not alone in getting this type of problem--definitely get a quote first and keep "do I want to replace this unit" in the back of your mind....This is a JVC problem.---Rick
Sep 16, 2009 | JVC GR-D370 Mini DV Digital Camcorder
Will not display picture or eject tape.
most of no signal means dsr 11 or similar machines have dirty heads. When they get dirt sometimes, you can´t play a cassette and the machine turns off (with the cassette in).
I´ve tried several times to reload the cassette and I manage to make it work again.
with the cassette in and the machine off press at the same time power and fast forward.
When in fast forward press play and your head should be starting to be clean (takes 4 o 5 minutes
to get a clean picture). Normally the machine gives a code error like if it was a loading problem but
not nearly related
Mar 13, 2009 | Panasonic Televison & Video
The tape will not eject, battery is charged, help! Thank you!
Unplug battery and reattach it again, then try to eject the tape.
If problem still exist and camera shows error code "C:..:.." and beeps then it is problem of tape mechanism.
Dec 13, 2008 | Sony Handycam DCR-TRV50 Mini DV Digital...
C:32:11 message flashes, cassette eject won't work, camera doesn't work
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Nov 24, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
DCR TRV320
That is the "LOAD" error code.
However, to service the C:31 code, Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Oct 25, 2007 | Sony Handycam DCR-TRV320 Digital Camcorder
Error "04" on display & tape won't eject
you have bad capacitors in your power supply. i would suggest you take your unit to a good shop in your area and request a power supply re-build and mode switch cleaning.
Jan 22, 2007 | JVC BR-S822DXU VHS/S-VHS playback VCR
Sony Handycam DCR-TRV103 Digital Camcorder Logo
89 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
