Question about Mastercool 67471 Evaporative Cooler Air Conditioner
My evaporative cooler is only blowing warm air through the home, even though the water is on and all windows are open. Can you help?
  • 40 Answers
Check if the water is getting into the unit. check if it is pumping any water over the filters. cooler will meet its limits at 90% humidity plus
Posted on Apr 04, 2011
  • Sherri Stanes
    Sherri Stanes Feb 02, 2014
    there is no water going to the unit at all...
I have a Taiwan evaporated cooler, 120 vac 60 Hz 85 w. Does this unit cost a lot of electricity to run, or is it fairly energy efficient
evaporative coolers use a principle of blowing air though a filter that is water moist
the air passing through the water uses a heat exchange process as the water boils off, the air is cooled and so you get cooler air
very efficient in places where the humidity is under 80% but over that the water doesn't evaporate all that readily and so the effectiveness is reduced
basically the hotter the day and the lower the humidity the more efficient they are.
Cheap --yes as it only runs a small motor for the fan and an even smaller motor for the water pump, but you will need a regular water supply some units have a small tank which needs regular filling and others can be connected to the home water supply
it is not an air conditioner , simply an air cooler.
Jun 15, 2015 | Heating & Cooling
What is wrong with my Goodman AC unit?
Sounds like it has no power getting to it at all. Dont forget that some circuit breakers have UP as ON and some have DOWN as ON. Do not just assume a common way is always the same. You may even have to have one UP and the other DOWN as on. Check what the switch or circuit breaker has written on it to be sure.
AIR CONDITIONERS run like a refrigerator, they manufacture their own Heat or Cool and blow air past the unit to give hot or cold air to cool or heat the Room. These do not require flowing water.
Sometimes people (wrongly) call EVAPORATIVE COOLERS air conditioners. (An evaporative cooler just blows AIR past flowing water to humidify the flowing air and therefore "cool" the area)
An evaporative cooler therefore would require running water and without flowing water, the unit may not start due to the installation of a "fail safe" switch. An evaporative cooler would generally have a large box mounted on your roof with open sides with filters which are kept moist by the running water and through which the fresh air is sucked and pumped into your home.
There are varying thoughts on both, I personally consider the REFRIGERATED style as the most effective type, but they are more expensive to install and run.
May 29, 2014 | Goodman Manufacturing GSZ130181A - 1.5 Ton...
Water dripping from inside top to bottom of cooler what is causing this and how can i fix it?
Coolers like yours create a lot of condensate. Every time the door is opened warm moist air enters and changes back to a liquid state on the evaporator coils behind the fan and area you see moisture dripping down from top and back wall should be going down a drain pipe to the bottom of cooler and into a pan where a fan blows warm air over the condensate/water returning it back into the store or business that the cooler is located. Looking inside there shoud be a tray or pan that is at the base of the evaporator. True uses different parts but you need to see why the water is leaking from. If cracked tray or line blockage causing overflow into the cooler. Click Here=> Leaking Refrigerators and then again here=> Leaking Refrigerators! This will help you get a better idea of what I am talking about, if helpful please rate. True MFG. does not share their information to me. I would need to be their registered customer to get answers. Click Here=> E-mail True Technicians I also think if you have questions for them they ask for your model number as a reference. They Will answer you just need that number along with GDM-72-RC I will be here if you have questions, Thank You, Sea Breeze
Oct 13, 2011 | True GDM-72-RC Refrigerator
What direction should the outside fan be blowing air . Should it be out over the evaporator or sucking outside air inward over the evaporator, which if this is the case it would be pulling hot air over the...
Those condensing units are usually designed to draw air in, even though it is warn air it is cooler than the compressor so the air moves heat away from compressor. I think its the proper configuration
Jul 11, 2011 | Coleman Mach III Air Conditioner
We have an older swamp cooler and need to have some windows in our home open to get best cooling. Does a mastercool need to have some windows open in our home to give max cooling?
The solution is to install "up ducts" These devices are easy to install and are fairly cheap. With a swamp cooler the best way to use them is to allow them to draft outside with the "up duct" you get the drafting to the outside but also get to remove attic heat too.
Apr 24, 2011 | Mastercool 67680 Evaporative Cooler Air...
I have an evaporative cooler: vulcan bonaire. the only control buttons which appear to be useful are: on/off, cool in the 'appliance' window, and cool in the 'mode' window. i have a feeling that this is...
Hi and welcome to FixYa. The principle of operation of an evaporative cooler is to provide cooler air via evaporation. The evaporation process is achieved by water being pumped over very porous pads with air is drawn through the pads. Most all evaporative coolers unless connected with a centralized heat / cool system only have an on / off & cool function. "On" is fan only (air circulation while using outside air being drawn into the home) and "cool" turns on the pump to pump water over the pads for evaporative cooling. Hopefully I did not confuse you with my answer.
Happy New Year and thanks for choosing FixYa,
Kelly
Jan 01, 2011 | Heating & Cooling
I have 550 CFM cooler and the air is blowing but
you need to open up and clean the pump unless gravity fed but still need to cleaned. or new pump.
Jul 11, 2009 | AdobeAir Adobe Air 550 CFM Portable...
Do not know how to work/maintain swamp cooler
Make sure you have water to the unit, the water pump is on and the fan is working. No water=no cooling.
Apr 21, 2009 | Mastercool 67471 Evaporative Cooler Air...
Fan blower coleman electric cooler
The fan should blow air into the heat sink. The warm air exits the heat sink at both ends. (It might work the other way, haven't tried it.)
When you have ice in your cooler, you know the thermo-electric element is working well--it's below freezing!
Ice builds up because there is water in the cooler. For example, in humid weather, you open the cooler, some humid air gets in, and the cooler temperature condenses the water. You have to empty this water, either by tipping the cooler, or using a sponge.
You can easily defrost the cooler by unplugging it for an hour or so. You know it's time to defrost when you hear the fan blades making a racket because they're hitting something--a thick buildup of ice.
Aug 10, 2008 | Coleman Electric Cooler 40 Beverage Cooler
Mastercool 67471 Evaporative Cooler Air Conditioner Logo
1,036 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
acrman404a
Level 1 Expert
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
