Question about RCA L40FHD41 40. in HDTV
Please help. Hooked up Toshiba Satellite to l40fhd41 RCA using VGA cord and video shows up on PC channel of TV. My problem is the sound. Trying to get sound to TV using earphone port on Laptop with Cable that has RED and WHITE component plugs. Tried all Audio plugs on TV but no sound. Any ideas? ATT Uverse hookep up to TV and also DVD player. Both pass Video and Sound fine. Thank you for any assistance you can provide.
  • 11,361 Answers
If you look real close at the VGA port on the TV, you will see a small mini phone jack 'AUDIO' that is for attaching the audio cable with mini stereo phone plug at both ends, one end is to the TV PC audio input jack, another end goes to the PC AUDIO line out or headphone out.
Posted on Dec 31, 2010
I am trying to connect and play my pc on my lcd tv
It depends on what sort of television you have and the connections that it has available.
1. The easiest way is to get a VGA cable like the one in the image below if your TV has a VGA input connection.
img src="http://www.fixya.com/uploads/images/mariolands_13.jpg" alt="VGA"/>
Notice this is for video, you will need a double audio jack cable to connect sound, if your TV has this sort of input, otherwise you are better of with option two.
img src="http://www.fixya.com/uploads/images/mariolands_12.jpg" alt="VGA"/>
2. If your TV doesn't have a VGA connection, you need to get a VGA to RCA adapter like in the image below. Majority of the TVs have a RCA input connection, so if your has one you need to get this adapter and an RCA cable.
img src="http://www.fixya.com/uploads/images/mariolands_14.jpg" alt="VGA2RCA"/>
Dec 12, 2010 | Toshiba Satellite L455DS5976 Notebook
Got a svga/hdmi cord and hooked up for my panasonic viera plasma to my computer but nothing shows on my component 2. also wondering if i'll need a cord for audio - i have double red/white/yellow...
You probably would need the extra audio cords seeings as normal svga connection won't suppost sound streaming. mixing and matching connections is always a pain to perfect.
If you are using the HDMI end on your plasma, then you will have the video show up on the HDMI channel. Then get an RCA red and white pair - 3.5mm jack and plug the jack into your PC's audio connection port and the RCA's into the Audio In ports in the back of the TV.
Once done the TV should display video and play sound from the PC. Failing this, try a few different configuration but always keep the audio plugged into the same Audio in port on the TV. Bacause then you at least know the channel that the audio works on ;D
Hope this helps mate, any more q's just ask!
Nov 23, 2010 | Panasonic Viera TH-50PX80U Plasma TV
My toshiba S300m has a VGA socket and no S cable socket. I want to connect the Tosh. with my TV. Problem is that the TV is an older one and has a S video (female) and it also has three (Yellow, white,...
try to lower your video/screen resolution down to what your older tv can take as an input. (try 800x600 or lower) first if that does not work search on eBay for
VGA SVGA TO S-Video 3 RCA Composite AV TV Out Converter Adapter Cable PC Cord
Jun 04, 2017 | Toshiba Satellite Pro S300M-S2403 Laptop
Where can I get a power cord to fit the RCA L40FHD41 40 in HDTV TV?
It uses the same power cord as used for PC, try your local PD repair shop, It is NEMA5-15P to IEC C13 POWER CORD.
Jun 13, 2010 | RCA L40FHD41 40. in HDTV
Trying to connect my toshiba satellite a205-s5804 laptop to my sony bravia lcd 1080 t.v. I have connected VGA from laptop to t.v.VGA pc in on t.v..Also headphone out to sound in on t.v.. T.V. not excepting...
Please double check that your VGA cable is working properly and you have installed the most updated version of video drivers.
Is the TV not even playing the sound? Are you on the right channel? Only try checking the sound on a AV channel by using a headphone jack to AV jack cable.
If you have a S-Video port try connecting with it you can get that cable for a buck in a dollar store.
Hope this helps.
Mar 23, 2010 | Toshiba Satellite A205-S5804 PC Notebook
I want to know which port on my Toshiba L300D laptop to use to connect it to a tv
Hi, you can get it connected with a vga to rca cable as show in the picture below
hope this will be helpful & don't forget to rate :)
kind regards
Jan 17, 2010 | Toshiba Satellite L300D-ST3501 Notebook
Cable from pc to tv
Have you gone into your display settings on your laptop and changed it to an extended desktop?
Oct 23, 2009 | Toshiba Satellite A135-S2386 Notebook
I am trying to hook up my tv with a vga to av(rca) cable,but I can't get it to work.What do I have to do to get it to work?
If your notebook has RCA composite video out, you need to hook it up to TV composite video input jack, usually the color of this RCA jack will be yellow. Why do you not use the VGA port on the back of the note book to feed the signal into the TV's VGA connector, just mke sure to set the resolution of the laptop to be at TV native resolution.
Sep 26, 2009 | Toshiba Satellite A105-S4334 Notebook
Connectiing toshiba satellite 2210 to a tv set
The cord you need will either be VGA to S-Video or VGA to RCA depending on which port is on the tv.Once you have the cord hooked up to both,You will need to switch into presentation mode on the laptop using the FN + F7 keys.
Please take time to rate this fixya
May 14, 2009 | Toshiba Satellite A205-S4617 Notebook
No sound when connected to my pc tv type 42 inch dynex flat panel plasma without desktop speakers connected and all audio is turned on also if your tv has speakers and ur using it as a pc monitor shouldt...
No the sound does not travel through the vga cord only HDMI has bidirectional with sound.. You gonna have to use the speakers on your laptop for sound or buy some amplified ones.. good luck
Apr 22, 2009 | Toshiba Satellite A135-S2276 Notebook
RCA L40FHD41 40. in HDTV Logo
152 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
